Question about Hobart A200 Stand Mixer
NEED A WIRING DIAGRAM FOR A A200 HOBART MIXER
NEED A WIRING DIAGRAM HAVE THREE BLACK WIRE COMING OUT OF BACK OF MIXER AND THEY HAVE NO MAKINGS ON THEM I TRACED THEM TO THE ON OFF SWITCH THE WIRES COMING OUT OF SWITCH HAVE NUMBERS ON THEM I AM NOT SURE IF THIS UNIT IS 220 OR 110 BOUGHT IT AT A AUCTION AND THERE WAS NO PLUG ATTACHED THANKS
  • lech olek May 09, 2009
    I NEED A WIRING DIAGRAM FOR A A200 HOBART MIXER
  • 3 Answers
I need Hobert A 200 wireing diagram
Posted on Sep 03, 2010
I NEED TO KNOW HOW I CAN HOOK UP WIRE OF SAFE GARD
Posted on Oct 16, 2008
    Scholar:
  • 81 Answers
I have a wiring diagram for the standard A-200. If you send me your e-mail to me I will send it to you. capt_rick1912@yahoo.com
Posted on May 31, 2008
  • 36 Answers
I had a look on google and came up with a service manual. not sure if this has the wiring diagram but the only other thing i can suggest is to contact te manufacturer direct. Go to http://cgi.ebay.com/HOBART-A200-20-QUART-MIXER-SERVICE-PARTS-MANUAL_W0QQitemZ160203114233QQcmdZViewItem
hope this helps.
Posted on Feb 02, 2008
Why My Hobart A200 20 QT Mixer ML #104858 Motor Is Smoking?
I think... without knowing that motor... that the capacitor is a start capacitor, and that the start switch may be trying to "start" the motor full-time instead of switching it out of circuit after it figures that the motor has spun up. I may be wrong - that design may be a capacitor-run motor (similar to a three-phase motor) - but I'm betting it's a start-only capacitor.
If you know someone with a capacitance meter, you could check the capacitor - for both capacitance (to be sure it matches the label) and leakage. Easy way to write that one off. Alternatively, you could rig it such that after the motor's wound up you could manually disconnect the capacitor and see what happens - either the motor stops or else the smoking issue stops.
Whatever you do, don't let it smoke very long. The varnish on the windings is only so thick.
Jul 31, 2014 | Hobart A200 Stand Mixer
Hobart mixer
hi Gassman, below you will be able to find a link on parts assembly for the mixer, you will have an idea on how to tear off the parts, get them cleaned and place them back, like a regular maintenance.
Hobart A200 Mixer Parts Assembly
More parts assembly for Hobart A200 Mixer
hope this helps.
Aug 19, 2008 | Hobart A200 Stand Mixer
A200 wiring diagram
The wiring diagram can be found here:
https://my.hobartcorp.com/kroger/TechnicalServiceManuals/A200%20Technical%20Manual.pdf
Mar 23, 2011 | Hobart A200 Stand Mixer
I need a wiring diagram for the Hobart H600 which has a multi tap motor on and i would like to change the voltage on the motor to 200volt single phase 120/208 or even 120208 3phase. The wiring diagram is...
You cannot wire a three phase motor for single phase and you cannot wire a single phase motor for three phase. If you have a three phase dual voltage motor your options are 220 or 440 volts. If you have a single phase dual voltage motor your options are 120 or 240 volts. A 208 volt Hobart motor will only function correctly on 208 volts and is not dual voltage.
Aug 05, 2010 | Hobart H600 Stand Mixer
Hobart A 200 Mixer
There are four possibilities to look at here. Assuming your mixer has a normal capacitor start motor (older a200's used a different style motor), possibilities are, in order of likelihood:
Motor start capacitor
Start switch (electronic or mechanical)
Burned wiring
Motor start winding
The start capacitor is located at the rear of the mixer. Remove the rear cover (4 screws) and pull the cover towards you. Disconnect one wire from the capacitor and test with any multimeter.
The start switch, if electronic, is able to be tested, but not very easily. Once you've eliminated the other possibilities, it's time to replace the (electronic) start switch. If the motor has a mechanical start switch, it's easy to test: Remove the two wires at the rear of the motor and test for continuity with the motor stationary. A multimeter should show near zero ohms for a good mechanical start switch.
Burned wiring should be easy to spot with some careful inspection around the motor, capacitor, and start switch.
Start winding: Look closely at the stator (stationary part of the motor). If some of the copper windings look significantly darker in color than the others, it's likely the start windings were overheated (the start windings are the thinner copper wires - if you look closely, approximately half of the wires are thinner than the other half). Look for a wiring diagram behind the power switch and determine which wires leading to the start switch and/or capacitor are for the start windings and test for continuity across the start winding. You should read a fairly small value such as 5 - 15 ohms. Values significantly outside this range could indicate a partially open or partially shorted start winding.
Jun 09, 2010 | Hobart A200 Stand Mixer
Stationary Start Switch part needed
Go to your local Motor repair shop. They usually have used ones laying around or can sell you a new one.They wont try to sell you the new improved solid state controlled version!
Dec 14, 2009 | Hobart A200 Stand Mixer
A - 200 3 speed mixer needs a wiring diaram
how do you know diagram is wrong , you could have wired it wrong the timer kit i belive comes with 3 or 4 different diagrams for that mixer you need to pick the right one
Aug 27, 2009 | Hobart A200 Stand Mixer
Hobart 20 quart mixer
Hi im a service tech for hobart.I cant give service manuals out because i could lose my job but i can step you thru your problem with the mixer,let me know.
Aug 21, 2008 | Hobart A200 Stand Mixer
Whining noise in all three speeds.
There is only one bearing in the back a an A200, the rear motor bearing. Page 12 -- Otherwise I'd look for something rubbing the motor. (wire, capacitor shield) The two back side covers are easy to remove, two screws each.
http://www.hobartlink.com/extranet/extranetmanualsandcatalogs.nsf/57866D624A678E7385256CB0007232DA/$File/F-19357%20(05-95).pdf
The timer is also in the link. The part is not cheap, but easy to install.
Jun 20, 2008 | Hobart A200 Stand Mixer
Hobart A200 Stand Mixer Logo
2,345 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
