Question about Sony XR-CA370 Cassette Player
Radio not working
I've just got a new car and attached the XR-CA370 to power - but I can not get any lights or anything on the display.
I have followed the connection guide from SONY and connected the black cable to earth and the red and yellow to the 12V+.
I have tried just the red to 12V+ and press reset, nothing.
Just the yellow to 12V+ and press reset, nothing.
AND both red and yellow to the 12V+ and press reset - NOTHING!
Any ideas / help / advice?
PLEASE!
  • Bruno58 Feb 03, 2008
    I had already checked the power supply, earth and fuses. In fact I even plugged in a cheap radio and that worked fine. My nice SONY XR-CA370 was working fine in my previous car and I thought I must have wired it up wrong or had to do something to get it powered up (I don’t think it had a code?).
    All I’ve done so far is connect the red and yellow cables to a good battery (+ve) and the black cable to the –ve. I then pressed the reset button, as per instruction manual, and attached the front panel – no display and no lights. I cleaned the contact on the panel and repeated the above steps - nothing.
    I tried pressing the OFF and indeed every other button, several times – no display at all.
    I was rather surprised to get a voltage from the yellow cable and earth – with no car battery anywhere near. I assume it has a battery (small black square on the circuit board?) or capacitor somewhere. I have taken the radio to bits and cannot see any obvious damaged capacitors, shorted resistors or bad solder joints.
    I was just hopping that someone would say “press X” or attach cable Y, but I am beginning to agree that the radio has died. It was kept in a box for a year or so between cars and now it seems I may have to burry the poor little thing I that box.
    Thanks for your help Bear40.
  • Bruno58 Feb 04, 2008
    Thanks again Bear40.
    I do not remember that this radio had a code, but you could be right. Nothing in the manual?
    Do you have any idea how I go about entering the code (if I ever find it)?
    I've had radios with codes before but they always displayed CODE or something on the screen, this one is just totally blank,
    Thanks for you help but I think this one is going in the bin!
Have you made sure your power source has power?
Next check your inline fuse if it has one.
Make sure you do have a good ground.
If none of these solutions work you most likely have a bad system.
Posted on Feb 02, 2008
  • Bear40 Feb 03, 2008
    It has a removable face if you removed it before disconnecting the power you should have to enter a code to get it to work again.
    It is part of the security feature of the unit to keep people from stealing your deck and placing a different face on it.
  • Bear40 Feb 05, 2008
    you know you are right you don't have anything at all I would say your radio is gone.
I just installed a new stereo and now my running lights are always on even when I turn headlight switch off. It is a U.S. car and everything else is working fine.
There is a wire that attaches to the radio that turns on the radio lights together with the park/running lights. You must've attached that wire to a full time power source if the running lights are on all the time, right after a radio install. Recheck your radio wiring.
Jan 02, 2011 | 2001 Nissan Pathfinder
2007 Saturn Aura XE, the audible alarms can hardly be heard
Good news - they're adjustable. The radio is used to adjust the vehicle's chime level. To change the volume level of the chime, press and hold push-button 6 with the ignition on and the radio power off. The volume level will change from the normal level to loud, and LOUD will appear on the radio display. To change back to the default or normal setting, press and hold push-button 6 again. The volume level will change from the loud level to normal, and NORMAL will appear on the radio display.
Note: Each time the chime volume is changed, three chimes will sound to indicate the new volume selected.
Sep 07, 2010 | 2007 Saturn Aura XR Sedan
Need to download manual for Sony XR-CA370 car radio
Click Sony Support and download required user manual of XR-CA370
Sep 04, 2010 | Computers & Internet
Disc can eject and be inserted but display does not light up, none of the buttons do anything. tried a different deck and it does the same thing the display dosen't work and no music plays. i am thinking...
It sounds like they messed up your installation. You can confirm their work by verifying that each wire was attached properly.
2005 Pontiac Sunfire Car Radio Wiring Diagram Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: Pink
Car Stereo Amp Trigger Wire: Pink
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Click on this link for a PDF of the installation instructions of the radio (If you don't have the installation guide that came with the radio).
Illumination is the grey wire from the car to the orange with white stripe from the radio.
I suspect that the yellow wire from the car is not connected properly. When the orange wire (constant power from the car) is attached, but not the yellow wire you can insert and eject cds, but it will not turn on. Constant power is used for maintaining the clock and preset radio stations.
If everything looks correct, I would take your car back to the installer and have them correct the issue.
Dec 21, 2009 | Sony CDX-GT400 CD Player
Cd change will not work
Power Antenna Wire hooked up as amp turn on. Switch the blue wires around.
Dec 21, 2008 | Sony XR-M510 Cassette Player
SONY XR-C450 FACEPLATE WON'T LIGHT UP
How do you solve the problem my face want light up
Nov 25, 2008 | Sony XR-C450 CD Changer
I have a AIWA XR-MDS7 EZ sup mini stero unit, the lcd display is dead although the unit works I cannot tell what disc is playing or track number. Also I cant tell what radio station is playing. Everything...
The first thing to check is the solder connections on the display itself. Look specifically at the connections on either end of the display. These are the supply pins. Also, I don't know if this model has an LCD display or LED. If LCD, then make sure that the back light is funtioning.
Keep us posted on what you find.
Dan
Apr 11, 2008 | Audio Players & Recorders
Wiring color code for xr-c5100
I am about to sell one on eBay - here are the connections from the installation paperwork and connector that I have:
Top row, left to right:
White - Front Left (+)
Green - Rear Left (+)
Purple - Rear Right (+)
Gray - Front Right (+)
Blue/White strip - AMP REMOTE (Max 0.3A)
Blue - ANT REM (Power Antennta Remote) (12V, Max 0.1A)
Red - Power (Accessory)
Black - Ground
Bottom Row, left ot right
White/Black - Front Left (-)
Green - Rear Left (-)
Purple - Rear Right (-)
Gray - Front Right (-)
BLANK
BLANK
BLANK
Yellow - Power (Battery)
One of the BLANKs is for the "Light Blue - ATT (attenuation for car phone)", but it is unclear which one. This wire is not on my connection block...
The circular BUS line to the right of the terminal block is apparently for linking to a CD/MD unit (cable supplied with unit)
The Blue 3.5mm socket is for the RM-X45 Rotary Commander (which attaches to the indicator lever)
Important notes:
If there is no ACC power line in the car, do not connect the red lead.
Ensure the power select switch on the bottom of the unit is in the B position, then press the RESET button (behind the faceplate).
This means that the display will be off when the unit is not in use - avoiding a flat battery risk.
(Posn A is for normal use, with red line on ACC)
The RESET buttom should be pressed after installation, before initial use.
Hope this helps.
Jan 08, 2008 | Sony XR-C5100 CD Changer
Sony XR-CA370 Cassette Player Logo
100 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
