Cable connection I just bought a used Quasar television 1989 - TV25130K. There is also a Quasar remote with it that works. However, I want to run cable on this set and I do not think this "old" remote is capable of getting this done. My problem is that I cannot seem to get a universal remote to work on this television in order to set up my cable. Is there a way I can do this through my Quasar remote, assuming the same year as the television.
  • 2 more comments
  • rsckr63 Feb 03, 2008
    Excellent! Thank you so much. I had others telling me that they thought this t.v. would not be able to receive cable. Did what you said and now have cable on its. Again, thanks! Robin
  • Anonymous Feb 12, 2008
    I attached the cable wire to the back of the tv but it does not come on in cable mode. It has a lot of static.
  • nile80 Feb 28, 2008
    hello.
    Have a SANYO CEM 1454 TV.İ adjust the channells but can not save them.İ cant find memory button on the remote.Pls help me.
    Thanks in advance.
    Nilgun
  • Anya hoboken Apr 05, 2008
    I have a Sony TV same problem
    Scholar:
  • 84 Answers
Some older tv's only go up to so many channels.you may not even need a remote to set up cable tv. if you are going to use a cable box on this tv, put the tv on channel 3.if not, look in front of the tv for a little door. behind it maybe knobs or buttons that can program the channels 1 at a time [+= add - = erase. there also maybe a switch for different cable types [hrc,std, etc]
hope this helps
wg
Posted on Feb 03, 2008
OLD QUASAR TV WITH BUILTED IN VCR WITHOUT REMOTE. ISN'T A WAY TO AUTO SCAN CHANNELS WITHOUT THE REMOTE?
I think you can use the channel up arrow and it will go into an auto-scan mode. At least that's what I was able to do when I was having my problems with the cable/sat now working. I had to find a way to get it into Cable mode vs TV mode. I think if your tv is in TV mode, this might work. worth a try at least.
Oct 23, 2011 | Quasar SP-2723 27" TV
Quasar VV-1301 cant program for cable tv channels without remote, is there a way to autosearch the cable for channels so they are able to be selected
Ur tv have a manual Menu button on the front of the tv bazel frame?Yes used that manually Menu button pushes go into the tv menu to find select CABLE do autosearches by hand through a manually selected by functions buttons like channels buttons up and down as selections and menu button as enter to excicute functions.No try website like Remotes.com to buy the tv original remote to used.
Aug 18, 2011 | Quasar SP-3235 32" TV
I have a Quasar tv/vcr combo, model VV2007, I have no remote and bought a RCA universal remote and none of the 3 codes work, the most I can get out of it is channel and volume, I need to add channels but...
Sometimes the universal remotes do not compromise fully with certain models especially with combo models.
So you might a different type of universal type to connect with the Quasar codes, but it is ideal if there is the model mentioned in the manual of the remote.
Volume and channel working is what is most important and should be considered good enough.
Sep 14, 2010 | Quasar VV2007 20 in. Combo
My Quasar VV8220
According to the manual, follow the steps below to program channels on your Quasar VV8220 TV:
1) Hold the CHANNEL MEMORY Button on your remote in and press the 1 key
(a box will come up where you can shift between TV & CATV --
you will want to be on CATV (for cable channels).
2) Press the 4 key which will change from TV to CATV -- make sure it is
on CATV or if it is already on CATV, press the 5 key.
3) Press the 4 key (the auto set guide will engage and go through the channels).
Hope this is helpful.
Aug 14, 2008 | Televison & Video
Quasar tv/vcr
try this code--003,or 070
Nov 01, 2007 | Quasar VV-2002 20 in. TV/VCR Combo
Quasar VV-2001 TV/VCR combo - msg: Check Antenna Cable Connection
Check first the antenna using another TV. If there is no other TV available, check using an ohmeter. If you are 100% sure tha the antenna is ok then the antenna connector on your Tv is not making a good connection to the antenna plug.
May 24, 2007 | Quasar VV-2001 20 in. Combo
Can receive only channels 1 thru 27 although connected to cable with 70 channels.
First you need to check if your set is in the cable mode and not antena mode,if the set is in cable make sure is in the standard cable mode and not another type of cable like HRC,if it is change it and try the autoprogram to set the available channels.I hope it helps.
Sep 11, 2006 | Panasonic PV-M1349 Combo
Quasar TV
Is there no buttons on the set to adjust the volume??? I've never seen a tv that didnt have at least under a door somewhere. Do you have an owners manual? You can get a universal remote to get this to work Good Luck!
Apr 14, 2006 | Quasar TP-917 9 in. Television
Televison & Video Logo
111 people viewed this question
Top Televison & Video Experts
Electro Med Services...
