Question about Bosch Axxis WTA 3510 Electric Dryer
Auto Selection Knob
The knob spins on the post and will not engage to select a cycle. I had it replaced last year which involved 2 trips from the repair service and the entire circuit board. I am not thrilled with the idea of that again, much less the cost $400. I am tempted to ditch the whole thing and buy a new dryer. There must be defect in the design because I am extremely careful with the knobs and are the solo user. I have called customer service and they have never heard of such a problem. Any ideas
I have the same issue with my Bosch WTA 4400 dryer. What happened was that the knob is weakly designed on the back side and quite a lot of torque is required to turn the selector unit. So, over time the plastic fatigued. Replace program dial and it should be fine.
Posted on Feb 23, 2008
  • 130 Answers
Hello Gigi2deb, well to be honest I haven't heard of this happening either and I have been working on this model since it came out. The issue here is that the cycle selector board sounds like it has moved back. Turn off the power to the dryer, take a putty knife at the lower corner of the facia panel along the outside edge and pry out carefully. Now open the door and if you look up you will see 3 slots, with the putty knife insert there as well and pry out, the panel will lift out at the bottom and you can access the selector.
Posted on Feb 02, 2008
The dryer heats up and spins without issues. The problem seems to be in the dry cycle selection knob, it used to be a bit stiff when turning it to different cycles. Now, it seems very loose and it only...
Try pulling out the knob and turning the post wth your fingers. You will have to caibrate it yourself. If this does not work, You will have to rplace the control board behind the knob.
Sep 19, 2013 | Dryers
Wash cycle dial wont turn...will still push in and pull to start
We have a GE WJRR4170 washer, with the same problem. At first I thought I might have to unscrew the entire control panel just to replace the knob. However, replacing the knob turns out to be easy.
Right behind the knob, holding it in place, is a nylon/plastic retainer clip. If you pull out the knob (into the "start" position), you will get easier access to the retainer clip. You can use a flathead screwdriver to push the clip out. The knob then will slide easily off the metal stem. A GE replacement knob costs $9 or $10, depending on the source.
Shame on GE, but the knob is designed terribly. The part of it that engages the dial has eight, flimsy plastic teeth. At any time, four of these are supposed to engage four little slots in the dial. However, the way the knob is designed, there will be a lot of wear and tear on these plastic teeth, so they'll wear out on every single machine.
Good luck to the many people who will have this problem!
Jul 26, 2009 | GE WJSR4160DWW Top Load Washer
The washer will fill up with water but won't complete the cycle or drain. This has happened before, and I would spin the knob a few times and switch the load size selection. It always randomly started
it sounds like a bad timer there....! if after you selected a different load it drained......!
if it didnt drain at all on any mode I would say a bad lid swtich.
May 27, 2009 | Maytag Washing Machines
GE washer selection knob doesn't engage
The knob it probably stripped. i would replace.
Mar 10, 2009 | Kenmore 24032\24036 Top Load Washer
How to remove the washer cycle selection/start-stop knob on a Whilpool Heavy Duty Thin Twin stacked washer dryer
I believe the selector knob on a Whirpool just has to be turned counter-clockwise with the selector pushed in. It will spin off the shaft and then the outer indicator dial will pull off. The shaft also has a keyed slot that will only allow the dial to be removed and installed one way, so there should be no question as to how it goes back on.
Was there a reason as to why you are removing the washer selector knob? If this is a simple matter of replacing a broken water temperature selector, you shouldn't have to remove any of the control knobs to gain access to the selector. The entire front panel comes off by removing the screws holding it in place. That way you can access the broken selector from behind the front panel much easier. Just remove the panel right above the washer top (under the dryer) and it should expose the front panel mounting screws. Remove these screws and the front panel comes off. Just make sure the unit is unplugged before you begin. I hope this helps you. Let me know if you need further assistance.
Apr 22, 2008 | Whirlpool LTE6234D Top Load Stacked...
Bosch washer spin only
Had a repair man here for the same issue. Learned two things:
1. Too much detergent causes 'soap lock.' The electronics will get confused when there's too many suds left after a rinse and shut the spin cycle down. That's why re-running the entire cycle without more detergent solves the problem. Use less detergent.
2. There is a way to manually get the spin cycle to run using diagnostics codes. Here's what my guy did:
a. Washer selection knob in OFF position.
b. Hold the 'Spin Selection' and 'Delay Start' buttons down at the same time.
c. While holding those two buttons, turn the Washing selector knob to Permanent Press-Cold.
d. Keep the buttons held down until the LCD control panel reads 'P:01'
d. Release buttons.
e. Use the 'Spin Selection' button to cycle thru the codes. Stop when it reads 'P:04' which is the spin cycle.
f. Press 'Start/Pause' button to begin the spin cycle.
I don't know what the other codes do but this should save you from having to run the entire wash cycle.
Hope that helps! Tim
Apr 17, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Bosch Axxis WTA 3510 Electric Dryer Logo
145 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
