Question about Maytag MER6772 Gemini Electric Kitchen Range
Maytag MER6772 - Oven bake element not working even after replacing it.
I have a Maytag MER6772 electric oven. The top oven bake element stopped working. The broiler still works. Replaced the bake element but it still does not work. Both elements work in the bottom oven. No error codes display. The oven is 7 years old.
  • 3 more comments
  • Anonymous Feb 28, 2008
    I HAVE HAD MY OVEN FOR 7 YEARS ALSO, AND THE OVEN HEATING
    DISPLAYS DO NOT WORK. THE ONLY WAY I CAN USE MY OVEN IS WITH THE AUTO START FOR THE BOTTOM OVEN ONLY AND NOTHING ELSE WORKS IN THE OVEN.
  • Anonymous Mar 14, 2014
    When turning oven on to bake the broiler comes on also and when it reaches the set temp the broiler stays on and continues to heat
  • Anonymous Mar 22, 2014
    oven element replacement
  • Anonymous Mar 27, 2014
    how to replace the bake element on a maytage gemini oven
  • Anonymous Mar 29, 2014
    THE OVEN AND STOVETOP ISNOT WORKING.IS THERE A RESET BUTTON
Replaced bottom element in oven , now neither element works ?
Posted on Jun 15, 2013
To find service information for your Maytag Model go tothis link
http://www.servicematters.com/
When on this site, click on Maytag Historical Service Library.
Then click on Maytag Service Library.
Click on term and conditions
Click on Literatur by Model
Enter Modle number MER 6772
Clck go
You will be able to print or download the service manual for your model
Your problem may be the bake relay on the clock or wiring.
Posted on Feb 09, 2008
These ranges have a tendency to blow out either the solder joints or the relay leads on the PC board of the main controller when an oven element fails. Apparently there is a current surge as the element fails which causes this.
Check these threads and you will see others who had the same problem.
In my case, the lead to the oven relay vaporized so I could not solder it back. The relay on my MER6755AAS is a Song Chuan 832-1C-F-C-12VDC. I searched the part on the web and found 832-1C-F-S-12VDC in stock at an electronic distributor which is the same relay in a sealed, washable version for
$ 2.88.
I soldered in the new relay and everything works fine.
Note these relays are not available as spare parts. Only the entire control assembly is sold for about $270.00 An official service person will only replace the whole assembly, but if you do this on your own you can save big $.
There are 7 of these relays on my control, so I ordered 7 relays for any future repairs.
Ken
Posted on Oct 31, 2013
Getting tu the heating element on a maytage oven model #mer5755qab how do I get to that element . is it on the top or under the botto,
Hello Jerry,
That bake element is accessed from under the floor of the the oven...in th erear of the floor is a couple screws if ya remove those ya can pull up the the oven floor up and out from the rear to the front the bake element will under of that floor.
BEFORE ATTEMPTING THAT BE SURE TO DISCONNECT POWER TO THE OVEN
Sep 30, 2011 | Maytag MER6772 Gemini Electric Kitchen...
The bottom oven is heating up very slow.
If you are having problems with your electric oven heating up too slowly, not being able to maintain temperature set point, or wild variations in temperature, then you probably have a bad baking element in your oven.
The bake element is the bottom element in your oven. The life span of these elements can vary depending on the usage of your oven and the quality of the element. Anything electric has an unpredictable lifespan. Elements made on the same assembly line can vary greatly in how long they last. But when the element burns out it will need to be replaced to have your oven work properly.
The thing the fools many people is that many ovens will use the broil element to preheat the oven and then switch to using the baking element only. When this happens the oven will no longer heat and will cool down. The unit may sense this and activate the broil element again which will cause wild swings in temperature and also can cause food to burn on the top self or not bake properly.
If you can see the elements, watch them and see if they both get red hot when initially warming the oven. If only the top, broil element gets hot then you have a burned out element or a bad contacts where the element plugs into. Usually lifting the element and pulling out on it will release the element. If the contacts are discolored or pitted then they could be causing your problems. By using an ohm meter you can check the resistance of the element. If you get no continuity through the element it is no good.Bad elements will often have blisters, bubbles, or even burn in two.
If the element contacts are bad, make sure the you replace both the element and the receptacle that the element plugs into. Replacing only the element will only temporarily solve your problem.
Jan 23, 2011 | Maytag MER6772 Gemini Electric Kitchen...
My top oven on the maytag "gemini" doesn't work! it is a gas oven.
1) Confirm if its just the bake or both bake and broil that doesn't work. 2) If its just the bake you will most likely need to replace the bake ignitor. 3) If its both you need to test for voltage output from the electronic control to the ignitors.
Jan 13, 2011 | Maytag MER6772 Gemini Electric Kitchen...
No power to upper oven 'bake' heating element.
Sounds like you have it figured, need to spend some moola..........
You can ohm out the sensor to the oven should be about 1100 ohms at room temperature.((the sensor is the little rod with two wires attached to it sticking in the oven, as temps change resistance changes which is read by the board) The upper and lower oven sensors are probably the same,you could just swap them to test, but probably not necessary,might also be confusing if you do not do a lot of testing on a regular basis. Remember to unplug unit for safety.
The bake element if it was not bad should be about 20 ohms, bad would read open........
Feb 21, 2010 | Maytag MER6772 Gemini Electric Kitchen...
My lower and upper oven wont heat up
since either one is not working id say the clock assy is bad. we replace alot of btm oven baking elements ., but your clock is what sends power to the bake elements . so suspect clock. not a cheap repair
Sep 19, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Oven won't stay hot
You probably need to replace the baking igniter, (Igniter,bake burner
Part Number: AP4102011 made by MAYTAG
Feb 12, 2009 | Maytag MER6772 Gemini Electric Kitchen...
After cleaning MER6775AAB, upper oven has stopped working
See if the top heating element is open. Also check the switch that feeds power to the element.
Aug 28, 2017 | Maytag MER6772 Gemini Electric Kitchen...
Bake element doesnt work everything else does
hi there,
the bake element can melt for various reasons, however, i think that you problem lies somewhere else.
here is the service manual. have a look through it and let me know if i can be of more help.
http://www.servicematters.com/maytag_library/docs/16010107.pdf
Sep 09, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Main control panel
need to have a service company check the bottom oven elements first, the replacement part has only a 90 day warranty on it. if it is the control again ???????????????
Apr 10, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Top Oven Stops Working
Sounds like a bad sensor for the oven here is the link to the repair manual to help you out
Feb 10, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Maytag MER6772 Gemini Electric Kitchen Range Logo
1,732 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
Sal DeAngelo
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
