Question about Hitachi Deskstar 7K80 Hard Disk 80GB, 7200RPM, ATA-6, 2MB Cache, Desktop, 20PACK (HDS728080PLAT200A3021020PK) Hard Drive
Sticking? When turning power on the external HD keeps making a constant pulsing sound. it does not load up? The HD is full and i wanting to save data on it? or at least transfer. Is the HDrepairable without losing data?
  • peterdr1953 Feb 03, 2008
    yes will try anything once/ If only could get a list of what files I have lost woul be useful
    Brigadier General:
  • 6,966 Answers
Most hard drives (whether external or internal) that produces a "constant pulsing sound" indicates a mechanical problem. Often this is the head arm trying to move from its position but failing to do so. What you are hearing as pulses are when it slaps back to its park position.
Should this be the case, am afraid that the HD is a goner. The normal course of action is to replace. If the data inside are mission critical, your only course of action is to avail of those data recovery by firm specializing in such but they are rather expensive.
Trying to use "data recovery software" might prove to be futile since as earlier stated, the problem is mechanical in nature.
You can of course still give it a try.
Should you feel adventurous, would be willing to experiment and gamble, pls post back as I may have not a permanent solution but a "down & dirty" trick of making it run long enough hopefully to get some of your data back. Again, this is a "hit or miss" and should only be considered if all else fails and you really want to get your files back.
Hope this be of some help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Posted on Feb 03, 2008
  • Louie  Role
    Louie Role Feb 04, 2008
    Hello again Peter,
    Gambling in this instance is either "you get what you want or you loose everything"... having said that, pls:
    1. physically remove the HD from its external enclosure exposing and thereafter removing the cable connector (SATA or IDE) and the 4-wire power connector. You may need to pry it since some manufacturers use a glue of some sort to lock it in place;
    2. place the HD in question in a zip lock plastic bag (used in sandwiches). Try to get as much air as possible out of the plastic bag. Freeze the plastic bag with the HD inside overnight (the fridge's freezer would do just fine);
    3. on the following day, sans the HD, power up the PC, let it boot and run your Windows normally; Open "My Computer" and click on your C drive, create a new folder "whatever", once created, open and leave it so. Open another instance of "My Computer", let it be for the time being;
    4. Remove frozen HD from freezer and from the plastic bag. Rather quickly, connect the attachments/connectors in place to the HD and plug in the USB to the PC (of course power must be applied to the external HD);
    5. Wait for the HD to be recognized by the PC and shows in the 2nd "My Computer". Once shown, right click to "Open" and do the normal copy/paste not cut/paste. You have to do this quickly since soon as the HD reaches room temp, chances are the HD will be back to the "slapping" mode;
    6. If the partition is gone or if the PC says the HD is "unformatted", you need to be running a recovery software such as "GetDataBack" which of course would be better if you have downloaded, installed earlier and be running when you hook up the defective HD.
    7. The above steps (except # 6) could be repeated as many times as you want if you are successful in the first try.
    I hope you success... Pls post back any developments.
    Cheers.
I want to restore my computer to factory settings
Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer) or
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
hope this helps
Aug 02, 2011 | IBM USB Portable Diskette Floppy Drive for...
How to reset my motherboard - dg35ec intel
click start all programs accessories scroll to system tools from there you should see a system restore click next a sytem date should open up select the date you want to restore your computer to or if you want a full factory restore or
Hope this helps
Apr 26, 2011 | Intel DG35EC Motherboard
I want extend my partition c
If you want to keep the data on that drive, you will need to use a software program like partition magic or similar... otherwise, you can reformat the drive to whatever size (within the confines of the max cap of the drive) you want.
Dec 29, 2009 | 01 Communique Communicate! I2000 Full...
I have an HP765 pavilion with a burnt out power supply. I have alot of information on the hard drive. What specific parts would I need to remove and what are my possible choices for data transfer besides...
If you are certain that it is only your power supply, you should be able to replace the power supply and the Pavilion should work again.
On the other hand, you can hook the hard drive up to another functioning desktop PC, use the jumpers on the hard disk and make it a slave drive, so that it will not conflict with the HD that boots the computer.
Once it boots up, try to access the slave drive and, if you have room on the primary drive, copy your valuable data to your C drive. If you don't have the room, if you can burn DVDs or CDs, then copy the data and burn it to a series of DVDs or CDs, but it will take a load of CDs.
Then there is the option of - still as a slave drive - buying a 64 GB jump drive, or an external HD with a load of space, like an IOMEGA with a Terrabyte of space, and copying the valuable data from the slave drive to the Huge External HD, over a USB cable.
Clearly, USB will be a slow process, but it is a solid connection, and safe, and should allow you to copy and save all your valuable data to the external HD which gives you the additional option of being able to attach it to anything else with a USB connector, making all that valuable data portable.
When done, you just remove that slave drive, and put the desktop back to the way it was.
-a.
Dec 18, 2009 | HP Computers & Internet
Weird clicking sounds
Clicking sound on an external hard drive is an indication that it's quiting to work. You mentioned that it's just stopped working, you may need to check the Disk Management of your computer to see if you could still reformat it. To do this, please follow the steps below:
FOR WINDOWS XP AND VISTA:
1. Make sure that the HD is properly connected to the computer.
2. Right-click 'My Computer' or 'Computer' folder and then go to "Manage".
3. Locate and click Disk Management.
4. Then, take note of the drive letters that will appear on the screen.
5. While the Disk Management window is opened, unplug the HD and check which drive letter will disappear.
6. If a drive letter disappears, then that is your external 250GB HD. You may reformat it to make it work again.
NOTE: Reformatting the HD will erase all the files saved in it. You may want to bring your HD in any data recovery center to retrieve the important files. If the HD didn't show up under your Disk Management, then there's nothing that we could do but to bring your HD in to the Data Recovery to save the files.
FOR MACINTOSH OSX:
1. Connect your HD to the computer.
2. Click 'Go' (located near the Apple icon, Finder, File, Edit and View).
3. Select Utilities and then click the Disk Utility Icon.
4. Take note the drive letters and then unplug the HD.
If a drive letter disappears, that's your HD. If nothing disappears, then the computer no longer detecting the HD.
Jun 01, 2009 | Iomega (33215) 250 GB Hard Drive
Could not recognize and no spin
I hate to be the bearer of bad news but from the sound of it you can't. At least not cheaply. The drive must be rebuilt to save the data. Your only option is to bring the drive to a HDD Recovery service for a Clean Lab Recovery. Expect to spend 600-1000.
Sorry Again :-(
Apr 28, 2009 | Computers & Internet
Maxtor 3200 external hd not working
I would attempt to connect the drive after the system has booted up. If the external drive is found and accessible copy the data to another drive. If the external refuses to be recognized, allow the drive to cool completely 2-3 hrs, place the unit in a freezer for 2-3 hrs and then try the procedure again. Often times when the drive units or platters within the HD begin to fail you get symptoms as you have described. Super cooling the drive sometimes allows you to remove the data. If not and the data contained within the drive is valuable to you there are software solutions as well as companies that specialize in the data recovery field.
Apr 25, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
I dont not wy i can't play
many games load data on to the hdd to keep load time down. If your hard drive is full you can upgrade to a lager unit or erase the data you no longer need. btw all ps3 use a 2.5" sata hd with a 5400rpm speed. You can put in a 500gb if you wanted. You would need to back up all your data first. you can also setup the ps3 to use a external hard drive for storage.
Feb 16, 2009 | Sony Playstation 3 (PS3) Console
My hitachi makes a clicking sound
i'm afraid if you would have damaged the cylinders inside...
if yours hd is under warranty you can try it with a computer repairman...else if would cost you more of the secure recovery of the data in the hd..
thankyou
Aug 31, 2008 | Hitachi 200GB External USB 2.0 Hard Drive
Icon missing on desktop
It sounds like your external hard drive is physically damaged. Just like an engine in a car, the drive is constantly running, anywhere from 4200 to 7200rpm. When you hear the drive making " sounds ", outside of when you power it up, you should only hear a whir of some sort, and possibly the sound of it writing or reading. You may need data recovery software or services.
Sep 06, 2007 | FireLite (USBFLB80) Hard Drive
Computers & Internet Logo
154 people viewed this question
Top Hitachi Computers & Internet Experts
Alun Cox
Marvin
Marvin
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
