Question about RCA P52937 52" Rear Projection Television
Convergence problem I have a convergence problem with my RCA P52937SG. the picture is bowed in the corners and the pictue is blurred, how can I fix this
  • Christy Nance Apr 09, 2009
    My RCA P52937SG Rear Projection TV was fine until about a week after we moved it. Then, all of a sudden, the screen was bowed on both the top, bottom, and the sides. What can I do to fix this?
    Genius:
  • 3,422 Answers
Yes, this is a convergence problem.
If it is going in and out or showing different symptoms from time to time, I am suspecting you have an intermittent problem as well.... Have you done the whacking test? Whack the set with your hand or fist; smack it a good one on the side, top, back, etc., to see if you can restore the picture. If the picture will restore - even if only for a few seconds, then you have a loose connection or a cold solder joint lurking inside somewhere. It may still be the convergence board or somewhere else that is effecting the color resolution lines; or you could have two problems: A) convergence board failure and B) intermittent condition from a cold solder joint either in the convergence board or elsewhere.
If you replace the convergence board be prepared to shell out some serious money. Usuall cost is around $150 to $400 depending on the unit and the labor and the other parts that may need replacing.
I, personally, don't like RCA brands because I believe they are not too reliable. So, if you repair it there is a high satistical probability that something else will go down soon thereafter. RCA in particular are prone to MTBF (Mean Time Between Failures) that catch up with it soon.
If you call a repair shop that is well trained in RCA big screens and describe the problem I think they can give you an easy estimation of what will be needed and how much it will cost.
goodluck,
Please don't forget to rate me as fixya..
Posted on Feb 02, 2008
At the top of TV there is a color line that is bowed it will not show a picture and another problem is the color. For example when it says menu on the screen you can see it in red, gren and blue not just...
Ur tv have a problem known as a convergence picture problems it is dead.Tv have any colors lines R,G,B mis alignments,have colors shadows picture or 3D pictues look alike?Yes.The tv convergence board it dead have to be fix like replacing 2 STK convergence ICS and some or all of it resistors too.Fixed the convergence board to solved tv convergence picture problems.The tvs shops will cost u like $300-350 for parts and labors.
Aug 25, 2011 | RCA HD52W59 HDTV Projection Television
My 52" RCA P52937SG screen bows on the top and on
What you are describing can be due to a number of different settings.
Focus on the red and green guns
Sharpness on the red and green guns
Horizontal position and size
Vertical position and size.
Please consult a professional for adjustment on these items as they are all near or connect to parts that have Hazardous Voltage.
Mar 22, 2011 | RCA P52937 52" Rear Projection Television
the part is called the convergence ic. replace those ics.
Mar 22, 2011 | RCA 32F531T 32" TV
Blurred picture and colors. warped picture size
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some images of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Or goto the site www.TvRepairKits.com for the parts and instructions on how to fix it yourself.
Nov 28, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Hi RCA 52 inch part numbers P52937SG
Tries this website for convergence ICS.Must know how to solder?Tv Repair World.com,Ebay.com.
Oct 15, 2009 | RCA P52937 52" Rear Projection Television
Hi i have a RCA P52937SG with the bowing of the screen
The problem may still be on the power supply board (one of the supplies may be missing and) when you unplug the supply both supplies go missing check the supply voltages and repost
Oct 14, 2009 | RCA P52937 52" Rear Projection Television
RCA projection is having color shadows and blurred picture.
Hi, this is failed convergence and it is due to a faulty convergence board chip set. simply replacing the convergence board in this set Will fix your issues.
May 21, 2009 | RCA HD52W56 52" Rear Projection HDTV
Picture is blurred and bowed
ok you have a convergence problem. first check out the article the fl231 problem in the tips and tricks section it will tell you of a condition that might mean an easy repair. first check to see if you have the convergence options in the customer setup menu
Mar 15, 2009 | RCA HD52W59 HDTV Projection Television
Double words and blurred picture,
Is the picture bowed in too. first consult "the fl231 problem" article under the tip and tricks section under my profile. THis MAY be the problem. Otherwise you have a convergence issue. convergence is controled by three cuicit boards in this set. Setting the convergence on this set is tricky. try autoconvergence see how far it gets. let me know and i help you trouble shoot further
Nov 15, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA P52937SG Convergence
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 29, 2008 | RCA P52937 52" Rear Projection Television
RCA P52937 52" Rear Projection Television Logo
171 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
