Question about HP Compaq Evo n610c Notebook
Lap top not turning on
A friend of mine has a lap top like mine, her son slammed it shut on her, now it won't turn on, she has the ac cord plugged in, the battery light is orange, but won't do a thing, is her battery toast or is there something else wrong?
    Scholar:
  • 103 Answers
Try removing the battery, waiting 30 seconds, then plugging it back in. Plug in power cord and try to turn it on.
Posted on Feb 02, 2008
Targus Charger Problems
It looks like there is a shorting taking place whenever you insert the power jack into the laptop. Most likely the shorting is taking place on the laptop side and requires replacement, which should be done at the manufacturers service station even if its warranty has expired.
Dec 02, 2011 | Targus Computers & Internet
Toshiba Satellite C655-S5082. Won't power on. Worked fine last night. Today it won't turn on. Plug it it and no power light. With power cord plugged in when I push the power button the light for...
Hi.
Take out the AC power jack and then remove the laptop battery. Plug AC power back in and see if the laptop will turn on. If it turns on let it boot the operating system and then shut down as normal, remove the power cord and reinsert the battery and again see if it will switch on. If it does then there has been a glitch with the battery. If it doesn't then there is a problem with the battery.
If the laptop won't switch on either with or without the battery then there is a possibility that the motherboard has developed a problem.
Good luck.
Jul 16, 2011 | Toshiba Computers & Internet
Hi: My Aspire 4710Z was not shutting down properly. I pulled out the battery to turn it of. Now, when I put back the battery after few hours, there is no power in my Lap top. Screen is black and now...
Remove the battery and the AC adapter from the laptop.
Press and hold the power button for 60 seconds then let go
Plug the AC adapter only back into the laptop
Now press the power button on the laptop
If it now boots properly shut down the laptop and insert the battery
Now push the power button again
If it now fails you may have a bad battery
Mar 05, 2011 | Computers & Internet
Green light on ac charger goes out when i plug it in to lap top
This indicates a short in the computer or power supply. The power supply senses the problem and shuts itself off. Does the laptop run at all? More info. is needed to correctly solve your problem. Send me a message and I will help you out. Phil
Dec 09, 2009 | Dell Inspiron 1501 Notebook
My lap top worked just fine in the morning and went into sleep mode. The computer was unplugged so there isn't a power surge issue. I've tried shutting it down by holding down the power key, I removed the...
try the following steps.
1.remove the battery pack
2.press and hold the power button for 30 seconds.
3. plug in the ac cord to the wall and to your laptop, (make sure the light indicator on ac adapter is on)
4. press the power button once to turn on
IF this process fails, more likely you have a motherboard issue. South Bridge chipset may need to be resoldering or replaced
hope it helps yuva
Mar 26, 2009 | Computers & Internet
My lap topwill not turn on.
Try to check if your AC adapter has a light itself. If it the light is off. Then try a known good adapter. If the AC light is green, then try to wiggle the cord from the port and see if it ain't loose. Try to also check if the AC pin is not bent or broken.
Nov 25, 2008 | Dell Inspiron 6000 Notebook
Toshiba M55-S135
check your battery on some other's laptop, i think the battery life is over, you have to replace the battery
Oct 29, 2008 | Toshiba Satellite M55-S135 Notebook
Acer extensa 4620Z laptop computer will not re-charge battery. The cord going to the outlet has power...green light...but no lights are on lap top and it is securely pluged into lap top. - When I...
It could be one of three things. It could be a bad battery, a bad ac adapter, or the recharging circuitry could be bad. I would try pulling the battery out, and see if the laptop will startup and run strictly off of the ac adapter. If that does not work, you have a bad ac adapter. If that works, and the battery has any charge left, try running it strictly on the battery. If it doesnt work, you have a bad battery. If it does work, the circuitry is bad and you will probably need new motherboard. One other thing you can check is where the ac adapter and battery plug into the laptop, and make sure there is no corrosion that could be causing a short.
May 10, 2008 | Computers & Internet
Battery
ok..remove battery from laptop..plug in ac adaptor, then see if it runs..
Apr 18, 2008 | Dell Latitude D600 Notebook
360 No Longer Turns On
By cord, do you mean the entire AC convertor box? Does the orange light on the convertor box light up? If you used your friends whole ac wire/convertor box (w/ the plug that goes into the xbox itself) and THAT didn't work, then your motherboard took a surge. It is probably trashed as they are VERRRRRRRY sensitive and prone to failure. Time for a new one (or a warranty "repair").
Sep 12, 2007 | Microsoft Xbox 360 Console
HP Compaq Evo n610c Notebook Logo
160 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
