Question about Philips Magnavox 9P6034C 60" Rear Projection Television
Phillips magnavox 60" 9P6040C101
HI, I WAS HOPING SOMEONE COULD HELP ME, AT FIRST WHEN MY TV TURNS ON THE PICTURE ON THE SCREEN IS SMALL AND THEN GETS BIGGER AS THE TV WARMS UP AND THEN WORKS FINE ANY SOLUTIONS WOULD BE GREATLY APPRECIATED THANKS
  • eiafeec May 04, 2008
    I have the same problem, the picture starts out at about half the size and not clear. As it is warming up it will expand and retract, and then finaly after about 3 min. stays big.
    Where can I buy this part? Also at what age should I replace the bulbs?
    Gene
  • Philips Master
  • 3,459 Answers
This site sells kits to fix this problem.
http://www.magnavoxhelp.com
Posted on Jun 20, 2008
    Problem Solver:
  • 17 Answers
Change an ic regulator it has 8 legs,it's located right in front of chassis,thanks.
Posted on May 03, 2008
Smack it
Posted on Feb 03, 2008
We have an older Phillips Magnavox tv. The tv will turn on & we will see the picture for a short time but then the screen turns grey. We still have sound, just no picture. Also, the green power light...
Hello, the grey screen could be due to a missing 220Volt source which feeds the color (RBG cathodes)inside the CRT(picture tube). When this happens the beam current inside the CRT goes high in a matter of second, thus triggering the beam current protection circuit(blinking green light)shutting down the TV. Repairing the secondary voltage source is necessary to get the TV working normal, a good technician should be able to repair it for between 80 to 100 dollars parts included, except a picture tube, which could be also the cause of the problem(K-A shorts).
Nov 06, 2010 | Philips Magnavox 27MS343S 27" TV
PTV835 PICTURE SHRINKS
Hello, I dont have a solution but I am experiencing the same problem. Did your tv get fixed ? Any solutions that you can offer ? Rudy
Jan 13, 2010 | Philips Magnavox 9P6034C 60" Rear...
IC Chip?
Its a common problem with this model. Goto www.TvRepairKits.com to get the parts and instructions to fix the TV.
Sep 06, 2009 | Philips Magnavox 9P6034C 60" Rear...
Picture is going out
it is either ic 7411,7412, 7413 they are cheap replace all three, they are located on the back of the large signal panel right in the middle, very common issue. If you can't solder the repair may cost around 200 or so .
Sep 02, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Picture is small then gets large then gets small again.
Probably a voltage regulator problem. It's not something you can fix yourself unfortunately
Aug 28, 2009 | Philips Magnavox 9P6034C 60" Rear...
No picture
Hi, common problem, have a tech replace IC7412, gl, video-tek
Jul 03, 2009 | Philips 9P5034C 50" Rear Projection...
Magnavox 19" TV shuts itself off.....won't stay on
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Jun 04, 2009 | Philips Magnavox 27MS343S 27" TV
No picture
if it is dropped you most likely would have a cracked ciruit board. you would need a qualified tv repairman to check tv
Jan 14, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Magnavox mptv68a
any magnavox controler will work just put in some good batteries . lots retail wholesale stores like walmart carries magnavox tv remotes but make sure its a magnavox.
Apr 10, 2008 | Philips Magnavox 27MS343S 27" TV
Problems with my 61 inch phillips t.v.,need help a.s.a.p.
Can you explain more about what you mean by big then small? When the picture got small do you mean it shrunk down in size leaving a black screen around the perimeter? Or did it bow in from top bottom? If you van acurately describe what it was doing I may be able to point you into the right direction on diagnosing the problem.
Jan 03, 2008 | Televison & Video
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
101 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
