Question about iRobot Roomba Discovery SE Bagless Robotic Vacuum
IRobot not picking up dirt
The cleaner is moving around the room in the usual manner but not picking up much. The dirt compartment is empty and only dirt i see is on the lower side of the filter. It ran for a hour but did nothing. I cleaned the brushes changed the filter, still same result
  • 4 more comments
  • jimking1327 Feb 06, 2008
    Have the same problem, plenty on the filter but nothing in the dirt compartment, noticed a different whining sound when this started happening, this is the second one in two weeks with the same problem?
  • Anonymous May 25, 2008
    roomba picks up no dirt, makes a whining sound when its running
    - cleaned brushes filter as usual
  • Anonymous Mar 19, 2009
    same problem, any solution....it has a new filter in it
  • kckp Apr 04, 2009
    I have the same exact problem. I'm getting so sick of this Roomba, I've had nothing but problems.
  • Anonymous May 16, 2009
    have the same problem. i put in a new filter and new rollers no change.
  • christina318 May 11, 2010
    Is the main brush turning?
This link fixed my prob :
http://www.robotreviews.com/chat/viewtopic.php?t=10628
and just in case the link doesn't work, basically, you have to take out the whole red brush-head assembly unit by unscrewing the 4 screw screws that hold in down in either corner; then find the side of the unit that has the gearing inputs, and unscrew all the screws until you get inside and clean out all the hair...
That should do it :)
Posted on Nov 29, 2009
  • Robert Nance Dec 02, 2012
    Glad I found you! The inside of that unit was FULL of dust and hair. Thx very much!
  • 281 Answers
Clean the filter and make sure there isn't and dirt clogging it up
Posted on Apr 28, 2009
2 Suggested Answers
  • 3 Answers
SOURCE: IRobot not picking up dirt
I had the exact same problem.
In my cases, cleaning the little yellow things on the end is what fixed it.
This is what I got from irobot:
We apologize for the inconvenience. Here are a few things that you can try to resolve this issue:
1. Remove and empty the Roomba's dust bin.
2. Turn the Roomba on its back, remove the brush guard, and remove the main brush.
3. Reinstall the brush guard and run the Roomba without the main brush or dust bin. Is the flexible brush turning? If yes, go to step 4. If not, please skip to step 9.
4. Inspect the main brush to ensure it is clean and not bent. Verify that the main bristle brush has a larger end cap on each end. When you perform maintenance, you will need to remove the end cap from the brush. When the brush is clean, please return the end cap to its location.
5. Verify that the main brush and flexible brush each have a yellow bearing on one end. If either yellow bearing is missing, your brushes will not turn properly. This can potentially damage the Roomba. Please respond with this information so that we can send you new brush bearings.
6. Inspect the yellow bearings on the two brushes and ensure they turn easily with your fingers. Remove the yellow bearings and clean any dirt accumulated in the bearing cups.
7. Ensure that the brush sockets (on the opposite side of where the bearings fit) are square, and not stripped or worn out in any way.
8. Reinstall the main brush and brush guard on the Roomba. Run the robot without the dust bin. Is the main brush turning? If not, please skip to the bottom to provide the requested information.
9. Remove the flexible brush and reinstall the brush guard.
10. Run the Roomba without the dust bin and listen for the Cleaning Head gearbox running. Do you hear the gears turning? If not, do you hear any noise at all? If the noise from the Cleaning Head sounds abnormal or you cannot hear it, please skip to the bottom to provide us with the requested information.
If you do hear the noise, reassemble your robot and run it again. The issue should be corrected.
** NOTE: Excessive build up of hair in Roomba's brushes and bearings can permanently damage Roomba. Inspect brush bearings regularly.
Title: Cleaning the Main Brushes
URL: http://homesupport.irobot.com/cgi-bin/irobot_homesupport.cfg/php/enduser/std_adp.php?p_faqid=624
If the issue persists, please tell us which brush is not operating properly and also respond with the following information for our verification process:
• Your complete name and shipping address
• Your Roomba's product code. The product code is located under the dust bin near the brush assembly.
• The original date and location that the Roomba was purchased
Title: Where can I find the serial number/product code for my robot?
URL: http://homesupport.irobot.com/cgi-bin/irobot_homesupport.cfg/php/enduser/std_adp.php?p_faqid=274
Posted on May 30, 2009
My Rooma 500 series, when I press the start button to go....it sounds like it wants to move forward and the sings a song and doesn't move
I agree with the previous poster, every time you run Romba, you have to empty out the dirt compartment, take the beater brushes off and pull the hair, lint and thread off the brushes (if you use a cat or dog brush this works fantastically) and remove the lint that's wrapped around the ends of the beater brushes. Every other time, you need to remove the thread and hair wrapped around the rotating brush (sometimes you need to remove the Phillips head screw holding this on and really clean it out). Finally the rolling ball wheel needs to be popped out using a narrow, small screwdriver and all the stuff trapped in there removed.
Feb 23, 2015 | iRobot Roomba 560 Robotic Vacuum
Why My Rroomba 560 collects the dirt and after 2 or 3 circles gives it back on the floor. What is wrong?
Sounds like it's picking up the dirt, running it around the brushes and dumping it back out after one full circuit. I would check to see if anything big is caught in the brushes and preventing dirt from going into the filter compartment. Do you need to empty out the filter compartment and shake out or change the dust filter? If the filter is too clogged, dust won't get pulled into this compartment because there's no air passing through the filter to draw air.
Jun 16, 2014 | iRobot Roomba 560 Robotic Vacuum
I starts and tehn stops and beeps three times. I can start it aain and it will run but then it does the same thing'
TYhe iRobot Roomba has different model designations. Here is a webpage with a list of what the beeps mean in the 400 series. I am thinking that is what you have. 3 beeps means the dirt cup is dirty, filters are dirty, or debris in collecting and it needs to be cleaned.
Here is the webpage: http://uksupport.irobot.com/app/answers/detail/a_id/1047/kw/iRobot%20Roomba%20Discovery%20SE%20Bagless%20Robotic%204200%20series%20Vacuum%20beeps%203%20times/related/1
Hope this helps. If it does, I would appreciate a vote. Thanks,
Handie Andie
Apr 01, 2011 | iRobot Roomba Discovery SE Bagless Robotic...
It starts and for a few seconds and then stops The battery is fine
Is the charging ase turned on and is the dust container emptied? Any obstructions?
Apr 11, 2010 | Roomba Robotic Floor Bagless Vacuum
Can not charge thr battery
bbaker58,
When you press the "clean" button after charging, does the Roomba give you any audible tones? Those tones are the key to understanding failures in the 400 series. See chart below to decode those tones
If you get no tones at all, then either (1) you're not getting power from the battery to the main circuit board or (2) the main circuit board is dead. You really have to open the unit up to figure out which it is. Circuit board replacement is a pretty involved procedure since it requires disassembly of almost the entire robot. If you are brave and want to try it, replacement PCAs are available from places like www.RoboticVacParts.com. They are my favorite shop because they sell parts tha iRobot refuses to sell to consumers and they're prices always beat what iRobot charges.
Roomba Says
What It Means
What You Should Do
Plays 4-note song as Power button blinks RED
Play sound The battery is low and needs recharging
• Connect the robot to the charger or Home Base® and recharge the battery. “Ehh”
Play sound The Cliff Sensors are dirty or malfunctioning
• Pick up your robot and turn it over.*
• Check for any debris that might be caught underneath the front bumper, around the Cliff Sensors.
• Wipe the Sensors with a lint-free cloth or use compressed air to clean them out.
"Uh-oh"
A wheel is stuck or is not touching the ground
• Lift the robot and place it down again.
• Press the Clean button to restart the cycle. “Uh-oh” plus 1 beep
The robot's main brushes are stalled
• Pick up your robot, turn it over* and remove the wire guard.
• Look for something blocking the brushes; you may need to remove and reinstall the brushes to remove the obstruction. “Uh-oh” plus 2 beeps
The robot's Side Brush is stalled
• Pick up your robot and turn it over*
• Check to see if something is wrapped around the Side Brush.
• Remove the Side Brush with a screw driver and check for string or hair wrapped under it.
• Replace the Side Brush, place Roomba in the center of the room and press Clean to resume cleaning. “Uh-oh” plus 3 beeps
The robot's vacuum is stalled
• Remove and empty the Dirt Bin.
• Use a flat-head screwdriver to remove the grill at the back of the Dirt Bin.
• Spin the Vacuum Impeller around, shaking out any debris that may be stuck.
• Replace the grill and the Dirt Bin. “Uh-oh” plus 4 beeps
Play sound
The robot's Drive Wheels are stalled
• Your robot may be stuck, or something may be caught in a wheel.
• If it's stuck, place it in the center of the room and press Clean. It should resume cleaning.
• If it is not stuck, lift the robot, turn it over* and look for something caught in the wheels. Test the wheels by pushing them in and out and making sure they rotate freely. Place robot in the center of the room, press Clean, and it should resume cleaning.
If this continues to happen every time you clean, you may need a software upgrade. Contact iRobot Customer Support.
“Uh-oh” plus 5 beeps
The robot's Cliff Sensors are obstructed
• Wipe the Sensors with a lint-free cloth or use compressed air to clean them out. “Uh-oh” plus 6 beeps
The robot's Wheel Drop Sensors are overloaded (robot is stuck in a bumpy area)
• Pick up your robot, place it in the center of the room, then power it off and then on again.
• Select the cleaning cycle you prefer and let it go to work.
“Uh-oh” plus 9 beeps
The robot's Wheel Drop Sensors have failed at startup
• This failure requires you to contact iRobot Customer Support. Click here to send us an email. “Uh-oh” plus 10 beeps
The robot's bumper is not registering obstacles
• If the robot travels for a long distance without bumping into anything (which would be unusual), it might think it’s stuck and can’t move; press Clean again and it should resume cleaning.
Jun 02, 2009 | Roomba Robotic Floor Bagless Vacuum
try to replace the filter, that should work.
Feb 23, 2009 | iRobot Roomba 530 Robotic Vacuum
IRobot 5800 Scooba Vacuum dirt not going into the fliter basket
You can try rinsing the tank very thoroughly with warm water. Be very sure that you rinse the four ports on the underside of the tank (one round, two oval, one curved like Scooba's filter) very thoroughly, because all the dirt and dirty water moves through those openings and can clog things up.
Fembot
Jan 02, 2009 | iRobot 5800 Scooba Vacuum
iRobot Roomba Discovery SE Bagless Robotic Vacuum Logo
6,971 people viewed this question
Top iRobot Vacuums Experts
Are you an iRobot Vacuum Expert? Answer questions, earn points and help others
