Question about Acer TravelMate 2300 Notebook
It's also about resume from standby
My notebook is travelmate 2300,can't resume from standby which i entered manually.and in case usb device might cause it,i unplugged all usb devieces before standby,but still.
do i need to upgrade bios or do sth else?and where to get new version of bios for 2300?
thanks
  • fornone Feb 03, 2008
    I checked drivers and bios u gave me and found what i have is already latest.I'll try using only ac to clear standby later.
    Thanks
  • 43 Answers
This URL will give you all the downloads you will need.
http://www.acerpanam.com/flex/acerdrivers/bin/drivers.html?CFID=145191&CFTOKEN=47327244
Posted on Feb 02, 2008
  • Gregory Young
    Gregory Young Feb 03, 2008
    Remove your battery from laptop.
    Using only power mains,press & hold down Start button.
    This should clear your Standy Mode
How i can boot up win xp on bootable usb on acer travelmate 2413lc
1st of all plug in the usb bootable device. Then:
When you start up your computer it should say something like press f2 or f8 or something for setup. Hold down that key when the computer is starting up then:
1. Search through the BIOS with the arrow keys and enter for the setting to change the boot sequence.
2. Change the boot sequence to have your computer boot from the device first.
3. Then save the changes and reboot your computer.
May 10, 2011 | Acer TravelMate 2300 Notebook
The USB Ports on my ACER TravelMate 2350 Series Laptop, I have deleted the USB Port files from Device Manager and the machine reinstalled them when I re-started but it didn't change anything. I downloaded...
I'm guessing your USB ports don't work or does it always ask you to install them. If you have your Windows XP license key at hand, please try downloading and installing the following...
Acer TravelMate 2350 XP Chipset Driver
Reboot. It might ask you to do a reactivation, or not.
Please recheck if your USB ports still work. If not, restart your machine, hit F8 continously until you get many options - choose the option "Safe mode" and press Enter. Check if it picks up USB in this Safe mode.
What you can also try, is that you have 3 different USB 2.0 ports on your machine. Try each one separately and see if one of them works. I would also recommend to see if the USB device you are trying to use is actually functional.
May 19, 2010 | Acer TravelMate 2300 Notebook
Doesnt see the USB device when pluged in
do you have more than one usb port if not check device in another machine make sure it works if it does then check usb human interface device under hardware devices under my computer properties if it has a yellow question mark re-install usb drivers for the computer not the device
Dec 12, 2009 | Acer TravelMate 2300 Notebook
My Acer LP - Travelmate 2300 Wireless is not working after system failure. I have re-installed with all the right drivers but cannot see any netwok. I was able to see a bunch of Wireless Network around my...
I too have problem with my 2300, I tried reinstalling with recovery cd, but two files on disk 1 are corupted. Can any one please help me, I need files 60ET4008.GHS and 60ET4009.GHS.
TDVNEWF
ltconsultants@hotmail.com
Oct 06, 2009 | Acer TravelMate 2300 Notebook
Scorpius K3NT USB Keyboard prevents resume after standby in Win2K
When entering standby, the usb ports go to sleep. Most motherboards allow you to tell the bios that you are using a usb keyboard. That should solve the problem. I keep an old ps2 keyboard plugged in and on the floor as a 'just in case'.
Jul 24, 2009 | Mini iOne / Qtronix Scorpius K3NT PS/2...
USB Port Problem
uninstall ALL usb devices in the device manager and reinstall. To reinstall, choose scan for hardware changes after you uninstall them, no software required.
Mar 20, 2009 | Acer TravelMate 2300 Notebook
My Acer travelmate 2300 usb ports aren`t working
What has changed most recently? did they work before? May be disabled in bios, need more info.
Jan 24, 2009 | Acer TravelMate 2300 Notebook
Hard drive for acer laptop 525 TE travelmate
You can use an external hard drive with an USB hard drive case and and connect it to your USB port
Jul 07, 2008 | Acer TravelMate 2300 Notebook
Acer travelmate(belongs to my grandson), one rear usb three side mounted. Rear socket had been damaged, plastic contact support missing, pins touching case. Before I looked at it, notebook crashed if any...
motherboard dont have fuse has diodes which act similar to fuses but wont be blown.only things that will blow in that area are transistors or capacitors;but if these were blown usb's would not be detected.
in device manager were its says working correctly it relates to software istalled and working properly it cant tell u that the hub connection is damaged internally.
if your usb's are on card and connected to motherboard they can be replaced otherwise if built into motherboard youll have to take it to repair shop.
if the only problem is when u connect a usb device and not causing any other problems,u could use usb hubs that go into the pcmcia
Mar 30, 2008 | Acer TravelMate 2300 Notebook
Computers & Internet Logo
132 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
