After cleaning stove top, I turned stove on and sparks came from the control I turned on. Now there is no auto pilot, the gas comes on but we must manually light it. What can we do to fix this?
Hi There are a few things to check for: First make sure the electrode (the small metal piece that the spark comes off from) is clean and the holes in the burner are clean, use a pin or paper clip to clean out the burner holes. The next thing to check for are theignition switchesunder the surface control knobs, the switches can twist and break and keep the spark module on and the spark keeps "clicking" even when the burner is light. If every thing looks good, you may have a badsparkmodule which should be replaced as sometimes cleaning can get moisture into the surface switches; try drying them with a hair dryer to see if this will help. Hope this helps...please post back for further assistance. Daniel
Probably the safety valve. This unit broils and bakes off the same gas burner. A spark ignitor lights the pilot and this save gas because no standing pilot is needed. It takes a few minutes for the thermocouple bimetal combo to release the gas. When the temp gets to the desired rate then the bulb on the oven control closes off the flow of gas. To recap: The flow of gas comes from a regulator along a rail which supplys the gas to the top burners and the oven control. older models had pilot light tubing going down to the oven and to the top burners. This newer style uses a spark module to light off the top burners and the oven. So when yall turn the the oven on the spark ignitor lights the pilot first and then after the mercury bulf thermocouple heats up the bimetal inside the valve opens allowing gas to flow out to the pilot and ignite the gas burner. the temp rises and the mercury bulb oven control expands closing off the flow but not the gas safety valve. I would suspect the safety valve on this one.
check to make sure your pilot orfice is not clogged it will be located at the end of the small tube coming from your gas control valve if its not then while you are trying to light the pilot tap the side of the gas valve (sometims somewhat hard) if it then lights you know you have a bad gas valve
As far a "popping" do you mean the igniter on the cook top "clicking"? Did you clean the range and use too much water? If water gets into the igniter switches they will short out and constantly click. Also if the polarity at the electrical plug you can get what is called "ghost spark" so make sure that the polarity is correct at the electrical outlet. Each gas control valve has a switch that turns on the igniter when the knob is in a certain position and they are all wired in a sequence. One of those switches may be shorted out or have a loose wire(range dis-assembly required to inspect). Do you visually see a spark at the electrodes of the burners or do the burners ignite? If you cannot see the spark then there may be a grounding issue and possible loose wire.
There is not pilot light on the stove top since the burner is activated by a spark generate by high voltage to a small ceramic disk with a wire protruding from it by the burner.
You have the have AC Power to the stove and you should hear a clicking when you slightly turn on the burner. Once the burner is on fire then turn the burner control to the desired temperature. If the burner will not light after 4 seconds of clicking sounds turn the burner control off and make sure the round gas diffuser on top of the burner is correctly seated on the burner. It should lock in place and is removable for daily cleaning of the stove. Now try the burner control again in the light position for no more than four seconds to see if it lights.
Do you smell gas? Do you hear clicking when slightly turning the burner knob? If yes to both the stove is working and the top of the burner is not seated correctly. If no on either or both you may have a stove, electrical or gas problem.
Wow this problem sounds exactly like my landlords problem only he is just now saying he is learning of the problem. You even have the age of the stove correct.
do you hear any clicking when you try to start the oven portion of the range? if not lets try this, open the lower drawer so you can see the burner bar and mechanism for lighting the bake bar. as your watching the mechanism turn on the oven (nothing should happen as per your issue) while oven is on try lighting one of the top burners, any one will do wanna check if that lites the spark and in turn lites the oven pilot.if that does infact work you have a bad spark switch for the oven control
