Question about Balance CM2017 17" Monitor
Signal out of range?
I have when I boot up my computer, this monitor displays "Attention Signal Frequency is out of Range H: 68.5 kHz, V: 85.3 Hz Please change signal timing". I have hooked a crt monitor to this computer and it displays fine. How do I adjust the "signal frequency"?
Thank you,
Chris M.
  • Anonymous Jan 07, 2009
    signal frequency came up on my windows xp ? what do I do
  • Paul Teichmann May 11, 2010
    It will be necessary to use your CRT to change the settings on the PC. What version of windows are you using?
    Scholar:
  • 103 Answers
Using your CRT, open the properties of the video adapter. Look for the refresh rate and set it to 60Hz. This should fix your problem.
Hope this helps, and please rate my advice, good OR bad.
Thanks, and good luck!
Posted on Feb 04, 2008
Get rid of "Out Of Range" message on e218c1 monitor.
The device driving the monitor is exceeding the horizontal and vertical frequencies that the monitor can display .....thus the "out of range". The specs for this state that the Horizontal Freq. is 80Khz and the Vertical Rate is 75hz. If you are driving this monitor from a computer running Windows, reboot the PC and use the F8 key to put it in SAFE mode. This will cause the video driver to default to a rate that the monitor can handle. Then go into the screen resolution settings and reset them. The native resolution of the monitor is 1680x1050 at 60 Hz. Exceed that and you'll get the "out of range"
Sep 10, 2014 | Envision Peripherals 22"" envision e218c1...
I get a message out of range.
your resolution is set too high.. change to VGA and move out from there. if the computer is set too high and you can not see boot into safe mode which should be VGA and set accordingly.
Nov 06, 2013 | Envision G22LWK 22" LCD Monitor
Has a blue dialog box that says out of range
Hello
It sounds like you have two separate problems.
The first one is the "out of range" issue. This means you are trying to display a screen resolution that is too high or too low and your monitor cannot display any image. Reboot your computer with another monitor or into safe boot mode and change the resolution to an industry standard (800x600 / 1024x786) and then see if your monitor will display the image. Once you can see the image on your monitor, you can make adjustments and it will automatically revert back if you cannot see the new display settings.
Update your video graphics card drivers to get the best possible resolution.
As for the buttons on the front of the monitor not working, this may be caused by the "out of range" issue above. It could also indicate that your monitor may be going bad. Try the above steps - if you get no image from the monitor, try moving the monitor to another known good computer and see if the button functionality works after it displays an image.
May 04, 2010 | AOC 193FW LCD Monitor
Out of range 64.0 kHz / 60 Hz
Unfortunately if you cannot get the resolution down, you cannot use it.
Jun 18, 2017 | LG Flatron L1515S 15" LCD Monitor
I get error message: Out of Range, on my 17 inch LCD KDS monitor
get the monitor that you used previously, and on the Windows desktop, go to display properties, in settings> advanced, under the monitor tab, change the refresh rate to 60, which is common on these flat panels.
Jan 05, 2010 | KDS Computers & Internet
In the middle of my screen a blue box is showing and in it this reads OUT OF RANGE H. FREQUENCY 68.7 KHz V. FREQUENCY 85.0Hz What does this mean and how can I fix it this was a gift...
That message appears when the Windoze display settings exceed the monitor capabilities. If you will boot into windoze safe mode (F8 at boot) and correct the display settings, the message should clear at the next boot. Afterwards you can right click on the desktop and access the display settings to make final adjustments.
In your case, the refresh rate (V Frequency) should not exceed 70 Hz
Nov 23, 2009 | Envision H22W 22" Monitor
Sonicview VG 2021 - Out of Range message
..hi..just select menu on the front panel of LCD the find the option Auto then click Auto..good luck..Thanks...^_^
May 11, 2009 | ViewSonic Graphic VG2021m LCD Monitor
A_turkovsky@yahoo.com
ya u enable vga mode hit f8 at start up in xp select vga mode ok resets u then use 60 hertz man and its native res ok only update drivers ect mark me ask fit ya ok thx nick
Feb 08, 2008 | ViewSonic VX1935wm LCD Monitor
Range Warning
first, 68.5 khz -85hz means horizontal raster frequency of source signal is at 68.5 kilohertz and repeats vertically at 85 hertz. (hertz means "cycles per second). the sony monitor cannot "read" the signal being sent from the pc. change the screen resolution to a lower number like 75 or 70 hertz vertical.
Jun 05, 2007 | Sony SDM-HS95 19" TFT screen silver LCD...
Balance CM2017 17" Monitor Logo
509 people viewed this question
Top Balance Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Jaime Hernandez
Jerry Greenberg
Jerry Greenberg
Are you a Balance Computer and Internet Expert? Answer questions, earn points and help others
