Question about Marantz CDR-300 CD Recorder
My CDR-300 just says "no signal" after I put it in record mode
It works fine in play mode, but suddenly says "no signal" when I try to record on it. NOthing I've tried has worked. It did take a brief spill the other day but I can't believe this tiny fall would break the mic, would it? I thought it worked after that and today, nothing.
  • Anonymous May 26, 2008
    mine says the same thing.  I use the internal mic so there is no cable to check.  Last week it gave feed back for an entire recording session.  I turned of the machine and turned it back on, it worked fine, then a day later, nothing but the no signal message.
  • 983 Answers
No signal is may be bcoz of the RF cable is not connected properly or there is some problem with it just try changing it... u will get rid of the problem....
Posted on Feb 06, 2008
6ya staff
SOURCE:
Power failed in middle of a recording session when the machine was in Pause mode. How can I recover the recorded file?
You can try computer software like Nero or Roxio and finalize the disc as it is. This is exactly why I had advised Churches that went from reliable cassette tapes to CDR to put UPS units on the CD recorders as they do not react too well to power outages. If you were using an Open Reel there would be very little loss of the recorded signal.
Mar 24, 2013 | Marantz CDR-300 CD Recorder
Hi,i have connected phono cables from mixer to anolog in on marantz dr4050 and from anolog out on marantz dr4050 to input on amp,there is no sound unless you turn levels to max and then it is very quiet...
So you're saying an unnamed mixer is feeding a potential analog signal to a CDR. You're monitoring the CDR output at an unnamed amp.
You haven't established that there is any signal to BE heard.
WHAT is the actual source sound device (BEFORE the mixer)? Is the source input visible on the CDR when it's in Record Mode?
Have you perused the manuals?
NEVER USE EXCEPTIONALLY HIGH VOLUME SETTINGS FOR TROUBLESHOOTING. If a signal is inaudible at half volume it's effectively not there. YOU WILL BLOW SOMETHING UP WHEN YOU FIND THE MISPLACED CONTROL AND FLIP IT.
Jun 07, 2011 | Audio Players & Recorders
Cdr drawer won't open on Philips cdr 800.
looks like the rotor is jam or broken,try to unscrew it and open the top cover so you can see the rotor and then plug it in to the power source ,then always press the open/close button and check the rotor if its jam or broken and see what happen.
Jun 06, 2010 | Philips CDR800 4-Disc CD Recorder
Problem with analog recording on Yamaha CDR D651
Your assessment that it duplicates CD's internally fits with an analog-only failure mode. Let's make sure the signal is getting past your RCA jacks on the deck...
Put the deck in a Rec/Standby mode and make sure an analog source registers adequate volume on the meters. If it's good there and doesn't change with cable swapping between the input channels, you're right, the problem is internal. Maybe the volume potentiometer itself has developed a dead spot. Manually rotate it throughout its range many times to wipe it clean.
If you have an external optical digital source use it to check the meters in digital recording mode to be sure they're about even. The same knob affects analog and digital levels.
If you have the deck connected via the traditional Tape Monitor circuit in a receiver you should be able to tell by ear if the one channel is dead or too low. This puts all of the recording circuitry including the volume knob in line with your receiver.
May 16, 2009 | Yamaha CDR-D651 2-Disc CD Recorder
Does anyoe know how to record from LP to cd?
Use your tape out, or another line out signal from your preamp.... if possible - OR Sometimes you can pull out some connectors on the back of your amp (a Metal joint kindathing ;), to break signalpath between preamp and poweramp if its an integrated amp -
Use preamp out signal to feed your cdr ( Main purpose is to equalize out, the RIAA correction on a record)
Have you tried to google your question ? Lots of fine guides out there!!!
Jan 14, 2009 | Harman Kardon CDR2 2-Disc CD Recorder
Wrong disc
Some audio cd's work better than others. I have experienced some problems with the Maxell brand so I switched brands. It can be quirky. Sometimes you get a bad lot of discs. I have had no problems since that bad lot of discs.
Mar 05, 2008 | Philips CDR770 CD Recorder
Deck A will not play/Deck B OK
Sounds like the CDR deck has an issue. When the disc comes out has it's position changed i.e has it been spun at all? Can you hear any motors moving? Does it work with any type of disc ( cd/cdr/cdrw)?
Feb 14, 2008 | KLH CDR2000 2-Disc CD Recorder
Can't record through A/V cable
make sure camera has this function first,Easy way to check is to see if top of camera has a record botton where play,ff,rew,stop are..Put camera in VTR mode then hok up cable to tv ..if no signal is comming thru,, check on camera menu for this function..LINE IN
Dec 07, 2007 | Sony Handycam DCR-TRV250 Digital Camcorder
RCA CD recorder/player CDRW120
You sure it's recognizing the CDR? And you are using 'consumer audio' cdr? Watch it at all times. If it 'opc fails' after you put a blank in it still shows as a CDR and 0:00 on the display but won't record. It's easy to miss.
Nov 02, 2007 | RCA CDRW120 2-Disc CD Recorder
Marantz CDR-300 CD Recorder Logo
178 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
