Question about RCA R52WM24 52" HDTV Projection Television
Rca r52wm24 the t.v.'s 3 colors are seperated in a bowl shape. i had a repiar man come out and he said it needed a circuit conv power s-cn(tce 271860) and circuit conv amp-cn(tce 271870) and 259633 connector. so i got these parts from repair shop and replace them but i still have the same problem
  • Anonymous Feb 20, 2008
    I am having the same problem, unit work just pasted it 1 year warranty, the converegence issue has cropped up. I have replaced the center fuse twice so far.
  • Babylooch May 11, 2010
    Mr. Bob,
    I replaced the fusible link F231 and the TV worked for a couple days. Whatever caused it to blow in the first place, must have caused it to blow again. (Both times the TV was relatively cool - only on for about 1/2 hour as opposed to running all day.) Do you know where the convergence IC's are located for this TV? There are only small ICs on the heatsinks (I have seen pictures of 2 X 3" IC's on heatsinks in other TVs (STK-180s). Nothing I can find has a number starting with STK on them. There are 3 boards further back (towards the front of the TV), that I did not pull out. Are they located there?
    Another thing we thought about was just jumping the fuse. It is only a 400ma so we think relatively harmless?? What is the worse that can happen if we bypass the fuse?
    Your advice is apprecaited.
I had the same problem as babylooch. I replaced fusible link FL231 (center fuse by high voltage transformer) and my problem was solved for about two hours. Then it blew again. So I'm gonna try to swoop out the IC's. Does anyone know where they are located in this TV. I have a RCA R52WM24. I don't see anything with STKxxx.
Posted on Feb 29, 2008
  • Hans007 Mar 25, 2008
    So I resoldered the points on the flyback transformer and put a new FL231 in and wouldn't you know. MY PROBLEM IS FIXED! Its been fixed for almost 3 weeks now. Thanks to Willtab for his input. So basically its a very easy fix:
    Find the flyback. Its the big black transformer to the left (bottom lefthand corner of board) of fuse FL231. Resolder the points on that flyback and then put fuse FL231 back in and your problem should be taken care of.
  • 90 Answers
When the convergence goes out - and yours sounds like it's completely gone - usually only the conv ICs need to be replaced. If you start "boarding it", you may lose the eeprom that contains all the memory for your particular set.
Get all the "old" boards and parts back in your possession, put them back into your set, then get the ICs and try just replacing them.
You may need to replace fuses as well. Sometimes the resistors also burn up, but that would be painfully obvious, if it had already happened.
Mr Bob
Posted on Feb 03, 2008
The picture shows all 3 colors seperate from each
Sounds like a problem in your convergence circuit. This is the circuit responsible for making sure all 3 colors align perfectly so that you don't see what you are seeing now. If you have tried adjusting it and that did not work then you will need to have the convergence circuit repaired.
May 24, 2010 | RCA R52WM24 52" HDTV Projection Television
RCA G35831AT
This is a loss of the "pincushion correction" circuit. These sets are known for bad high voltage capacitors in the horizontal circuit that cause a loss of pincushion correction. It could also be loose solder connections in the horizontal circuit. This can be a dangerous circuit to work with. Have a shop check it for you. Thanks for using fixya.
Jan 11, 2010 | RCA G35831AT 35" TV
RCA 61w66 messed up
lost of power supply that power up your conv.
if you tack off the back of tv look at the left of tv you see a red wire come from the flyback
you see 3fuse by the flyback down at the base
of the flyback that is power for the conv,
it could be bad solder, try that to see if that
you fix. hope this worh for you.
Sep 09, 2009 | Panasonic PT-53TW53 53" Rear Projection...
Colors seperating and Screen bowing
The convergence circuit is not working. There are bad solder connections on the sweep board and a small fuse is open. this is not easily done yourself unless you have a technical background but an RCA tech can fix this easily.
Mar 25, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
did you replace the tw0 5 amp pico fuses F9A04 and F9A05 as they usually open when an IC fails
Jan 24, 2009 | Mitsubishi WS-55805 55" Rear Projection...
Rca hctv
Good Day;
I would suspect the fuse near the IHVT, conv. power board or conv board itself. check voltages going to the convergence board. Good Luck, big IRISH.
Nov 15, 2008 | RCA HD52W59 HDTV Projection Television
Tv out of convergance 300 volts going in 271860 nothing comeing out
convergence out..... repaired 27860 what repaired. do you have the convergence option in setup.. is the piture completely without convergence/
Jul 03, 2008 | RCA HD52W59 HDTV Projection Television
No menu option is a clue to your problem. No menu option for convergence is due to the Micro not seeing a active convergence module in the unit. This is a post check, when the unit is turned on, and on some units, only done at AC power up.
With that in mind, you need to check your (PW=power) pcb for the conv module. This is easy to find, but on most RCA is located on the plastic panel that is in front of the CRTs. On this model, you should see PW conv PCB on left and Conv PCB on right. Top left corner is a plug with two wires, BP611, (i think) which should have like 300v DC. If you dont have the B+ go to the Primary power supply. More then likely you will have it.
If your 300v is there, order the PW conv module. NOTE: most of these modules are rebuild only and cost about 70.00 to rebuild at PTS. Other wise, you can trouble shoot at board level.
JTV repair.
May 26, 2008 | RCA HD52W66 Projection Television
Convergence Problem
the 271860 is a convergence power supply IC. Exactly what was your problem, and could you please include the chassis number from your set, as rca has to be diagnosed by chassis number.
Mar 14, 2008 | RCA HD52W59 HDTV Projection Television
Two boards govern this circuit . 1) convergence power supply board # 271860 2) convergence amplifer # 271861 . In most cases amp board is your problem . You might want to check the amp board for loose connections on it .Most of the times its the cable sockets on the borad have loose pins . This the board that has the metal heat sinks in a row of about nine of them on the board . Good luck
Mar 11, 2008 | RCA HD52W59 HDTV Projection Television
RCA R52WM24 52" HDTV Projection Television Logo
137 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
