Question about Nikon Speedlight SB-600 TTL Flash
Sb600 doesn't fire well off the sb800
Was shooting a wedding last night and sb600 would only fire remotely off the sb800 when in very close proximity. I thought these flashes were supposed to work in unicen from across a larger room. Just wondering if I set up somethink wrong or how to troubleshoot.
    Scholar:
  • 33 Answers
The sb600 needs to be able to see the preflashes of the sb800, so this is probably caused by one of two things.  The first thing I'd check is whether or not the light sensor on the side of the sb600 was covered, blocked, or facing away from the sb800.  I've had problems outdoors when I forgot to have the light sensor face the camera.
If the sensor was facing the camera, it is possible that the flashes didn't have a good line of sight to each other.  That normally shouldn't matter, but if there is a high ceiling and lots of people, it could be the case.  I don't know if it will help, but in any case I would recommend using a StoFen Omnibounce on the sb800 to increase the likelihood that the light finds a direction where a surface to bounce off of is found.
Good luck.
Posted on Feb 04, 2008
Hotshoe and sync cable will not fire strobs. However, if I connect the sync cord via my SB800 the strobe will fire.... Help :D
What strobe are you using besides the SB800? Probably the best solution is to use a hotshoe extender for the mystery strobe (like an SC-15), and then set the SB800 in SU-4 mode (i.e. fire when any other strobe around it fires).
Sounds like the mystery strobe isn't triggering correctly with the sync signal that the body is giving through your adapter.
Mar 09, 2011 | Cameras
Black display on speedlight Sb800
You have a defective LCD assembly and it needs to be replaced . Check out the rest of the unit and see if it fires..
Berrie Smith Camera Repair
Certified in NIKON and CANON
Mar 29, 2009 | Nikon Speedlight SB-800 TTL Flash
I would like a dvd for the using of the Nikon SB800 flash
Blue Crane Digital DVD: Understanding the Nikon Flash SB800 and SB600
  • Mfr#
  • BC202
  • B&H# BLDVDNFSB800
THIS SHOULD HELP YOU
BERRIE SMITH CAMERA REPAIR
770-312-0719
bbmw@bellsouth.net
Feb 14, 2009 | Nikon Speedlight SB-800 TTL Flash
The flash won't turn on
what kind of flash ? SB800 ?Sb600 ?
or are you using compact..if you're using compact,I guess you'll be needing Manual mode and tweek something on the setting menu.
Jan 31, 2009 | Kodak EasyShare C763 Digital Camera
Question: Can my SB600 flash be used remotely from my d4ox camera? when taking photos?
For wireless flash you need two things:
1) Something to act as the controller.
2) A remote flash.
While your SB600 will work fine as a remote flash, the D40x does not have the 'built-in' capability to act as the controller (as some of the more expensive models do). Unfortunately, you would need a SU800 or SB800 to act as controller.
Matt
Apr 16, 2008 | Cameras
SB600 Works Erratically...
If red light on flash is blinking, flash is charging. In shooting rapidly, sometimes flash will go off even though it isnt fully charged. This can give dark shots. Flash eats batteries like crazy, best to always use fresh batteries for each shoot.
Apr 14, 2008 | Nikon Speedlight SB-600 TTL Flash
LCD moniter locking up on SB800
I would pack it back in to the box with a detailed description and send the flash back!
Jerry G.
Mar 30, 2008 | Nikon Speedlight SB-800 TTL Flash
SB800 Won't Remote
The channel on the flash for remote on the 4a withthe NIKON D70
If you are using the Nikon D200 then the channel is 1a ...
If you have any more questions contact
bbmw@bellsouth.net
Feb 04, 2008 | Nikon Speedlight SB-800 TTL Flash
Sb800 doesn't flash
Let's force the flash to fire:
nstalls four fresh batteries.
Turn on flash, do not connect to camera
Wait until flash is ready
Get a small wire with insulation and strip both ends about 1/8".
With one end of the bare wire lead, touch/hold CENTER TIP
Contact(silver pin from flash).
Make sure flash head is not pointing at your face.
With other end touch bare wire to OUTSIDE Contact (silver on
outside of hot shoe that rides into camera hot shoe rails-this is ground).
Flash should fires, gets a flash out of the flash tube.
If not, you have flash problems.
You most likely hurt the flash by using the dome filter on top of flash.
Over 80% photographers are doing this way when shooting flash photography. And 95% for wedding photographers.
This will shorten the life of the flash.
Even more with that adapter parked onto the flash.
Hope they are helpful to all photographers.
Suggestions or comments,
atdlee@netzero.com
Jan 15, 2008 | Nikon Speedlight SB-800 TTL Flash
SB800 firing but not syncing??
I had that same problem with the SB600 and the SB 800. Solutions; get a new one. After about a year of usage the sb600 started giving me that problem. It flashes but it does not sync. It still works as a remote unit, but not mounted on the camera. The SB800 just went to a coma last weekend. No sync at all, not even as remote unit, no strobe function, just a bright flash, when triggering the test button with new fresh batteries, it flashes at max power once and takes around 7 seconds to recycle. No multiple flashes at all. I had to buy a new one.
Jan 09, 2007 | Nikon Speedlight SB-800 TTL Flash
Nikon Speedlight SB-600 TTL Flash Logo
127 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
