Question about JVC DR-MX1S DVD Recorder/VCR
JVC DR-MX1S We have been having problems with the above machine, it will not play or record, when we try to select navigate it just starts loading then shuts down.
  • Ralph R Apr 28, 2008
    I have the same problem on the Hard Disk Drive. Funnily enough it runs playlists ok from the HDD but won't access the programmes that the playlists draw on.
    Curiously if I go into Navigation & then select NAME at the bottom, I can view all of the titles on there as thumbnails, complete with sound!
    I've been having a look round the net and have found a number of links describing what is essetially the same problem across a plethora of JVC models, though it appears to have affected the dvd drive in a number of cases.
    On the following link (which runs to 18 pages on a forum site) they reckon its down to the capacitors on the circuit boards not being able to handle the heat generated by the unit itself.
    http://forum.videohelp.com/topic255081.h...
    The following also relate:
    http://www.amazon.com/review/product/B00...
    http://www.ciao.co.uk/JVC_DR_MX1S__67103...
    Interestingly enough JVC America acknowledged this as a known fault on a number of models:
    http://support.jvc.com/consumer/support/...
    My DVD recorder has experienced green or white noise in the picture display followed by the word Loading flashing continuously on the front panel. Unplugging the unit clears the "Loading" indication and restores normal operation. How can I prevent these symptoms from re-occurring?
    Models: DR-MV1S, DR-M10S, DR-MH30S, DRMX1S, SR-MV30U
    A limited number of units of certain models of DVD recorders (Models-DR-MV1S, DR-M10S, DR-MH30S, DRMX1S, SR-MV30U) have experienced the symptoms described. While manually resetting the unit, as set forth in the question, restores normal operation, the symptoms may reappear. JVC has identified the cause of these symptoms and will make the necessary adjustments to affected units to eliminate the likelihood that the symptoms reappear. Adjustments will be made free of charge at JVC Factory Service Centers. If the Factory Service Center technician determines that the symptoms are unrelated to the adjustment, you will be sent an estimate of repair charges which you can either accept or decline. Click the Factory Service Center link at top left of this page to obtain your nearest location. Please call 1-800-252-5722 and select option 4-3 if you have any questions regarding this process.
    I've e-mailed JVC UK about this and they say it will be a chargeable repair from the nearest service centre. uriously the forum suggests JVC America repaired out of warranty machines for free too.
    Just hoping it is the capacitors & I don't lose the content of the HD disk.
    But I shall be challenging them on the chargeable repair.
    Ralph
I have the JVC DR-MX1S DVD Recorder / VCR Combo. Recently, after connecting to my new ONKYO 706 receiver, the VCR doesn't seem to work. I can put tapes in and they appear to be rolling, but I don't get any video or audio. I have the Receiver set to the device that I have the component cables connected to in the back. Any ideas. I can see and hear media from the HDD and from the DVD... just nothing from the VCR.
Posted on Dec 13, 2008
This machine has a lot of problems. One thing that often works is to turn it off and unplug it for a couple of minutes. Then plug it in again. Then it will say "loading" for quite a while. Leave it alone until it turns itself on. Then it should be okay. If the couple of minutes doesn't work, sometimes unplugged overnight (same method) works, but then you have to reset everything.
Posted on Feb 20, 2008
  • subgenre Feb 20, 2008
    Whoops ... I meant to type "Leave it alone until it turns itself OFF. Then it should be okay.
Hi I am trying to dub from a VHS tape to a DVD+RW disc and I get an error message "CAN NOT DUB WITH THIS DISC" I have tryed different disc and different brands and I still get the error message?...
a while ago many vhs tapes had a protection sceme to prevent copying, i forget the namee right now, "something" vision" i think. it may be the vhs and not dvd disc.
Jan 14, 2011 | JVC DR-MX1 DVD Recorder/VCR
Unable to do anything!!!
In what state is the unit? Is everything else functioning asides from what you posted?
Feb 02, 2008 | JVC DR-MX1S DVD Recorder/VCR
JVC DR-MX1S
It's likely to be an incompatible signal. You have PAL (UK) and NTSC (Belgium), the DVDR/VCR combo may not be compatible with PAL causing it to seem like it's not receiving any signal, when in fact it is - but not in a recognisable format. You may try and get an NTSC to PAL signal converter like this: http://cgi.ebay.co.uk/NEW-TV-AV-Video-System-NTSC-To-PAL-Converter-Converor_W0QQitemZ270163920912QQihZ017QQcategoryZ32837QQtcZphotoQQssPageNameZWDVWQQrdZ1QQcmdZViewItem That'll solve your problem.
Sep 09, 2007 | JVC DR-MX1S DVD Recorder/VCR
Does nothing when plugged in says it is loading and it doesn't
hello,
since your dvd keeps saying itis loading and it is not.
that simply means the lens of the dvd is already weak.
try cleaning it with a lens cleaner,
or better still you can replace the lens.
take care
May 27, 2010 | JVC DR-MX1S DVD Recorder/VCR
Firmware crashed, unable to get repair in UK
I also have a faulty unit with discs that hadn't yet been finalised. You can access the discs via your PC. I used a program called IsoBuster by Smart Projects. There is a free demo which you can download. Just google it.
As for the faulty power supply, just scrap the unit and DON'T buy JVC again. Eventually, they will have to listen to the economies of scale.........
Sep 18, 2009 | JVC DR-MX1S DVD Recorder/VCR
I plug it in to mains and all that happens is a white light comes on on front panel it also flickers every now and again?
You almost certainly have problems with the power supply board which fails fairly often in these machines. They are available for around 80 euros, trouble is that having bought one it is not uncommon to plug it in only to find you have another problem. Your best bet is to take it to a big JVC service centre where they will have the spares to try substitute components without you having to buy them first!
May 18, 2009 | JVC DR-MX1S DVD Recorder/VCR
I recorded a dvd and it will not play in any other player.
You must finalize the DVD after recording it. If you post the model of the JVC device, I may be able to find out how to do this for you.
Jan 12, 2009 | JVC DR-MX1S DVD Recorder/VCR
New DVD recorder won't play DVD
We have the same problem fiber optic unit need to be replace and cost more that what I pay for my machine thats that TRASH!!
Sep 10, 2008 | JVC DR-MV7S DVD Recorder/VCR
JVC DR=MX1
this happened to mine - could be that it is getting too hot (mine is in a cabinet) - turning the machine off (by unplugging the plug, not putting on standby) and letting it cool down seems to work.
However, the dvd has now stopped working (not related to the above problem) - hence me looking
Jan 13, 2008 | JVC DR-MX1 DVD Recorder/VCR
JVC DR-M100S
I have a JVC DR-MH50 DVD/HD recorder and it will only record on DVD-R or DVD-RW not DVD+R or +RW. so check your format of disk you are trying to record on it may be as simple as that.
Sep 04, 2006 | JVC DR-M100S
JVC DR-MX1S DVD Recorder/VCR Logo
449 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
