Question about Kyocera FS-3900DN Laser Printer
150 ERRO CODE
I know what the 0150 error code is how do i reinstall or up grade the system software with a CF card. also were do i find the latest system software?
  • timelock Feb 02, 2008
    thanks but i need info. on how to install it. Thanks for the software.
    Genius:
  • 3,422 Answers
Click here to download the software i hope u know how to install it..
if u have any problems please ask me..
Goodluck,
Please don't forget to rate me as fixya..
Posted on Feb 02, 2008
When i start up my dell laptop it says disk erro so i preesed diagnose and it said error code 2000-0146 how can i fix this?
Two possible causes
  • Hard drive itself is bad (If this is the case you will need to replace the hard drive and reinstall the OS and any software)
  • You have a nasty bootsector virus (Format the drive and reinstall the operating system and any software)
Try to format and reinstall the operating system and if it works great if not then you know the hard drive needs to be replaced.
Comment back if you need more help.
Sep 02, 2011 | Dell Inspiron 1521 Notebook
Hi, have just had to reinstall all software and games onto my daughters R4i as had a system date error... now can't play games as has error code 1, please reset system!
Hello.
You can fix it by formatting your SD card and then reinstalling the latest and make sure it is the compatible kernel for your R4i card.
Tip: If ever you will get an error about your date again, just adjust the date to a few years earlier and that should fix it.
Aug 16, 2011 | Nintendo DSi White Console
I'm getting error code 2037 since 2 days when I try to buy something on Itunes. Credit card works fine. Would like problem to be solved asap.
You may need to update your iTunes, or reinstall, make sure you have the latest software, if that does not work, go online to www.apple.com to talk to someone just to make sure nothing is going wrong on their end. It could also be your account, make sure you credit card information is up to date. It will also help knowing what that error code means, so if you do have to contact apple have that error code handy.
Dec 12, 2010 | Apple iTunes
My Kodak Esp 5 want scan and I received a error message after trying to scan
is this the error message you recieved 1-2000 or tricode code for example 235x892. please verify what error message you recieved. Now if your recieved an erro mesage numbers you may need to reinstall the software of your printer. please download the latest software and drivers of your printer at kodak.com/go/downloads
Nov 21, 2009 | Kodak ESP 5 Printer
My Kyocera fs-3900dn has the message: call service 0150:0040557. What does it mean?
0150 - Engine PWB EEPROM error. Detecting engine PWB EEPROM communication error.
Solutions:
1. Switch the printer OFF; unplug the power cable; wait 20 seconds; plug in the power cable; switch the power ON, If the error comes back follow the next solutions:
2. Update / Burn the latest firmware version. You may need to call a Kyocera Service Provider because you need a CF card (compact flash memory card) and the FIRMWARE.
3. Replace the Engine PWB (a board) - again you have to call a Kyocera Service Provider.
Dec 30, 2008 | Kyocera FS-3900DN Laser Printer
Trying to upload my photos from Kodac Camera
esapp is from Kodak EasyShare software and so may be an uninstall and reinstall or reinstall of the most up to date software for the camera would help. Which programs produce the other errors? What do you do to get message to display?
Jun 21, 2008 | HP Compaq Presario v3000z Notebook
FS-3900DN Error 0150:0000000
This error suggests eprom error the system firmware will need to but upgraded or reinstalled.
If it is new contact the store you purchased it from and tell them. If not contact Kyocera online and they will (or Should give you a dealer in your area)
Thanks J
Jan 02, 2008 | Kyocera FS-3900DN Laser Printer
Error 50
The "E50" error code indicates formatting a CF card has failed. Solution To clear the "E50" error, try performing the following procedure. 1. Try using another CF card. If you have another CF card, try loading it in the camera. If the error code is not displayed when the other CF card is loaded, there may be something wrong with the first one rather than with the camera. 2. Use your computer's ScanDisk utility to check the CF card for errors. Use ScanDisk to check the CF card for card error or card failure. Refer to the instruction manual for your operating system or Windows Help for further instructions. (If you are using a Macintosh, use the "Disk First Aid" program to check for card error or card failure. Refer to the instruction manual for your Macintosh OS for further information.) Be sure to back up the data on the CF card on the computer before you check the CF card. If a card error or card failure occurs when you use your computer's ScanDisk, there is something wrong with the CF card. Follow ScanDisk's on-screen instructions to solve the problem.
Aug 31, 2005 | Canon PowerShot S1 IS Digital Camera
Error 30
The "E30" error code is displayed when reading/writing data on a CF card has failed. Especially, the error code "E30" may appears when you tried to remove a CF card while the camera was processing data. Solution To clear the "E30" error, try performing the following procedure. 1. Try using another CF card. If you have another CF card, try loading it in the camera. If the error code is not displayed when the other CF card is loaded, there may be something wrong with the first one rather than with the camera. 2. Use your computer's ScanDisk utility to check the CF card for errors. Use ScanDisk to check the CF card for card error or card failure. Refer to the instruction manual for your operating system or Windows Help for further instructions. (If you are using a Macintosh, use the "Disk First Aid" program to check for card error or card failure. Refer to the instruction manual for your Macintosh OS for further information.) Be sure to back up the data on the CF card on the computer before you check the CF card. If a card error or card failure occurs when you use your computer's ScanDisk, there is something wrong with the CF card. Follow ScanDisk's on-screen instructions to solve the problem. 3. Format the CF card with your camera Try to format the CF card with your camera. Please refer to the "Camera User Guide" for your camera for instructions on formatting CF cards. Also, please note that formatting a CF card will erase all data on the card. Once the CF card is formatted, follow the procedure described in step 2 above and use your computer's ScanDisk on your computer to check the CF card for errors. If a card error or card failure occurs when you are using computer's ScanDisk, there is something wrong with the CF card.
Aug 29, 2005 | Canon PowerShot A310 Digital Camera
Memory card error - E50
Error Code "E50" (CF card formatting error) When a camera error occurs, an error code like "Exx" will be displayed, where the x's represent numbers. The "E50" error code indicates formatting a CF card has failed. Solution To clear the "E50" error, try performing the following procedure. 1. Try using another CF card. If you have another CF card, try loading it in the camera. If the error code is not displayed when the other CF card is loaded, there may be something wrong with the first one rather than with the camera. 2. Use your computer's ScanDisk utility to check the CF card for errors. Use ScanDisk to check the CF card for card error or card failure. Refer to the instruction manual for your operating system or Windows Help for further instructions. (If you are using a Macintosh, use the "Disk First Aid" program to check for card error or card failure. Refer to the instruction manual for your Macintosh OS for further information.) Be sure to back up the data on the CF card on the computer before you check the CF card. If a card error or card failure occurs when you use your computer's ScanDisk, there is something wrong with the CF card. Follow ScanDisk's on-screen instructions to solve the problem. If the same error occurs when you are using the CF card supplied with the camera, please contact the retailer where you purchased the camera or the nearest Canon service center. If the error code is displayed right after you took a picture, the image may not have been recorded. Switch the camera to playback mode to check if it was recorded. Precautions for handling a CF card: - Do not remove a CF card or disconnect the camera's power source while the camera is recording, loading, or erasing data on a CF card. - CF cards are high-precision electronic devices. Do not bend, force, or subject them to shocks or vibration. - Do not attempt to disassemble or alter a CF card. - Place the CF card in the supplied case for storage. - Moving a CF card rapidly between temperature extremes may cause condensation in the card, leading to potential malfunctions. To avoid condensation, place the CF card in a sealed plastic bag before moving it into a different temperature area and allow it to adjust slowly to the new temperature. If condensation forms on the CF card, put it aside until the water droplets have evaporated completely. - Do not use or store CF cards in the locations subject to dust or sand, high humidity, or high temperatures.
Aug 11, 2005 | Canon PowerShot A85 Digital Camera
Kyocera FS-3900DN Laser Printer Logo
161 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Chris Schutte
Marvin
Marvin
Adorjani Laszlo
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
