Question about Frigidaire PLMV169DC Microwave Oven
Microwave oven exhaust fan
I have a brand new Fridedaire over the range microwave. vertical exhaust. I rotated the fan, etc. per instructions, but I am not getting in pull at bottom, lots of air going out top.
  • 1 more comment
  • Honey_B Mar 13, 2008
    I have a similiar problem with my whirlpool microwave. The paper test under the vent works but when I'm cooking the steam and smoke from my cook top doesn't get **** in fast enough and leaves condensation on the microwave surface and smoke the whole house. Is there a way to improve the suction power of the vent? I feel more air blowing out then being **** in.
    Thanks.
  • Anonymous Jun 08, 2008
    the air is blowing out instead of blowing in
    I thought this was supposed to be an exhaust
    the dispay says fan ???
  • Anonymous Mar 16, 2014
    Vent fan will not pull any air from over the stove. Air blows out the top rapidly but there is no air being pulled from beneath
    Scholar:
  • 43 Answers
The Intake is gentle. It is not designed to have a great pull of air from the Cook Top.
TEST: Turn Exhaust Fan ON
Hold a sheet of your printer paper up to the INTAKE GRILLE (bottom). Will the sheet of paper stay? Held up only by the suction? If it does, Air Intake is OK.
Posted on Feb 03, 2008
Spontaneously stops working and then comes on after 5 minutes. Why?
Sounds like the magnetron is overheating. There is an automatically-resetable thermal circuit breaker attached to the magnetron. Most likely your problem is caused by either a cooling fan that is not running, or is running too slow (caused by gummed-up bearings). In some over-the-range (OTR) microwave ovens, the exhaust fan is run at a slow speed to cool the magnetron, and if it's bearings get gummed up, it won't run on the slow speed. But if it's a new OTR microwave, then the exhaust fan may be pointing the wrong way. (It is rotatable, depending on the installation). For example, if it is pointing up, but you don't have an exhaust vent over the microwave, then the air has nowhere to go, and the magnetron will overheat.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Oct 16, 2014 | Microwave Ovens
WMH32517AW Whirlpool Over-The-Range Microwave-No Fan
Go inside and check all of the connections related to the fan. Check the fuses, and the fan itself.
Nov 06, 2013 | Whirlpool WMH32517AW 1.7 cu. ft....
My Panasonic Over the range microwave Model NN-H264SF front touch pad don't get any beep plus i cannot put any number so microwave don't work. If range get over heat microwave exhaust fan get activated...
it needs to be repaired others have had the same problem.
here's one review...
liked this product very much, until it died after a little under 1.5 years. I brought it to a repair center recommended by Panasonic. They quoted me a parts-and-labor price of around $125 to fix the thing. The repair included a new membrane pad (the buttons on the front), new fuse, and new fuse holder.
The repair center told me they've been instructed by Panasonic to replace all old fuse holders with newer, better ones. Apparently, the original fuse holder was somewhat defective, causing the fuse to burn out. I don't know if this bears any relation as to why a relatively new membrane pad might have gone bad, but it's certainly annoying for a device costing several hundred dollars.
Feb 07, 2018 | Panasonic Microwave Ovens
How do you change fan exhaust from wall to front of unit.thanks
physically pull up and rotate exhaust blower fan assembly so it points toward the front. you'll need to remove a plate with a common phillips screwdriver.
Aug 06, 2011 | Goldstar MV-1501 Microwave Oven
Have whirlpool gold accuwave micro hood combo model# GH51884XPS5
The inspector is correct, air should be coming through the top louvers, although you sometimes will have a little air coming from the sides and back. Drop the microwave and see which way the blower is rotated, towards the louvers or towards the back or top. Some units also have a panel that blocks the venting from going the wrong way. Good Luck, Appliance Specialists
Dec 15, 2009 | Whirlpool GH8155XJ Microwave Oven
Tappan over the range microwave - exhaust fan problems
most microwaves do not blow air out the bottom.They pull air from the bottom and blow it out the top.
Aug 31, 2009 | Frigidaire Over-the-Range Microwave
My Micro vents into the kitchen instead of venting up the exhaust vent. What could be wrong
The fans on an over the stove microwave can be rotated up to 180 degrees depending on how the installer intends to vent the hood. Your fan is pointed forward and venting into the kitchen through a charcoal filter. If you want to vent through the ducting and out of the kitchen, you'll have to drop the microwave down off of the mounting bracket and rotate the fans in the back, pointing the dicsharge upward for a vertical vent, or 180 degrees, if it discharges out the back (wall vent). In both cases, an adapter is necessary, and can be obtained at any hardware store.
Best regards, --W/D--
Aug 08, 2009 | Tappan TMT104E1 Microwave Oven
Vent fan high comes on automatically with cooking
Right, that would be MCO10UW and the owner's manual is here.
The owner's manual does say this, of course,
"To prevent overheating from taking place, the exhaust
fan is designed to automatically turn on at a low speed if
excessive temperatures occur. Should this happen, the
fan cannot be manually turned off, but it will
automatically turn off when the internal parts have
cooled. The fan may stay on for up to an hour after the
range and microwave oven controls have been turned
off."
That;'s standard on microwaves.
But these models do have a separate internal cooling fan (which should run any time you microwave) plus the hood vent exhaust fan, which should only run when you select it, or if there is an excessive stovetop or under-hood temperature.
So if it comes on whenever you microwave, that is incorrect.
When that happens, it's usually a defective vent thermal switch (a.k.a. hood TCO).
But since it's brand new, I would certainly contact Magic Chef about this. If it's in need of repair, they will fix it free, assuming the oven wasn't physically damaged.
For more help from Magic Chef / Ewave see here or their contact page.
For Magic Chef in Canada call 866.587.2002
Jan 08, 2009 | Magic Chef CMV1000B Microwave Oven
Turntable in GE microwave stopped turning.
On some GE models, the turntable motor and stirrer motor are powered off a tap on the internal cooling fan motor and in such cases they will be marked "21V AC".
When I say internal cooling fan, I do not mean the hood vent exhaust fan which you can turn on and off manually.
I'm instead talking about the internal fan which comes on automatically whenever you microwave.
It is vital that the cooling fan runs, or the turntable and stirrer won't work, and magnetron will soon be destroyed.
A quick test is to remove the stirrer cover in the ceiling of the oven. The owner's manual tells you how, and you can download that here.
Then run the oven for several seconds with a cup of water inside while watching the stirrer blade in the top. It should turn very slowly.
If it does not turn or is jerky, it or the cooling fan is not working.
Also, we have a sound clip of what a microwave should sound like when the cooling fan and everything else is working here. The cooling fan's absence will be notable after you hear the clip.
The turntable system otherwise consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If the cooling fan is good, but yours won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Accessing some parts may require you to pull the oven from thew wall and remove the cover.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
Jan 04, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Noise of microwave exhaust fan
You can remove the exhaust turbine unit with one screw and reinstall microwave and buy a braun external exhaust unit that fits over the hole where it is at the roof or wall and all of the noise will be outside and it will actually work. It is weather proof and will **** steam or fumes out like the best vacuum cleaner.
Mar 25, 2008 | Microwave Ovens
Frigidaire PLMV169DC Microwave Oven Logo
749 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
