Question about Microsoft Windows Vista Ultimate Edition
Adobe Photo Deluxe 2.0
Adobe will not allow me to save a PICS to file. When I try to save the program shutdown. Up until a week ago I was using both Windows 2000 and XP with not problems. Only Vista OS
  • lansing Feb 19, 2008
    I can't save any photos now with Vista.
  • OldManStan Mar 31, 2008
    I'm having the same problem with PhotoDeluxe. I'd been using it for 6 months with Vista and it used to let me save the pics I worked on but now whenever I try to save the program completely shuts down. I've uninstalled and reinstalled it and it still does the same thing.
Go into the PhotoDeluxe2.0 CD ROM file list, right click on setup.exe and then go to the compatability tab. Select Win 98/ME. Hit OK. Then double-click on setup.exe. Program should install on Vista. Then find setup.exe on your hard drive, and set the compatability to Windows 98/ME. Program runs, but says something about not being able to load 16-bit driver. Just cancel out of that popup window. Program works fine...for me...so far.
Posted on Mar 26, 2008
I had the same problem with Adobe Photo 3.1when I upgrade to Windows XP...Not sure it will work with Vista but worth a shot.. Uninstall Photo Deluxe through ADD/REMOVE Programs..Go into programs and delete the Adobe Photo folder..Place the photo deluxe CD in the rom drive. If it auto runs cancel the auto run. Open My Computer and right click on Photo Deluxe (D) drive or the drive you used. Click on Explore then right click Setup.exe. Setup window will appear. Now click on the Compatibility Tab. Set it for Windows 98 or Me then click apply then click ok. Now go back and run Setup. Do not auto run. Hope this helps worked great with my Windows Xp.
Posted on Feb 29, 2008
Installed adobe photodeluxe on my xp and it says it doesnt have enough rtam to run program. I JUST ADDED MORE RAM 1 G AND IT STILL DOESNT WORK
Posted on Apr 20, 2009
  • indigocrow Mar 20, 2011
    For Photodeluxe 2.0 "Not Enough Ram" to run program error message:
    For Windows XP and older
    Go to cotrol panel
    open System
    Click on Advanced
    Be sure PROGRAMS is selected under both Processor scheduling AND Memory usage.
    Under Virtual Memory click CHANGE.
    Under white box, says Drive: C [the mane of your compter]
    under that is Space Aavailable: this is where your number of available MB appears.
    Look at this number carefully. My number is 106270 MB available. Choose a number LESS than the available space but allowing enough space left over in case your system needs to do a restore because it is from this available space that restores run from. The LESSER number I chose in my case was 110000. This number goes into the BOTTOM WHITE BOX called Maximum size (MB). Go ahead, delete whatever number is in there now and put your newly chosesn number in that box. Now, here's the important part. Your new number -- the one you just typed into the Maximum sixe box -- divide that number EXACTLY in half, and type that HALF number into the box ABOVE the Maximum size box where it says Initial size (MB).
    It is imperative that the number on top EXACTLY one half on the number on the bottom, or Photo Deluxe won't run. Click SET, then APPLY, the OK> You will be prompted for one of two things. It will say you have to restart. DO SO> or it will say to choose a smaller number for your MAXIMUM size entry. No big deal. Just keep using a little bit (500 MB or so) smaller number in that MAXIMUM sixe box, being SURE to change the top number to EXACTLY half of your new number until when you click set, is prompts you to go ahead and restart.
    I wouldn't go to the compatibility feature in PhotoDeluxe and change it to run under a different system. It seems like it makes sense to do so if your operating system is upgraded from the original system that Adobe Photo Deluxe was made for, but it cause error messags, and lots of other issues, when all you really need is to adjust that Virtual Memory number. Hope this works for you. Adobe PhotoDeluxe 2.0 ROCKS!
  • 43 Answers
Patience!!!
Vista does not seem to work well yet with Adobe(older versionS).
Adobe CS3 is the only prog. @ present able to handle Vista.
If you are using older versions,stay with XP & 2000
Posted on Feb 02, 2008
    Scholar:
  • 50 Answers
Here's is what is happening with the memory problem. Older programs such as PhotoDeluxe 2.0 and 3.0 do not know how to read higher ram and video memory. The program is reading any thing over 512mb video or ram as a negitive number . aka. you have +2 gigs of ram on board, PhotoDeluxe is reading it as negative 1.96mb ram. Another issue with the virtual memory is back when PhotoDeluxe was released a 1 gig hard drive was not even thought of. So PhotoDeluxe is once again reading negative Virtual Memory. Want PhotoDeluxe to work? What I did was just got an older Pc with a tiny 10gig IDE HDD drive and 256mb ram and installed Widows 95 on it and just use a flash drive when I need to work on a picture. The same thing is happening with the Older version of Music Match's Audio editor and Tag editor.
Their is a way to fix Adobe and Music Match to run on a newer operating system but unless ya'll ask I m not typing as it takes a lot of mods to the actual program its self. If ya want to run them on Vista or Windows 7 it is able too, just ask here on this page and I''ll post it.
Posted on Jun 27, 2010
  • 1 more comment
  • jcmgmi Sep 26, 2010
    Okay, Im asking. I have Adobe hoto Deluxe 1.0 Business Edition. It was working on Windows XP but my computer died and I had to purchase a new one. It has windows 7 and my CD for Adobe just sits there and does nothing. Can you help me?
  • Rolan Cowart
    Rolan Cowart Sep 26, 2010
    This will fix the Export Image dialog box hang/crash (UNABLE TO SAVE IMAGE). With all versions of Windows after 2000 pro.
    Ok, Here's the problem, it was caused by Windows Update. The new update covers issues with Internet Explorer and the font folder from the PD Deluxe CD. If you remove all of the recent updates for Internet Explorer (restore to it's original state is best as it will restore PD File commands for the Fonts) your Adobe 2.0 and 3.0 will allow you to export your pics. Provided you have already followed the above past solutions completed.(Start with the 1st and end with this) If security is an issue don't use Internet Explorer any more use another secure browser such as Mozilla, these browsers are not proprietary to Windows Explorer.
    *REFERENCE NOTE *The Export Image in PD v1-v4 uses Windows Explorer for the save as dialog box which was later fixed with PS Elements to use its own command box. Windows Explorer and Windows Internet Explorer use the same basics of each other. If I confused you let me know and I will try to elaborate as this is just a quick reference for more advanced users.
  • Rolan Cowart
    Follow Compaqguy200 fix which i copied below here for easy access.
    This worked for me on my Windows 7 pro. I run all 4 versions of adobe with no problems on Win 7 I am a vivid user of Photo Deluxe. Just remember you cannot run PS Elements or any other newer editor at the same time nor in the same session. Use PD FIRST then use other editor is fine, but memory error with Virtual Memory HDD will occur if you do not restart your computer before returning to PD V1-V5. I haven't figured out a fix for this but will post when I do. Also make sure to setup your font installation from CD the same way as you do the PD Setup. When the dialog pops up to install the fonts just say no and install after setup PD finishes and restarts **(Some CD versions install differently pending on if yours came with a printer bundle or if yours came from purchased disks.)** A little thought and patience will get you there!
I had the Same Problem
But it is fixed now
I Followed solution no2
And was amazed when i seen it was working ok
Thanks again
Posted on Oct 02, 2008
  • prangerjohn Dec 06, 2010
    Save pix as gifs
    File ---> Send to -->GIF89a Export
Solution #2...your absolutely right! I did just what you said and it worked. One minor point of clarification. After you set up photodeluxe (as you described) go to the .exe start icon, right click on it and click on properties to set the compatibility. As said above choose "windows 98 and me" at least thats what mine says. All the rest is spot on. Thanks a million!
Posted on Apr 08, 2008
Folder Corrupt and Trying to Install Adobe Photoshop Elements 9
First variant you may use if your .psd file was seriously damaged
https://www.repairtoolbox.com/photoshoprepair.html Photoshop Repair Toolbox
Second solutions are showed as knowledge bases about Adobe Photoshop
http://www.techrepublic.com/forums/questions/repairing-damaged-adobe-photoshop-psd-files/
https://forums.adobe.com/message/6698481
Third one is a guide from Adobe
·Open "My Computer." In Windows XP, the icon is on the desktop. In Windows Vista or Windows 7, you must access this via the "Computer" option in the Start menu.
·Double-click the "C" drive, followed by the "Windows" folder inside. Locate the temporary Photoshop folder, which will look similar to this: "Photoshop Temp6382948398." Double-click the folder when you find it.
·Locate the file inside the temporary folder that matches the name of the corrupted file. Double-click it to open it in Photoshop.
· Click "Save As" in the "File" portion of the main menu bar. Save it in a different location and under a different name
Sep 16, 2015 | Adobe Photoshop CS for PC
The Adobe Reader is uploading the pictures to my computer but we cannot find instructions on how to save them there for future access. My camera is a Canon Powershot A80, and my operating system Windows...
I don't know why you're using the Adobe Reader to download your pics. You should be using the software that came with the camera or software that is already on your computer. The easiest procedure and the one the pros use is to use a separate card reader. You create a folder on your desktop and using the card reader, drag and drop your picture files into the folder. Once there, you can view them, save them to places such as "my pictures", e-mail them, etc. typrice_152.jpg
Mar 23, 2011 | Canon PowerShot A80 Digital Camera
No Adobe Acrobat Reader anymore
Don't worry, try uninstalling it using uninstall program like "ccleaner". You can easily uninstall it and again reinstall the adobe reader. If you still have the same problem, use this Foxit reader as an alternative for the time being if in case, you need to read the pdf file immediately. Good luck. Thanks for using FixYa.
Jun 07, 2010 | HP Compaq Presario C700T
I can transfer the photos from my camera to the PC with the software that came with the camera. When I try to use their e-mail feature I get an error message that says "mail not sent". Yet a few weeks...
Hi , I suspect that your picture files are too big, to transfer to the provided e-mail function of your software. Try changing the resolution to the lowest size a try a few shots. And try to send again. You should be able to save your pictures in a specified directory on your hard drive. You then can attach them to i.e. Microsoft Outlook, or similair e-mail program. I hope that helps.
G. Evans
Ontario, Canada
Jul 09, 2009 | Fuji FinePix F480 Digital Camera
I need to repair windows xp home edition
u need to install foxit redaer in your pc or u need to intall adobe acrobet reader in your pc here u can download acrobet reader & install in your system acrobet reader
Jan 16, 2009 | Microsoft Windows XP Home Edition
How to schedule system shutdown in windows xp
Go to Start >> Run type CMD and click Ok
in the command window
just use the AT command:
AT 9:00 SHUTDOWN -f
the schedule service must be running while using the AT command.
But normally it word well
Dec 30, 2008 | Microsoft Windows XP Professional
Restore windows 2000 like-new state
check if have backed up your system state before installing things on windows 2000. then you can restore the system state then delete all the program's folders by hand
Jul 06, 2008 | Microsoft Windows 2000 Professional for PC
Unable to download adobe flash player 9
Download Adobe from this link....
http://www.softpedia.com/get/Internet/WEB-Design/Flash/Macromedia-Flash-Player.shtml
http://www.filehippo.com/download_flashplayer_ie/
Save the file to the desktop location when prompted, then run the adobe program. file
Goodlucl :-)
Jun 05, 2008 | Microsoft Windows XP Home Edition
Microsoft Windows Vista Ultimate Edition Logo
3,405 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
