Problem with a Quasar Video-Viewer
We moved a Quasar Video Viewer VV 8220 from a summer house where it was connected to cable TV to our home, where we get satisfactory reception on other TVs by using a simple rabbit ear antenna. The TV can be turned on and off by using the manual power button. However it will show only channel 5, as the channels do not change when the manual channel change buttons are used. Furthermore, I was not able to achieve interaction with a remote control unit. I should also mention that the VHS drive chews up tapes and can no longer be used. What can I try to do to overcome this problem? Thanking you for your advice, J P Flatt
    Genius:
  • 1,067 Answers
I would buy new remote i can set u up with link if u like
Posted on Feb 02, 2008
  • 1 more comment
  • Anonymous Feb 02, 2008
    remotewarehouse.com enter yuor model in they have it
  • Frank Mallon
    Frank Mallon May 16, 2018
    guess I need a remote which I do not have!
  • Frank Mallon
    Great thanks Nick
6ya staff
SOURCE:
Quasar tv/vcr combo
A converter box is not needed to connect a DVD player to a TV. However, you do need a single cable with red, white, and yellow adapters orconnecterson one end and at least yellow and white on the other end. Ok if you have red; just don't worry if there isn't a hole to plug into.
Feb 11, 2012 | Quasar VV-1302 13 in. TV/VCR Combo
Need a remot for tv/vcr tv
  • Hi, i can help.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Sep 24, 2011 | Quasar VV-2002 20 in. TV/VCR Combo
I would like to connect a DVD player to my Quasar TV/VCR combo. No clue.....
Look in the back or the front of ur tv have a (Video Audio holes In).Look in ur DVD player in the back or the front have a (video Audio holes Out).Used a component AV video cable hook both devices together.Find the Video Mode in ur tv 1 or 2,now play the DVD player with a dvd disc.Now u should be playing the content of the dvd disc.If u don't have a AV video cable,tries websites like Amazon.com,Ebay.com to buy a set of AV video cable.
Dec 10, 2010 | Quasar VV-1302 13 in. TV/VCR Combo
Connection for cable
A snowy picture is usually an indication of a bad ground. Check the cables at both ends to be sure that the braid(shield) is still intact and connected to the F-connector. Also, check the connections on the exterior of the house. You can also call the cable company and have them check the connections at the poles.
Dan
May 10, 2010 | Quasar VV-2002 20 in. TV/VCR Combo
I need a manual for a Quasar VV-1305 TV. I
I have a quasar model vv1305 t v -vcr combo. the vcr loads and ejects the tape, but when you try to play or rewind it prints on the screen vcr lock activated . need help
Apr 11, 2010 | Televison & Video
Quasar VV-1302: Cannot Program Cable Channels
If you let it autoprogram and all you get is channel 103. Move the TV back to the old connection and see if it autoprograms all the channels there. If that works ok then you have a problem with the cabe line that only has channel 103.
Nov 17, 2009 | Quasar VV-1302 13 in. TV/VCR Combo
Quasar VV-1302 13in TV/VCR unit. Remote stopped working
Test your remote by placing it in front of a video camera or web cam if you have one.. Press the buttons and watch the cam to see if you see the light coming from the remote.. The camera lens merely slows the light to a visable spectrum.. If no light your remote is not working... If light replace the sensor in the TV..
Bill
Jan 14, 2008 | Quasar VV-1302 13 in. TV/VCR Combo
Static on cable tv/vcr comb
ok,normally the cable connection that in deployed in the home is only good for 2 tv.and if you add for one,it will become fuzzy. I could suggest that connect other one cable line
Nov 07, 2007 | Quasar VV-2002 20 in. TV/VCR Combo
Quasar VV-2001 TV/VCR combo - msg: Check Antenna Cable Connection
Check first the antenna using another TV. If there is no other TV available, check using an ohmeter. If you are 100% sure tha the antenna is ok then the antenna connector on your Tv is not making a good connection to the antenna plug.
May 24, 2007 | Quasar VV-2001 20 in. Combo
Televison & Video Logo
140 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
