I just bought a 20" widescreen monitor for Christmas from my local Office Max. No manual inside the box so I have NO Idea what all the litle buttons on the menu are for! Also...this thing DOES have a built in speaker, doens't it? No sound.... Everything is plugged in correctly, I'm using it. No plug in's not being used except for the spare USB on the monitor bottom??? Help~!
How is ur sound output from the computer box is conencted....is there an external speaker thru which u listen sound ?
if so that cable from the sound output slot on the PC need to shift to the monitor speakers thru some cable that goes into the monitor from the CPU box....
you need to plug a 3.5mm jack to 3.5mm jack audio lead between the pc and monitor to get sound, the reason it doesnt come with a sound driver is because you dont need one for the monitor
It is definetly a widescreen the issue is either with your display card or your resolution setting you need to check both. If you would have told me wether your display is through mother board or scsi card the model of mother board or the display card then i could fix the issue easilly.
Part Number:RK284AA#ABA * Display Type LCD display / TFT active matrix * Built-in Devices Microphone , Speakers * Width 20.6 in * Depth 11.4 in * Height 18.9 in * Weight 19.8 lbs * Enclosure Color ( The image of the product displayed may be of a different color ) * Localization English / United States * Display (projector) image aspect ratio 16:10 * Image Contrast Ratio 1000:1 * Diagonal Size 20 in - Widescreen * Dot Pitch / Pixel Pitch 0.282 mm * Max Resolution 1680 x 1050 / 60 Hz * Max Sync Rate (V x H) 76 Hz x 82 KHz * On-Screen Controls Switch video input , Brightness , Contrast , Image control , Color adjustment , Quick view , Language , Management , Information , Factory reset , Exit * Controls / Adjustments Tilt * Tilt Angle 30 * Signal Input VGA * Digital Video Standard Digital Visual Interface (DVI) * Type Microphone|Speakers * Interfaces 1 x VGA - 15 pin HD D-Sub (HD-15) * Connections - DVI-Digitaligital , - VGA * Microsoft Certifications Compatible with Windows 7 * Form Factor Internal * Voltage Required AC 120/230 V * Power Consumption Operational 65 Watt * Power Consumption Stand by / Sleep 2 Watt * Min operating temperature 41 °F * Max operating temperature 95 °F * Operating humidity range 20 - 80% * Service & Support Limited warranty * EPA Energy Star Compliant Yes * EPEAT Compliant EPEAT Silver
