Toshiba Satellite M35X-S349 Notebook Logo
Posted on Feb 02, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Disc Drive I am no longer able to play DVD's or Burn Discs. The error message reading I/H error pops up and says that the drive in inaccessible. It simply will no longer read anything in that drive.
Anonymous
Level 3:
Genius:
  • Master 3,587 Answers
  • Posted on Feb 02, 2008
Anonymous
Master
Level 3:
Genius:
Answers
3587
Questions
29
Helped
1147334
Points
9064
Two things to do.
1. Go to your system manager, then hardware option. If you can 'see' that drive(listed under DVD/CD) then it's mechanically ok.
2. Drivers for these can be abrupted quite a bit, easily. Check for drivers at support.toshiba.com
2answers
Remove Write protection from DVD disc
1. Insert the DVD disc into the computer's DVD-ROM burner drive. Click on "Burn files to disc" from the window that automatically pops up.
2. Type a name for the DVD disc in the "Burn a Disc" box. Click "Show formatting options" and choose a formatting option.
3. Choose "Live File System" to allow files to be copied immediately to the DVD disc, much like sending data to a USB flash drive or floppy disk. Live File System discs can only be read by Windows XP or later versions. Choose "Mastered" to have files be copied to the DVD all at once. This is the standard burning method; discs can be played back on any DVD-ROM drive.
4. Click "Next" to prepare the disc. Files can now be copied to the disc using the selected method.
tip
When you try to play a DVD game on Xbox 360 it tries to play as a movie?
c on your Xbox 360 console, you may receive an error message. This article presents step-by-step guidance to help you determine whether your disc is playable.
SYMPTOMS When you try to play a disc, you may receive the following error message: Can’t read this DVD.
CAUSE The DVD or game disc may be dirty or damaged. Because the console cannot read the disc well, it may even mistake a game disc for a DVD and report this error. If this problem occurs with multiple discs, even clean and undamaged discs, there may be a problem with your Xbox 360 console.
Note If you receive a different error message, such as one of the following messages, the problem is a different problem:
Error message 1 Can't play DVD. Wrong region code. Error message 2 Can’t play DVD. Family settings restrict playback of this DVD. If you receive one of these error messages, see the corresponding Knowledge Base article: 907620 While attempting to play a standard DVD movie using your Xbox 360 console, you receive the error message: "Can't play DVD. Wrong region code" 908645 While attempting to play a DVD movie using your Xbox 360 console, you receive the error message: "Can’t play DVD. Family settings restrict playback of this DVD"
THINGS TO TRY Here are some things that you can do to try to fix the problem or to determine what caused it.
Determine whether the disc is dirty or damaged Discs that are smudged, scratched, or otherwise damaged cannot be read by the Xbox 360 console. You will want to examine the disc to see whether it has smudges, scratches, or other damage. To do this, follow these steps: 1. Examine the disc for dirt or damage: a. Pick up the disc by its edges. Do not touch the top or bottom surface. b. Examine the shiny side of the disc to make sure that the disc is clean and has no damage.
NoteScratches that follow the curve of the disc are very damaging and prevent a disc from being read. If your disc has even one of these kinds of scratches, the disc is damaged, and you will no longer be able to play it. If this is the case, see step 4. 2. If the disc is dirty, clean the disc by hand: • Use a soft, clean, dry, chemical-free cloth to clean the disc. • Lightly wipe from the center of the disc outward. 3. After you clean the disc, try to load it in the Xbox 360 console. If the disc still will not load or you receive the same error message, the disc is damaged, and you will no longer be able to play it. If this is the case, see step 4. 4. If the disc is damaged, do one of the following: • Because DVD discs are not game discs and the disc was damaged because of misuse of some type, such as not storing the disc in its case, the only thing that you can do is buy a new one. • If you feel that the disc was damaged by the Xbox 360 console in some way, please contact Xbox Customer Support. To do this, please visit the following Microsoft Web site: http://www.xbox.com/support/contact
3answers
It says unable to read disc when i put the game in.
Please Rate me!
What Is It? The Disc Read error is a simple one. It simply means that the Xbox is unable to read the disc that you have placed in the drive. In the majority of instances, this error has nothing to do with the functionality of the console, but, rather, hinges on the actual disc that has been inserted into the DVD tray.
Disc-Related Errors The most common reason for Disc Read errors are related to the disc itself. Numerous conditions can keep the laser from reading the information contained within the game, DVD or CD in the DVD drive.
  • The disc is scratched - Game discs, audio CDs and DVDs can become scratched very easily. Usually this is because they have not been kept in their cases, but left in the open. Simply resting two discs atop one another can scratch the bottom disc. If discs are sufficiently scratched, the data contained on them will be inaccessible to the drive.
  • The disc is dirty/dusty - Dirt and dust can build up on the faces of discs left exposed. When sufficient dirt or dust has built up, it can block the laser beam used to read the disc, resulting in a Disc Read error.
  • The disc is the incorrect region - DVDs come in formats called "regions." These regions match the region specified in the software of the DVD player. Some games also have these regions. If the region of the DVD and that of the player do not match, the disc will not play.
Can I Fix These Errors? Repairing disc-related issues may or may not be possible. If the cause is simply dirt and dust, you can certainly repair the disc. However, if the cause is due to extreme scratching, then replacing the disc is likely your only choice. If the disc is from the incorrect region or from another country, you will have to obtain the correct region. Returning the disc to the retailer for exchange may work.
Non-Disc Related Errors As mentioned, there can be some Disc Read errors that have nothing to do with the disc at all. In this case, it's time to troubleshoot the Xbox.
  • First, simply try to reboot the machine. Often, this will flush the cache or other error and allow the game to operate or the disc to play.
  • Second, try removing the hard drive and/or memory units. Once removed, reboot the console and attempt to load the disc with the hard drive and memory out of the unit. If this works, you can simply shutdown and reinstall the hard drive.
  • Attempt to play the disc in another type of player. For instance, attempt to play the DVD in another DVD player or the CD in a CD player. If the disc plays in these players, you may need to clean the Xbox DVD player.
  • Check to make sure that all air vents are open and are able to provide sufficient airflow. Overheating can cause Disc Read errors, as well. In addition, ensure that the power supply is unobstructed and uncovered. Much like the Xbox 360, the power supply can become quite hot and can cause errors if unventilated.
  • Check for disc tray errors. Depress the eject button and watch the tray extend. If the tray partially extends and then retracts immediately, you may have a problem with the DVD drive. If your Xbox is under warranty, this can be replaced at no charge. However, if you are out of warranty, you can install a new DVD drive on your own.
  • As a note, make sure that the new DVD drive comes with the same firmware as your original console, or you may experience additional error codes after the installation of the new DVD drive.
2answers
Can lite-on-ltn4865 48x play dvd movies
If your Drive is a CD-Rome drive, surely it cant, for the drive cant read dvd disc. Replace the drive of yours with DVD-Rom or DVD-RW in order to play dvd disc, DVD-RW simply has the added capablity to burn on DVD discs
The drive plays DVDs and can read doc files, but
This problem is normal and exists with many CD/DVD drives.
On some of the drives, if you put in blank discs and try to open the disc in My Computer or Windows Explorer, Windows displays no contents or a blank disc. Whereas on other drives, you get the error message that you mentioned about incorrect function.
What software are you using to burn CDs or DVDs? Are you able to burn CDs but not DVDs or you can't burn both the discs? Did you try a CDs with a different make/manufacturer? Some drives refuse on some disc makes. Try another disc and another writing speed, or try the lowest writing speed available with your software.
Hope that helps,
Regards,
Raspal
1helpful
Disc drive no longer reads discs, when trying to burn error "please insert empty disc" pops every time, regardless of CD inserted.
Assuming you have already tried a cleaning kit, the unit has probably burnt out the laser and will need replaced. Luckily new DVD+R burners can be found for less than $25.
When i put an Xbox 360 game in it tries to play it as a DVD movie. please help!!!
When you try to play a DVD movie or an Xbox 360 game disc on your Xbox 360 console, you may receive an error message. This article presents step-by-step guidance to help you determine whether your disc is playable.
2answers
Xbox 360 disc drive is not reading discs, comes up with
time for a new reader only around 15 pound or 28 or so dollors on ebay and see you tube on how to replace drive its not to hard to do
5helpful
3answers
DVD is not recordable, Acer Extensa 5420
Just put in the blank dvd without trying to burn anything to it and see
if your pc see's the blank dvd, if not find one that is recognized by your pc. After you put in a blank dvd, it should show under my computer in the drive and should be able to open it like a folder, or
windows will pop up a little window that ask's if you would like to burn anything to the dvd.
CD RW/ DVD RW Drive Will not read and Burned discs or burn to blank discs
I suggest a firmware update from Toshiba. If this does not help then your laser in the drive is no longer capable of this task. Also just thought about it but make sure the media that you are burning to is the same as the drive + or - R's
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
