Question about Zebra Z6M Plus Thermal Label Printer
Zebra 105se printer is printing out of the label on the wright side
Our zebra label printer 105se, is printing out of the label on the wright side.
Please help!!!!
thanks
Daniel Ibanez
    Scholar:
  • 58 Answers
It would be best if we had more information, or a picture.
For instance if you told me as the label is printing it does not print on the label, and it appears shifted to the right or front, then I would say, you need to re-calibrate the printer for that label.
If you were saying that the printer is printing on the right side of the label as you face the printer and watch the label exit the printer, then I would say, that the label size in the software is wrong, or the transfer ribbon is loaded incorrectly, too far to the right as you face the label exit path, OR the labels are loaded too far to the left as you face the label exit path.
Here is a link to a manual that may help as well.
Posted on Feb 02, 2008
    Genius:
  • 1,067 Answers
Re donload software for it maby firmware update cheak settings in software ok
  • nick helpap
    nick helpap Feb 02, 2008
    re download software from zebra website unstall old ok should reset back to were should be sumone mesed up a setting ok
I have a Zebra 105Se zebra Printer for testing. When a label is printed it just prints 1/4th of the label,then the printer stops and paper/ribbon light,Pause light and data light is on.When I open the...
Make sure that both ribbon and media paths are clean (no glue, or sticked labels). Make shure the ribon and the media are corect installed on their paths.
Sep 23, 2011 | Zebra 105Se Thermal Printer
I have a Zebra 105se printer. When I attempt to print labels, I am using bartender 9.4 to create the labels, the printer will not print using the full label. Instead it uses only the last inch of the...
Check to see what printer driver you are using. If you are using Seagull Scientific Bartender, you will need the printer driver from Seagull Scientific for it to print properly. You can download it from the Seagull website. Hope this helps!!
May 25, 2011 | Zebra 105Se Thermal Printer
Zebra 105SL print only half of label
This can happen if your page size in your driver is not set to the actual label size. It can happen if you have old .dll driver files mixed with your mew driver installation.
This is what I would do:
Uninstall the driver completely - delete the icon in Printers and Faxes. Drop down the file menu there and choose server properties and remove the driver for all Zebra printers from the Drivers tab. Go into the LCD menu of the printer and load defaults. Go back into the LCD meny and look at the page width setting. Your printer has 300 dots per inch, so a 4 inch label would be 1200 dots wide.
Another thing to consider is that you may be trying to printer to a 300 dpi printer from a 203 dpi driver. Make sure that you choose 300dpi when you reinstall. This should work.... If not, repost with more details about your application and driver. I can assure you that this is not a printer problem unless half of your printhead has failed.... unlikely, but possible....
Jan 16, 2010 | Zebra 105Se Thermal Printer
My Zebra 105SE is printing fine on the left
I think the 105 has an adjustment on the printhead. There are left and right hand adjusters just above the printhead. It sounds as if the right hand one does not have enough pressure on it, try increasing the RH one and see the effect on the print.
Jan 06, 2010 | Zebra 105Se Thermal Printer
ZebraDesigner Pro is changing my settings
If you have two printers 105se and the 105sl must install the two printers and select the correct model when you print your labels.
Mar 10, 2009 | Zebra 105SL Thermal Label Printer
Zebra 105SE label material will not retract in prep for next Lab
The platen is the driving force for the label. the main drive belt runs all functions in the printer.
Is the back feed turn on in the printer? Check the setup.
Also if the print driver is set(doc/properties settings on print depending on software) to use pirnter settings, and the back feed is turned off in the printer, it will not backfeed.
Feb 24, 2009 | Zebra 105Se Thermal Printer
Printing solid black across the label.
Sounds like a defective printhead.
Reinstall the old one to see if the problem remains or not.
Steve
Jun 25, 2008 | Zebra 105Se Thermal Printer
Zebra 105se blank labels problem
I would say the roller isn't the problem. I had the same problem on many Zebra printers, but often the calibration helped. Then it could do, when printing task label is for larger/longer than the label size is set in the printer system (conflict of software with printer settings after calibration). It could be set too down to bottom in Y axis. Or it could be in the software settings - as action after print - not sure.
Try to open the printer queue while the label is printed and check if the label has proper number of pages or there's 1 page more. If it is the right number - then the problem is on printer side (recalibrate, reflash it). If the number is about 1 higher, the problem is with settings of the label size (barcode software, printer settings) or action after print on PC side.
May 30, 2008 | Zebra 105Se Thermal Printer
Zebra 105 SE Printing Blank Labels
You need the correct driver for the 105Se. The 300 dpi SL driver is not compatible.
Unfortunately, Zebra does not make it's older drivers available online. You will need to locacte someone with the correct driver for whichever version of Windows you are using.
Steve
Feb 13, 2008 | Zebra 105Se Thermal Printer
Zebra 105SE
make sure the ribbon is installed properly. The thermal ribbons are only coated on one side with ink. Make sure the right side is facing the paper. If that is not the issue the thermal head might be bad.
Jun 26, 2007 | Zebra 105Se Thermal Printer
Zebra Z6M Plus Thermal Label Printer Logo
323 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
