Question about ATI RADEON X1650 Graphic Card
X1650 agp does strange things in games
I just updated my video card from a ti4200 64 meg 4x agp to an his x1650 512 meg 4x/8x agp. my mobo is only 4x agp, which i have read is not a problem. everything runs great except when it comes to playing my one game that i always play. that is America's army. it seams that there will be lines that start from a wall that weren't there with my old card. the lines sometimes go straight and never get bigger. then some of them go into a large triangle. i have tried all sorts of settings to get rid of this and no luck. when i chenge the res the lines go away but then come back. i just installed this vid card so i have only the latest ccc and drivers that you can pull of off ati website. i have read people going back to 7.7 version because of problems with the newer games. is this the best thing to do? this is also being run on a 1600 xp cpu with 1.25 gigs of ram.
    Scholar:
  • 119 Answers
You have a interesting nice problem here..first of all check in the bios settings for the AGP aperture..make it maximum possible,in your case 4x.
-after that check the conection of your video card on the mainboard,clean the agp slot a little ..
-a good solution is to reinstal the windows..sometimes,like in your case,some parts of old nvidia drivers are still resident ..
-try reinstaling the catalist drivers but older versions,to see if the problem persists..
well I suggest you to do all theese steps..
I would do them if I were you..actually,I had few times your problem..
bye
Posted on Feb 03, 2008
About AGP grapics
Kababayan:
This is the specs of motherboard:
ASUS S478 VIA P4V533-MX Motherboard The P4V533-MX supports VIA ProSavage8 for quality integrated graphics, 533MHz Front Side Bus, Intel Hyper-Threading technology, DDR SDRAM, AGP 4X, USB 2.0, 6-channel audio and 10/100Mbps LAN, the P4V533-MX is an all-in-1 solution for system builders.
Eto naman Specs ng Video card mo:
Product Name : X1650 PRO 512MB AGP
Video Memory 512 MB DDR2
Bus Standard AGP 8x/4x
Pwede yan...
Happy Fixya...
Jan 22, 2009 | ASUS S478 VIA P4V533-MX Motherboard
Looking to upgrade video. is there a limit to uprade old mboard
Only cards that work with this board are AGP 4x graphics cards or possiblly AGP 8x cards that are backwards compatible. If you buy an 8x card do your research to make sure it's backwards compatible before purchase. Newer graphics cards are pci-express x16 or pci-e 2. These will not work with your board. Hope this helps & please remember to rate my answer. Thanks.
Jan 10, 2009 | Matsonic MS9327E (MS9327E+(USB))...
Graphics card issue - GA-0ST800 Motherboard
Your motherboard have an AGP 4X port, you can easy upgrade whit that card since it is an APG-card. Not sure tough that your motherboard can handle all that DDR3 power witch come with the card but im sure u will notice a big improvment.
I think that a cheaper card with 512 Mb DDR2 will give u the same results.
Good luck
Nov 21, 2008 | Gigabyte GA-8ST800 Motherboard
Screen going blank for a second or two while video freezes then jumps.
If you have on board graphics try removing video card and reboot when computer rebooted turn it of and refit card and restart when restarted computer should recognize new hard ware and should find the already installed drivers if not try installing drivers again
Sometimes windows does not recognize new hardware until its refitted
had this problem with modems alot and the above method solved it
Jul 31, 2008 | ATI RADEON X1650 Graphic Card
Distorted graphics
The 7600 gt can work on an agp 4x motherboard only in a 4x bus speed, if your just using the cd driver that comes with the video card try updating it by downloading the latest driver in www.nvidia.com, first uninstall the driver then restart the computer then install the latest driver you downloaded
Jul 23, 2008 | Computers & Internet
Graphics cards
Hi noxiney, you're MSI motherboard does have 1 opened AGP 8x4x slot. You can install & run the ATI Radeon X1650 PRO AGP. You can not run PCI-Express because there are no PCI-E slots on the board. There are PCI (White in color) on the board but the AGP slot is much faster than the PCI (White in color slots). The manual states the AGP card can only support 1.5volt video cards & not 3.3volt AGP cards. (Keep this in mind when looking for an AGP card).
Below is a link to a bunch of AGP 8x4x video cards. One or two include DDR2 memory. Carefull where you buy. Check the warranty. (Longer is better). The first one on the list would be compatible. Its not DDR2 but it does have 512MB of memory.
http://www.google.com/products?hl=en&q=AGP+ATI+Radeon+X1650+PRO&um=1&ie=UTF-8&sa=X&oi=product_result_group&resnum=1&ct=title
This card is 1.5v compatable.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3101648&CatId=318
& this is compatable.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1642902&CatId=318
Just remember, if the card can run both 8x & 4x it should support the 1.5volt needed to function on the MB.
Enjoy!
Mike
Jul 08, 2008 | MSI PM8M-V Motherboard
P4VMM2 - what graphic card to use?
Any current brand/model of an AGP video card would work with this motherboard (NVidia or ATI). The only limiting factor would be how much you would want to spend for it.
Not a preference but an observation dito sa tin, mas matagal buhay ng ATI compared sa NVidia.
Hope this be of some help/idea. Pls post back how things turned up or should need additional information.
Good luck and kind regards.
Jan 10, 2008 | EliteGroup P4VMM2 Motherboard
ATI RADEON X1650 Pro, AGP Graphic Card 512MB compatibility
Maybe this post is a bit old, but on last deceber I bought an AGP 512MB ATI Radeon X1650 PRO for my Foxconn motherboard and I must say that it's simply awesome!
I can play most games on mid-high settings on reasonable resolutions (most on 1024x768) with good FPS (except with Crysis... but let's face it, did Crytek bought a time machine to warp a 2010 game??).
So, if you already have it, then congratulations, and if you still are thinking on buying it, then what are you waiting for!?
Also, it's AGP x8, if your motherboard support x8, then it should run perfectly fine.
Also, I have a bit of problems trying to run Prey on the X1650...
It always appears an error... it's not of much importance, as I have much better games, but I haven't tried it with high fancy graphics... :P
Oct 13, 2007 | ATI RADEON X1650 Graphic Card
Does my (this) mother support agp ddr2?
MOTHERBOARDS Hi there, does my motherboard support video cards like ATI RADEON X1650 512MB AGP? ---YES, When you installing AGP card, please make sure the following notice is fully understood and practiced. If your AGP card has "AGP 4X/8X (1.5V) notch"(show below), please make sure your AGP card is AGP 4X/8X (1.5V). Caution: AGP 2X card is not supported by Intel® 845(GE/PE) / 845(G) / 850(E) / E7205 / 865(G/PE/P) / 875P. You might experience system unable to boot up normally. Please insert an AGP 4X/8X card. Does it support ddr2 or ddr3 memmory for the agp? ---YES, see the above notes can the agp memmory be over 512 mb? ---YES, see the above notes More more information go here >>> http://asia.giga-byte.com/FileList/Manual/motherboard_manual_8ipe1000g_e.pdf Hope This Helps =============================================== If you are having trouble with a Newly bought items then return them and demand a replacement or a refund! You may have purchased a reconditioned\repaired\factory defect product.
Sep 19, 2007 | Gigabyte GA-8IPE1000-G (MBGA81PE1000G)...
ATI RADEON X1650 Graphic Card Logo
62 people viewed this question
Top ATI Computers & Internet Experts
David
David
Computer Links
Alun Cox
Are you an ATI Computer and Internet Expert? Answer questions, earn points and help others
