Question about Sony KP-65WS500 65" Rear Projection Television
Color problems and tv shutting off
The color is very red, and the color flickers and changes. Also, the set starts flashing green and then shuts off. I called a few repair places and they said I would need to replace all 3 tubes at great cost, is that the case? Thanks.
  • rezon Feb 24, 2008
    Similar problem, though mine isn't as dramatic. It just flashes green every so often. I feel it is a symptom of a larger problem that could end up being as bad as the other poster's problem.
    Thank you.
My tv screen turns red as it heats up and the repairshop told me it would cost $600.00 for a new red projection gun how ever I don't think thats the case because it is a heat related issue. I think an ic or transistor is going bad and goes into saturation when it gots warm. I will be spraing some components with freeze spray and if my hunch is correct the color will temporarly correct its self when I spray the right component.
Posted on Jul 10, 2008
I have a 50 inch DLP samsung and it wont power on after making a lot of noise (I replaced the lamp) worked fine for a few days now the red light and the right side green light is blinking. any sugge
The answers above are correct. It's either the lamp or the color wheel. Testing the lamp is pretty straight forward. Use an Ohm meter to see if the it's filament has continuity. It's unlikely that a good color wheel would fail immediately after changing the lamp. Look to see if some wiring is out of place and rubbing the wheel causing the noise you described. A jammed but otherwise good color wheel would cause the TV to shut down and display an error code.
Sep 12, 2014 | Samsung HL-S5087W DLP TV
Mitsibushi WD-60638 , just replaced the lamp now tv flickers and shuts off with a solid red led light , can anyone help me fix this ?
not sure but check internal fan is functioning correctly...I had same problem with a hitachi
Feb 23, 2013 | Televison & Video
My dell E207WFP lcd first flickers and then flashes red,green, blue, black, white and green color after some time of use ...
some of the capacitors are blown on the boards that are inside the unit
the lcd is on its way out. I recomend when getting a new one to turn it off whenever you are not at your pc. even though it goes to sleep after a while of no activity there is still a current going through the unit because if you move the mouse it will wake up. I know this because I was a bench technician and I have done board level repairs. These capacitors have anywhere from a 20000 to 40000 hour life span so when not at your pc turn it off!
Nov 23, 2012 | Dell E207WFP 20" Widescreen Flat Panel LCD...
Wd65738 flickering
I had a TV do that about a year ago, the repair man said it was the color wheel inside the tv. I changed the bulb to see if he was BS'ng me and eventually got the manufacturer to send a color wheel and I change it myself, was very easy...TV works fine ever since. Hope this helps
Jul 10, 2012 | Mitsubishi WD-65738 DLP TV
Red, Blue, Green white flashing screen
https://www.bleepingcomputer.com/download/windows-repair-all-in-one/
Dec 04, 2017 | Acer AL2016W 20" LCD Monitor
I own a KP-57HW40 set that has a color and shut off issue. Started as a green tinge problem to the screen after watching for a few hours. Started becoming more and more frequent a couple months ago....
IF YOU HAVE A RA 6 CHASSI THE TUBES RUN HOT ANOID CATHOD SHORT IF YOU TAP ON THE NECK OF THE TUBES AND GOES TO SOLID COLOR THEN SHUTS OFF YOU HAVE TO REPLACE THAT TUBE ALL 3 TUBES WILL HAVE THIS PROBLEM
Feb 09, 2010 | Sony KP-57HW40 57" Rear Projection...
Green screen and shut down
TV screen flashes with Red lights for few times. sometime it shut down TV or red color is lost showing pictures without Red looks terrible. Any solution
Sep 17, 2008 | Sony KP-51HW40 51" Rear Projection...
Image flickers and colors off
I have the same problem as philvo. I was watching, the projector was operating normally, I heard a snap, there was a flash of light behind me I believe, and my Mitsubishi XD300U projector went to a black and white picture. That is all it will show now. All lights show normal operation. I would like to know if it is worth getting repaired. Does anyone have any ideas?
Jan 07, 2008 | Mitsubishi XD300U Multimedia Projector
Sony KP-65WS500 65" Rear Projection Television Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
