Question about Samsung HC-P4241W 42" Rear Projection HDTV-Ready Television
HX-P4241W appears yellow. Left and Right of screen are yellow
I am currently trying to figure out what is wrong with my tv. It is a Samsung HC-P4241W and it is only 2 1/2 years old.
All the whites look yellow. The left and right of the screen are yellow. Any idea how to fix this. Is it possible the red,green and blue need to be realigned?!.
Any help would be appreciated. I will give me indepth information if needed.
  • lexilait Feb 12, 2008
    Hello, for me same tv and problem, yellow / orange colour dominates, i cleaned the lenses and seems that the blue is weaker than the others, I tried adjusting contrast, colours, everything...without success.
    maybe the 3000h lamp is getting old and weak, on the samsung website they say the lamp is weak at it's life end...but I don't know what kind of lamp i would need for the TV and where I couls find one at better price...if this is the problem.
    Scholar:
  • 90 Answers
Yellow is the lack of blue. It can happen when you are running your contrast - which is your overall light level - too high.
Try turning down your contrast. On CRT tech, contrast should always be run at half what the factory allows as full, on the user controls. Full up is what calibrators call Torch Mode, and is NOT the way to get performance to be in the linear operating range of CRT tech.
If your sides are more yellow than your middle, your set may need lenstriping. Mild yellow on the sides is not uncommon, and usually not noticed. But heavy yellow on the sides would indicate that the blue image needs work on white field uniformity.
Yellow is the lack of blue, in CRT tech.
Mr Bob
Posted on Feb 04, 2008
6ya staff
SOURCE:
When i turned on my Hc-p4241w i smelled a burning smell then the color started looking 3d, i took a flashlight & looked through the left side of the tv and saw a orange glowing inside and i shut the tv...
Your Convergence output is burnt.DONT turn that TV on until convergence IC's are replaced,orange glowing inside that you see it is resistors that overheating and burning.Unplug TV from outlet before more damage is done
Aug 23, 2011 | Samsung HC-P4241W 42" Rear Projection...
Samsung hc-p4241w - No picture
samsung tv model hc-p4241w good picture no sound
May 22, 2009 | Samsung HC-P4241W 42" Rear Projection...
Connect Philips DVD to Sansung TV
the red and black are the same as the red and white, these are the audio left and right channels. the yellow plug is the video plug. the next thing you have to check is wheather your tv has video 1 and 2 channels
May 09, 2009 | Samsung Televison & Video
HC-P4241W
you need to replace STK 392-110s these are your convergence chips and will cause this problem some are stk 120s 150s,up grade to 180s.
Jan 08, 2008 | Samsung HC-P4241W 42" Rear Projection...
Samsung HC-P4241W 42 in. Rear Projection CRT aging
First off, do you not know Internet etiquette? Caps are considered yelling or shouting! So please! head You have the typical convergence failure of the convergence correction IC's. They BOTH need to be replaced. If you have no solid state printed circuit board experience, play it safe and call in a pro to assist you in this repair. Good Luck
Jul 28, 2007 | Samsung HC-P4241W 42" Rear Projection...
SAMSUNG 42inch HC-P4241W MODEL CRT AGING
explain what the picture looks like? Does it look like the edges are in 3-D?
Jul 25, 2007 | Samsung HC-P4241W 42" Rear Projection...
Blue haze around image, yellow streak
the tv color circuit is off frequency change the color ic take a look on the crystal that gives the 4.8.mhz burst could be that it needs to be replace dont rule out the video IF change the two ICs you mention.good luck.from the look of your tv screen that is my conclusion.good luck.email me at [email protected]
Apr 04, 2007 | Samsung HC-P4241W 42" Rear Projection...
Open Questions:
Samsung HC-P4241W 42" Rear Projection HDTV-Ready Television Logo
407 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
