My car has worked great till the other day i made it to the end of my street and it just stopped working it never made any noise nothing it just stopped its a ford xf 88 model every one says its probebly a fuel problem it sfuel injected it has a mobiliser on it and every thing is original on it i have been told it might be the emobiliser or its starved for fuel some where or some sort of fuel problem i wouldnt have a clue why it stopped in the first place as it was running great the past month and waS wondering if there was any one at all that can help the car wants to start but it just wont turn over to start it makes the noise for it to try and start but it wont start at all please help any one got any segestions
ok thank you tried it i also just found out its not an 88 model its an 87 model if that helps at all its a ford fairmont 87 modelok thank you tried it i also just found out its not an 88 model its an 87 model if that helps at all its a ford fairmont 87 model
nothin happened it wants to start but no luck as yet every one i know says it might be a fuel problem or fuel pipes or some thing and i cant afford to ahve a mechanic out at the moment to fix it so that makes it harder my fiance and his dad are ttrying to help fix it but no luck as yetnothin happened it wants to start but no luck as yet every one i know says it might be a fuel problem or fuel pipes or some thing and i cant afford to ahve a mechanic out at the moment to fix it so that makes it harder my fiance and his dad are ttrying to help fix it but no luck as yet
well we shall see how it all goes lol i will keep you posted thanks for all your help will keep u up to datewell we shall see how it all goes lol i will keep you posted thanks for all your help will keep u up to date
You can't post conmments that contain an email address.
You can try spraying some engine starter in the airtake while cranking it, if it fires up with that it is probably a fuel system problem, if not it could be something else like electrical, or air.
I am not certain on this, but my guess is that you have a problem with the door closed sensor, which should be attached to the door/ light actuating button. It may be faulty, or just out of adjustment. I assume that you have contacted Samsung about what error code 88 is. Do they have any other input? What doesn't make sense is that the fridge turns off. You would think that if the door sensor read "Open door" it would continuously run, rather than shutting off, unless it is causing an overload, or overheating condition. I have had good luck w/ Samsung tech dept., but they can be a little hard to reach. Hope this helps.
You should have your upper strut mounts and tie rod ends checked out. Many times when your ball joints wear out these parts are not to far behind them and can be in need of replacement. It would be a good idea to have the front end inspected, because the problem could be a safety issue. Some shops will give you a free estimate, in hopes of getting the repair job. I would use a shop that does front end alignment they will often offer better prices, and they tend to specialize in front end repairs. Good luck with it.
If it was your cranshaft making that kind of noise.your motor would have frozen up already.it seems more like a tranny problem than an engine problem. Take it to a good mechanic. It sounds like your tranny is about to go.
This job is VERY HARD and time consuming... don't expect to be done in one day... (rookie) My dad and I did the front end on a Ford Escort 1980. pain in the ***.
Before ordering your ball joints....
check the actual rubber housing of the joints for tears.. (openings).. if NONE then check and make sure nothing from around the brake calipers is rubbing. My Kia Spectra has an obnoxious little metal flap that seems to shift over time... (husband's handy work of trying to change brakes one day made it loose.) So now they rub or kinda squeek...
Also make sure the brake pads/calipers are sitting properly.. if they're loose.. it also causes noises..
Lastly.. check that your tires aren't bottoming out on anything in the whell well or steering etc... turning too harshly can cause the wheel to bottom out against the inside sway bar and stuff...
