Goodmans 19in lcd tv- there are static green and blue pixels visible on screen can this be repaired?
  • Linda F Feb 05, 2008
    Many thanks. I've now got an idea whats wrong.
    Problem Solver:
  • 40 Answers
Need make and model for accurate diagnosis...usually something like this would be a seine bd or a scaler bd........
Posted on Feb 03, 2008
Samsung LCD TV diagnosis. Possible tcon board?
T-con board is causing all your problems. You are correct. You can get parts from here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Sep 21, 2015 | Samsung Televison & Video
My Sony 32" TV with CCFL Back-light module started having green tint. On black colored images, green pixels are clearly visible.
according to your observation we called abnormal picture & common mode choke coils are defective l3000,whech are near to LVDS connecter there are 3 coils & must change all coils after replacing these coils your set will ok
Jul 10, 2015 | Sony KLV-32S550A 32 inch Multi-System LCD...
My toddler squirted milk at my goodmans lcd tv and now it has several vertical blue lines running down the screen but is working. It Is just out of guarantee, can it be fixed or do i need to buy a new...
The lines are caused by pixel connections that have been shorted by the milk - the defect is inside the LCD panel itself. This is unfixable, the panel would have to be replaced at a greater cost than a new tv.
Time for a new one.
Jul 14, 2011 | Televison & Video
Switch TV on then a blank red screen appear then a green and then a blue which then just repeats that sequence of colours every second. The remote control packed up working some month before. - 2 year old...
turn TV on, let the Tv cycle through the three colours, then using the remote press the menu button followed by the standby button. press standby button again and it all comes up working.
andy
Sep 20, 2010 | Goodmans GTVL32W27HDF 32 in. LCD TV
A gree speck on the screen
It's an "open" pixel. It is unable to close to block the light, so it appears as a dot. The color white is made up of red, green and blue. So, a single open pixel will have just a single color. If you have had the TV for just a short time (< 30 days), many retailers will exchange the TV. However, if you have had the TV longer, you should contact the manufacture. The pixel specifications will vary from manufacture to manufacture... but some manufactures have a zero dead pixel specification and they will repair the TV at no cost to you. I hope this was helpful, best wishes.
Apr 17, 2010 | LG 42LC2D 42 in. LCD HDTV
Whats the difference between a LCD and plasma
Answer: Outward appearances are definitely deceiving when it comes to LCD and Plasma televisions. Although both types of televisions are flat and thin, they employ different technology in an attempt to deliver similar results. Plasma TV Overview Plasma television technology is based loosely on the fluorescent light bulb. The display itself consists of cells. Within each cell two glass panels are separated by a narrow gap in which neon-xenon gas is injected and sealed in plasma form during the manufacturing process. The gas is electrically charged at specific intervals when the Plasma set is in use. The charged gas then strikes red, green, and blue phosphors, thus creating a television image. Each group of red, green, and blue phosphors is called a pixel (picture element). Although Plasma television technology eliminate the need for the bulky picture tube and electron beam scanning of traditional televisions, because it still employs the burning of phosphors to generate an image, Plasma televisions still suffer from some of the drawbacks of traditional televisions, such as heat generation and screen-burn of static images. LCD TV Overview LCD televisions, on the other hand, use a different technology (see also question #1 for this same explanation). Basically, LCD panels are made of two layers of transparent material, which are polarized, and are "glued" together. One of the layers is coated with a special polymer that holds the individual liquid crystals. Current is then passed through individual crystals, which allow the crystals to pass or block light to create images. LCD crystals do not produce their own light, so an external light source, such as florescent bulb is needed for the image created by the LCD to become visible to the viewer. Unlike standard CRT and Plasma televisions, since there are no phosphors that light up, less power is needed for operation and the light source in an LCD television generates less heat than a Plasma or traditional television. Also, because of the nature of LCD technology, there is no radiation emitted from the screen itself. Plasma vs LCD The ADVANTAGES of Plasma over LCD are: 1. Larger screen size availability. 2. Better contrast ratio and ability to render deeper blacks. 3. Better color accuracy and saturation. 4. Better motion tracking (little or no motion lag in fast moving images). The DISADVANTAGES of Plasma vs LCD include: 1. Plasma TVs are more susceptible to burn-in of static images. 2. Plasma TVs generate more heat than LCDs, due to the need to light of phosphors to create the images. 3. Does not perform as well at higher altitudes. 4. Potentially shorter display life span - this used to be the case. Early Plasmas had 30,000 hours or 8 hrs of viewing a day for 9 years, which was less than LCD. However, screen life span has now improved and 60,000 hour life span rating are now common, with some sets rated as high as 100,000 hours, due to technology improvements. LCD television ADVANTAGES over Plasma include: 1. No burn-in of static images. 2. Cooler running temperature. 3. No high altitude use issues. 4. Increased image brightness over Plasma. 5. Lighter weight (when comparing same screen sizes) than Plasma counterparts. 6. Longer display life used to be a factor, but now LCD and Plasma sets both have at least 60,000 hour or higher lifespans. DISADVANTAGES of LCD vs Plasma televisions include: 1. Lower contrast ratio, not as good rendering deep blacks. 2. Not as good at tracking motion (fast moving objects may exhibit lag artifacts) - However, this is improving with the recent implementation of 120Hz screen refresh rates and 240Hz processing in higher-end LCD sets. 3. Not as common in large screen sizes above 42-inches as Plasma. However, the number is growing fast, with 46 and 47-inch screen sizes becoming more common, and some LCD sets having a screen size as large as 65-inches also available to the general public. 4. Although LCD televisions do not suffer from burn-in susceptibility, it is possible that individual pixels on an LCD televisions can burn out, causing small, visible, black or white dots to appear on the screen. Individual pixels cannot be repaired, the whole screen would need to be replaced at that point, if the individual pixel burnout becomes annoying to you. 5. LCD televisions are typically more expensive than equivalent-sized Plasma televisions (although this is changing), especially when comparing EDTV Plasmas to HDTV-LCD Televisions. For a more detailed look at the LCD and Plasma comparison, check out: Should I Buy an LCD or Plasma Television?
Jan 18, 2010 | Panasonic TH-42PWD6UY 42 in. HD-Ready...
Horizontal green bar on plasma tv, please help!
what it is, is on plasma screen tv's and LCD, they can get too cold, too hot, or over-powered. when any of this happens with just the right conditions, a thing called "dead-pixel" occurs. basically, the pixel will not respond any longer to tbhe electrical signal, so will not change with the rest of the screen. its basically broken
Sep 14, 2009 | Samsung LN-T4665F 46 in. LCD Television
Samsung le32r7 2yrs old
Well the shadow is caused by the pixels going dead. There is a term for this "dead pixels" if its still under warrenty take it in. If its not you may be able to get a new screen for it on Ebay.com I use ebay a lot and boy I found thing I though I would never find people are very informative and you will probably need to take the screen you bought to a repair shop and have them place it in for you. this is not a quick fix so I hope this helps.
Apr 23, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Lcd tv with wrong color on one pixel
LCD screens occasionally have what are called "Stuck pixels". There is a tutorial in wikihow which might help you out here:
http://www.fixya.com/manuals/w153177-fix_stuck_pixel_lcd_monitor
Try that and see if it helps. Stuck pixels are actually a slighty common problem.
Jan 01, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
Toshiba regza lcd 46x3500
This is what is known as a dead pixel. If you have a standard wide screen lcd monitor it has over 1 million pixels. It is not super un-common for one to go bad. It will either always be dark or in your case always be lit. It is not worth it to repair, and in most cases unless you have multiple dead pixels with in a square inch of screen, it is not covered under warranty either.
Each pixel is individual and the problem will most likely not spread.
Jul 08, 2008 | Televison & Video
Televison & Video Logo
67 people viewed this question
Top Televison & Video Experts
