The routernis connected to the internet but the computer will not connecdt to the internet.
  • 43 Answers
Goto "Control Panel>Network Connections>Connected
Configure IP address to Auto-Detect>Internet Protocol
Run Add New Hardware.If modem is missing,select model & install.
Open browser,type in modem IP Address in address bar.Configure modem.
Posted on Feb 02, 2008
6ya staff
SOURCE:
Printer cannot connect to wireless network
Make sure that you're typing in the correct WEP/WPA password for your network. If you're sure you typed in the correct password, powercycle your router and printer then connect the printer again to your network.
You can also connect the printer using an ethernet cable straight to your router. Your printer will still be shared to your network.
Oct 08, 2012 | Lexmark 90P3000 - Printer Office Edge...
Tip
Set up and Use Internet Connection Sharing
To enable Internet Connection Sharing on a network connection
You must be logged on to your computer with an owner account in order to complete this procedure.
Open Network Connections. (Click Start, click Control Panel, and then double–click Network Connections.)
Click the dial–up, local area network, PPPoE, or VPN connection you want to share, and then, under Network Tasks, click Change settings of this connection.
On the Advanced tab, select the Allow other network users to connect through this computer's Internet connection check box.
If you want this connection to dial automatically when another computer on your home or small office network attempts to access external resources, select the Establish a dial–up connection whenever a computer on my network attempts to access the Internet check box.
If you want other network users to enable or disable the shared Internet connection, select the Allow other network users to control or disable the shared Internet connection check box.
Under Internet Connection Sharing, in Home networking connection, select any adapter that connects the computer sharing its Internet connection to the other computers on your network. The Home networking connection is only present when two or more network adapters are installed on the computer.
To configure Internet options on your client computers for Internet Connection Sharing
Open Internet Explorer. Click Start, point to All Programs, and then click Internet Explorer.)
On the Tools menu, click Internet Options.
On the Connections tab, click Never dial a connection, and then click LAN Settings.
In Automatic configuration, clear the Automatically detect settings and Use automatic configuration script check boxes.
In Proxy Server, clear the Use a proxy server check box.
Bhautesh.
on Feb 24, 2010 | Computers & Internet
360 x box no profile from hdd tried recover gametag no memory unit found
unplug the xbox 360 and then unplug the hard drive, if you have a connectivity kit connecdt the hard drive to your pc and see if it detects the hard drive, if it doesnt then your hard drive is most likely faulty , if it does detect it tell it to fix it, this is the only way you will be able to check it as your console is obviously not seeing it.
Mar 20, 2011 | Microsoft Xbox 360 Console
Where do the heater hoses connect under the hood?
one will connecdt to the water pump and the bottom of the radiator. The other will connect the thermostat and the top of the radiator. The small third hose is just an overflow line. It usually connects to a nipple by the cap on the radiator.
Aug 03, 2010 | 1977 Chevrolet Silverado 2500
I AM UNABLE TO ACCESS INTERNET THRU MY HYBRID APPLE MAC DESK TOP-
Go into network set up a shared Internet connection using ICS (Internet Connection Sharing) You can use Internet Connection Sharing (ICS) to share an Internet connection among two or more computers on a network. First, you need one computer, called the host computer, that is connected to the Internet and that has a separate connection to the other computers on your network. You enable ICS on the Internet connection. The other computers on your network then connect to the host computer, and from there to the Internet through the host computer's shared Internet connection.
If your computer is connected to a network, network policy settings might prevent you from completing these steps.
On the host computer (the computer whose Internet connection you plan to share):
  1. ?id=microsoft.windows.resources.shellexecutetopiciconClick to open Network Connections.
  2. Right-click the connection that you want to share, and then click Properties.getcontent.aspx?assetid=18abb370-ac1e-4b6b-b663-e028a75bf05b&documentset=en-us&renderkey=signed1 If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
  3. Click the Sharing tab, and then select the Allow other network users to connect through this computer’s Internet connection check box.
Jul 22, 2009 | Computers & Internet
Wheelwriter 6
Usually means the keyboard is bad. Check the keyboard connecdtions. Sometimes a real pain to remove and reinsert them. What lights are blinking?
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Jun 17, 2009 | IBM Wheelwriter 30 Typewriter
How can i use my motorola z3 to connect with the internet
If you mean "how can I connect my computer to the internet using my phone as a modem," then this is possible. Just set up an internet connection from your computer to go through your phone (works wirelessly, I've never tried with USB), and make sure you have a Data Plan on your phone. Connect to the internet with your phone and then use it like Wi-Fi. Keep in mind this will be much slower than using an internet card or any other sort of wireless connection to the internet.
As for getting internet on your phone through your computer, I'm pretty sure you can't do this. It doesn't make sense to even try. It's redundant. Just download what you need using your computer. Then sync the phone to the computer via bluetooth or USB and transfer whatever files you desire to your phone. There's no need to get the phone directly connected to the internet if you have a computer that can get on the internet.
Jan 26, 2009 | Motorola Mobility MOTORIZR Z3 Cellular...
Printer will not install on computer
Perhaps you have resolved your issue and just forgot to rank it
In case you have not, I will provide some basic answers to help you "FIX-YA'...in case it hasn't
If you need further assistance...just post a 'comment...as this will then appear in my inbox and I will revisit this posting to help further'
Please remember that anything other than a FIX-Ya, actually lowers my rank...although I didn't make the system...I am impacted by it...so please consider the impact as you rank my solution...please.
Solutions?
-assume it is not a Mac..as they are very automatic..if it is then clarify
-typically when you plug in your printer power cord and connecdt the USB cord into the computer, it will detect this addition and ask you (depending upon your settings) what you wish to do
-your goal is for the computer to find (& install) the correct 'driver'
-so basically you just have to 'agree' and let it search....you might need to be internet connected depending upon the printers age, etc.
-as well, be sure to turn your printer power on AFTER the computer
-if you need further assistance...please ask
hope this helps.....thanks for reading...please rank FIX-Ya or ask me further questions
sincerely
bearb
Nov 10, 2008 | Lexmark Office Equipment & Supplies
D-link cant accesed internet 4pc
Most of DSL modems are connected to PC with USB cable...
n if ur server is connected with other pc on lan .. you can use internet sharing option available in winxp.
Following are the steps to enable Internetsharing for other pcs.
How to use Internet Connection Sharing loadTOCNode(2, 'summary'); To use Internet Connection Sharing to share your Internet connection, the host computer must have one network adapter that is configured to connect to the internal network, and one network adapter or modem that is configured to connect to the Internet.
On the host computer loadTOCNode(3, 'summary'); On the host computer, follow these steps to share the Internet connection:
  1. Log on to the host computer as Administrator or as Owner.
  2. Click Start, and then click Control Panel.
  3. Click Network and Internet Connections.
  4. Click Network Connections.
  5. Right-click the connection that you use to connect to the Internet. For example, if you connect to the Internet by using a modem, right-click the connection that you want under Dial-up.
  6. Click Properties.
  7. Click the Advanced tab.
  8. Under Internet Connection Sharing, select the Allow other network users to connect through this computer's Internet connection check box.
  9. If you are sharing a dial-up Internet connection, select the Establish a dial-up connection whenever a computer on my network attempts to access the Internet check box if you want to permit your computer to automatically connect to the Internet.
  10. Click OK. You receive the following message: When Internet Connection Sharing is enabled, your LAN adapter will be set to use IP
    address 192.168.0.1. Your computer may lose connectivity with other computers on
    your network. If these other computers have static IP addresses, it is a good idea to set them
    to obtain their IP addresses automatically. Are you sure you want to enable Internet
    Connection Sharing?
  11. Click Yes.
The connection to the Internet is shared to other computers on the local area network (LAN). The network adapter that is connected to the LAN is configured with a static IP address of 192.168.0.1 and a subnet mask of 255.255.255.0
let me know if it helps.
best regards,
Nov 03, 2008 | D-Link DGS-1008D 8-Port Gigabit Ethernet...
Computers & Internet Logo
53 people viewed this question
Ekse
Marvin
Marvin
