Question about Faema FA60081
Innova Dream espresso machine
Hi! My espresso machine turns on but it doesn't heat up or build up pressure. I heard a rumor that there is a reset button on the top inside, so I took off the top, but after about 20 minutes of searching, I never found anything that resembled any kind of button. Does anyone know how I can find this? thanks a lot
  • Anonymous May 26, 2008
    Exactly the same symptoms!
I think it is more likely that your element is broken. That has happened to us twice.
Posted on Sep 15, 2008
Won't turn on
Hi Sab, you need to replace the thermal fuse on the ascaso dream. Ascaso dream safety fuse
Mar 17, 2014 | Ascaso Dream Espresso Machine
Rancilio Epoca DE 2 group espresso machine
Seems to be a problem with either the elctronics sensors, or the "brain" itself. Did you get the machine serviced by an authorised service center, or a local repair guy?
Jun 28, 2008 | Rancilio Silvia Espresso Machine
Ascaso Dream steam wand leak
Hi Emily,
You have 2 issues.
Steam wand leaking while making coffee - This indicates that the seals on the steam tap o rings need replacing.
Coffee pouring over the handle when making coffee - this indicates that the group gasket needs replacing.
Replacing the group gasket is easy takes 10 min
Replacing the o rings on the steam tap may take a little longer..
All you need is a group service kit Ascaso gasket kit Dream Arc Basic
Feb 28, 2012 | Ascaso Dream Espresso Machine
Hi. Could be pressure switch or vaccum valve. To check If the vaccum valve is faulty, try leaving the steam taps open while it is heating up. If it heats up normaly like it supose to than you vaccum valve is stuck. Shouldn't take too long. If it doesn't heat up fast but still heats then that could be element. If it doesn't heat then your pressure switch is faulty. Dazza
Sep 23, 2011 | Espresso RMI La Cimbali Espresso Machine
Hi Jah510,
My espresso machine turns on but it doesn't heat up..
You may need to replace the ascaso boiler element, if machine is between 3-6 years old then it probably is the element.There are a few of these, you just need the the manu date under the machine. Dream Arc Basic Ellipse 150 Products
Apr 04, 2017 | Ascaso Dream Espresso Machine
Old 1996 nuova simonelli mac digit no pressure or heat
There is a reset thermostat on the right side of the machine above the element, check to see if it tripped. If it did make sure there is enough water in the machine and when turning it on, open one of the steam valves and turn off the cup warmer. Leave the steam wand open until it hisses or small amounts of steam or air will vent out.
Feb 11, 2009 | Nuova Simonelli Mac 2000 Espresso Machine
Overheating ascaso dream, and too much steam
You need to descale the machine and replace the group spring valve. It is available in a kit . Ascaso Dream gasket kit versitale version There are a number ok kits for different machnes
Jan 02, 2009 | Ascaso Dream Espresso Machine
Ascaso, Innova, Dream Heater not working
If you are confident that your heating element is dead and are filling adventurous enough to replace it- you can get one at:
I saved myself shipping and repair costs by having it replaced by a friend. He took pictures and marked wires & connectors before removing the broken heater.
Yeah,, this looks to be systematic failure with this machine. Very disappointing- for this kind of money, one would expect the machine to work a bit longer after warranty expires.
Oct 18, 2008 | Ascaso Dream Espresso Machine
Coffee Makers & Espresso Machines Logo
252 people viewed this question
Top Faema Coffee Makers & Espresso Machines Experts
Kelley Hopper
Are you a Faema Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
