Question about Mitsubishi VS-55705 55" Rear Projection Television
Mitsubishi 55 rear projection
When I go to turn the unit on I herd a pop from rear and tv does not come on. Pulled back panel off the flash pop is coming from the center bulb area any ideas?
  • dakota48078 Feb 03, 2008
    it does look like the center (crt) has fluid in it the other two do not are they all supposed to? and the center one is leaking replace it or is there a fix thanks again
  • dakota48078 Feb 04, 2008
    pulled the center crt out today the arc was right at the heavy gauge red wire (like a spark plug wire) where it goes in to the lense the metal housing. the bottom board does show evidence of fluid that has been on it , is it possible that I just have to clean the boards and fix the leak in the crt would a shorted board cause it to arc at the top
  • Mitsubishi Master
  • 8,617 Answers
Sounds like yor green crt is shorted or you have some bad solder connections on the green CRT socket. Check the board with the green CRT socket for cracked solder. if the soler looks good your CRT is probably shorted.
Posted on Feb 02, 2008
  • Sonny Berry
    Sonny Berry Feb 03, 2008
    Yes they all should have fluidin them for coolant. This is easly replaced. but you must get all the coolant off the circuits as this will corrode your circuits. take the noard completely out to dry all the coolant. The seals are available and the coolant is very cheap. Let m know if ou need any additional info.
My mitsubishi 55" rear projection tv won't turn on at all. It does not make the clicking sound it normally does when you turn it on and the green light does not flash at all either. Tried unplugging it and...
problem with the convergence ic , normal repair on this unit is about $300 , but if u have some soldering skill u can do this job there is also 2 bad pico fuse 5amp , there is some wed side who sale as a repair kit
Aug 26, 2010 | Mitsubishi WS-55511 55" Rear Projection...
The green light on the front panel is flashing but
Try website Tvrepairworld.com to buy a refurbish DM power board for the replacement.U know soldreing?Buy capacitors for the replament.
May 14, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Green timer light flashing. tv won't turn on
Have to have a shop repair your microprocessor board.
Dec 30, 2009 | Mitsubishi WS-55511 55" Rear Projection...
55" mitsubishi timer light flashes
I just had the same problem have you figured out how to fix the problem?
Nov 26, 2009 | Mitsubishi WS-55511 55" Rear Projection...
It wont turn on. the power button light is just flashing.
physically unplug unit from wall. wait 2 minutes. this resets the microprocessor in tv. plug back in. enjoy!
Nov 11, 2009 | Mitsubishi WS-55711 55" Rear Projection...
Mitsubishi 55" rear projection TV, wouldn't turn off
um . that model doesn't have a reset button . but if no lights on front of the set even blink when you press the power button on the front or on the remote .then suspect front panel buttons ,with that model.
Sep 29, 2009 | Mitsubishi WS-55819 55" Rear Projection...
Sharp LC-32DA5U
sounds like youve had a pic tube go out,,probly just one and the other 2 are still good,,thats why it came bck on,,take it to a tv shop ,know ,,want be that much if its just one pic tube,,good luck
Oct 05, 2008 | Mitsubishi WS-55511 55" Rear Projection...
No picture on tv screen
try resoldering the vertical output IC. sounds like the cRTs are blanking due to the vertical. If that doesnt help you may need a new IC. While youre there look for signs of the CRt leaking as often it leaks right onto the vertical output section real close to the IC.
May 07, 2008 | Mitsubishi WS-55819 55" Rear Projection...
Mitsubishi Mod # WS-55315
On this model the timer led blinks when the tv is off if you have the timer set to turn it on. You can get the manual here.
Mar 13, 2008 | Mitsubishi WS-55315 55" Rear Projection...
Open Questions:
Mitsubishi VS-55705 55" Rear Projection Television Logo
85 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
