Question about GE (PSS26MSRSS) Side by Side Refrigerator
Water supply in door will not dispence water
The refrigerator is about 2 years old and I have had no problems until the last three months. The water supply in the door stopped working. Someone told me to take a hair dryer and heat the plastic tubing behind the crisper (not too hot so as to melt the tubing). I did this and also blew warm air around the back of the freezer door where the water is dispensed. Nothing happened until about 15 minutes later when it started working. It worked for a few days and stopped again. I have tried turning the air off that flows to the crisper area, tried turning the temperature up in both the refrigerator and freezer to no avail. I then heated all the same areas again and within an hour it stared dispensing water again. The third time I just went in and pushed and pulled on the tubing and about 20 minutes later it started working again. This time it worked for about four days. I have even tried moving food around in both sides with no results. I have household appliance insurance American Home Shield and they said that the water supply is not covered. I am extremely disgusted and unless something changes, this will be my last GE appliance!
  • Anonymous Feb 13, 2008
    Water dispenser in door will not dispense water.
  • Anonymous Mar 10, 2008
    Water dispenser satarted working intermittantly then the entire unit stopped. Has power and lights, try to set the temp and it only flashes HRS in the display, the water LED flashes on the dispenser.
I had the same problem, and unscrewed the water filter in the top back right side of the fridge and it was frozen solid........I ran warm water through it till the ice was gone, then the water started flowing again. My side by side continually runs way to cold....I've turned the freezer down to a "2" setting and the fridge down to "1", and it still is running below 32 on the fridge side......sheesh.
Posted on Feb 09, 2008
    Sergeant:
    Champion:
  • 262 Answers
G/e just came out with a heater for this problem i just ordered on the other day i cant remember the part # but call g/e and they can give it to you (the part # )your extended warranty should cover this it isnt a water problem is the ref.and g/e found the problem to late the unit where out in the field although its not a recall they know these units are having problems. i do warranty work every day so I see this as a common problem
Posted on Feb 03, 2008
Hotpoint Aquarius WMA58 (about 16 years old) is leaking, seemingly from under machine (back looks dry), and leaving clothes wet after spin cycle. Door seal seems sound.
no not worth repair at 16 years old
its got issues with aging worn motor
not spinning fast enough
door seal if you can buy one
may not be the water leak fix
time to replace the washing machine
Mar 06, 2017 | Hotpoint Washing Machines
How to resolve our "lack of water" issue..within the last few weeks, the water dispenser's water flow lessen with each day-now it does not just doesn't work
there may be a problem with the water lines or bottles in the fridge compartment is frozen raise the temp in the fridges to about 38 for a couple of days and this should unthaw the lines
Apr 13, 2010 | LG LFX25971ST Bottom Freezer French Door...
Refrigerator about 5 years old. stopped dispensing water twice in last 12 months. Ice and crushed ice works perfectly. No water for last 2 months. Whats up?
You have two points where you can check the dispenser water. At the rear where the water supply comes in is the water inlet valve. If you disconnect the dispenser water line and then see if the water comes out when you try the dispenser. You should hear the valve work when you try the dispenser. If you don’t hear it there is a dispenser actuator switch problem. If you do hear it but water doesn’t work here there is a valve or water supply problem. If it's normal, disconnect it at the bottom of the freezer door and try again.If it's normal here it may be frozen in the door. If this is the case open the door till it thaws. A blanket over the opening will prevent thawing of all the food.
Nov 12, 2009 | GE Profile PSW26P Stainless Steel Side by...
Kenmore Elite 795.7724 - Refrigerator Light Stays on
There is a factory update for this problem. You need a new control board and light parts.
Aug 18, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Whirlpool refrigerator stopped making ice.
If there are ice cubes in the icemaker sitting there waiting to be dumped then the problem is in the icemaker. If the icemaker is dry then you have a water supply problem, even if you have a water in the door working.
1.Check the fill line inside the freezer at the icemaker, if it is clogged with ice then remove this ice and replace the water valve.
2. Check the water supply. Turn the water supply off, disconnect the water line from the Ref, turn the water back on an fill a small glass. If the water supply is good the solenoid on the water valve should be checked. This is done with an OHM meter.
If you got this far and need more info to DIY - ronbuice.com
Dec 13, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
WATER QUIT RUNNING IN DOOR
Okay. My appliance is around four years old. The first time the water quit working was about a year ago (ice cubes / dispenser was fine). I just let it go and didn't worry about it. One day months later, I found it functional again. That lasted about a month or two, then it recently quit again. Tonight, I located the water supply line coupling under the unit on the left side under the freezer door, about five inches from the hinge. I separated the coupling (push lock type) and pressed the water dispenser lever. After a few seconds, the water flowed out just fine. I re-attached the coupling, turned the freezer coldness selector to 0 (off) opened the freezer door and fetched my wife's blow dryer. I ran the dryer along the inside of the freezer door near the black door seal frrom the hinge up to the water/ice dispencer compartment. I also ran it all along the back of the dispenseer compartment to the handle side of the door as I am unsure of where the water line runs. After about ten minutes of this, I attempted to dispense water with no luck. I continued with the blow dryer until the plastic and even the door seal were very warm to the touch. I closed the door and attempted to dispense water once again, and this time it worked. I turned the coldness selector back on. This time I set the freezer to 3 and the fridge to 7. I ran several cups of water through the dispenser since it's been sitting in the line for a while before drinking any. As for the "reservoir," I don't where or if one exists, but heating up the inside of the door from hinge to dispenser worked perfectly. Hope this helps someone!
Cheers!
Nov 26, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Maytag Water Dispenser Problem
If your water supply line is not pinched closed somewhere and the fridge has electricity supplied then it may be the solenoid operated water supply valve that has failed. This electric actuated valve should open when you activate the switch in the door with your glass.
May 03, 2008 | GE (GTS16BBS) Top Freezer Refrigerator
Kenmore Refrigerator stopped dispensing water
Look up through the ice despencer on the front door of the freezer. Is the flapper door open? If so it needs to be fixed. If its not then try leaving the freezer door open for 3+ hours to defrost the frozen line in the door. If that doesnt work, the water valve must be changed.(located behind fridge, take off back cord board panel at bottom, the valve is blue)... GOODLUCK!
Dec 31, 2007 | Refrigerators
GE (PSS26MSRSS) Side by Side Refrigerator Logo
133 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
