Question about Belkin Wireless Pre-N (F5D8230-4) Router (F5D82304)
Belkin wireless router installation with a laptop that has an internal modem
I have a dial up internet connection[reside in Africa. he he he he].I bought the Belkin router N1 so as to be able to use the internet with the computer upstairs.
My dial up is connected to through a laptop with the modem residing on this laptop[Its not an external modem].
Will I be able to connect this wireless router.I have tried without success.
  • Shaqman Feb 05, 2008
    I am running windows vista on both systems. The laptop that will distribute the internet has a wireless newtwork card and the receiving system has a belkin usb wireless card.
    Thanks for your response waiting to get it resolved
    Kind regards,
  • 3 Answers
Depending on the operating system that you are running, and if you have the appropriate wireless cards, you should be able to do this either with or without the modem. If you have the modem connected to one computer, and wireless cards on both computers, then your best option would be to just connect directly from one computer to the next. If you can tell me the answers to these few questions, I can help you get on the right path.
What operating system are you running? Windows XP? Vista? Macintosh?
Do both of your computers have wireless network cards? If not, then which computers have the wireless network, and which computer has the modem?
Posted on Feb 02, 2008
Belkin router can't connect to internet
This is part solution, part clarification request: When you say that you installed the setup software on your laptop, setup software for which: the modem, or the belkin router? Also what type of internet service do you have - Cable? DSL? If you are not sure, list your ISP. What operating systems do you have on your laptop and your main computer?
You say that you connected the modem to your main computer - I am assuming that you mean that you connected your modem with a network or ethernet cable (the one with a connector that looks similar to but larger than a telephone's connector) to your computer's ethernet card, or NIC, port. Is anything connected by ethernet cable to the Belkin router? If you have not connected the modem directly to the router, it will not connect to the internet, and anything connecting to the Belkin router will not be able to access the internet as well.
Try this: disconnected the power from your modem, then disconnect power from your router, and disconnect any ethernet cables from computer & modem, or computer and router. Connect an ethernet cable from the modem to the Belkin Router. (Ensure that you have plugged in the ethernet cable on the router into a port that is either set aside from others, or indicates "Internet", WAN, or something similar - it should be marked either with a different color, labled, or both). Now power on your modem. Wait until you see a steady "ready" light, green ethernet light, or the light usually lit for that model indicating it has completed its bootup tests and the internet connection is ready.
Next, ensure the ethernet cable is connected from the modem to correct WAN or "internet" port on the Belkin Router, then power up the router. Once the router boots up completely, plug in a cable from your computer's (main computer) NIC or ethernet card or port, to a port on the Belkin Router (there should be more than one port available, generally numbered "1, 2, 3" and so on - in a group, seperate from the WAN or internet port). Once you are sure you have the cable plugged into one of the correct ports, and if you have windows, restart your main computer.
Now on your main computer, check to see if you have an internet connection. If you do, you can now resume running the router's software setup on your laptop, which sounds as though it was walking you thru the setup process to connect you via wireless connection to the internet. Report back if you have any success, or if you have any further problems, and best of luck! Hope that info helps
May 05, 2010 | Belkin (F5D8231-4) Wireless Router...
Belkin router is unable to connect to 2Wire ADSL modem/router. 2Wire router has DHCP server enabled and Belkin has DHCP server disabled. Belkin is set to obtain an IP automagically. 2Wire IP is...
If the Internet light is off then there is a problem with the phone line to the ADSL modem or the modem is faulty or there is a problem at the telephome exchange.
Disconnect the phone cable at the ADSL modem and connect a phone handset to this cable - check for a dial tone and that you can dial out.
If you don't get a dial tone, use a different or new phone cable.
If the phone line is OK then : -
Ring your ISP to get them to test your connection to your ADSL
Oct 17, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
I cannot get my Dell Inspiron Laptop to connect with Belkin router, any idea why??
Are you trying to connect to the wireless network on the laptop ?
It is very simple.
first you will need to make sure that you have all the wireless settings of the network.
Click Here for more info about wireless network connections
Oct 17, 2009 | Belkin (F5D5231-4) Router
Connecting router to dial up
I don't believe that router is designed to be hooked directly into the phone line. That would be your problem. The process is much more complicated than simply plugging your phone line into the router instead of the laptop.
Feb 27, 2009 | Belkin (F5D7230-4) Router (587009)
Wireless internet
Basicly the wireless router needs to be connected into the internet, then you will be able to connect to it. You need to install the card and make sure it works in your device, then connect into the router and it should work fine.
Oct 27, 2008 | NEC MobilePro 900 Handheld
Set up my belkin g router
You may have to configure the belkin router depending on the type of ISP that you have.
Basically, you can do these to configure your router:
1. connect the computer to the numbered port of the router and connect the modem to the internet/WAN port.
2. turn off the modem, router and the computer for 30 seconds
3. turn on the modem first, wait for the lights to stabilize then turn on the router, wait for the lights and lastly turn on the computer.
Sep 04, 2008 | Belkin (F5D7230-4) Router (587009)
Installing wireless G router
Yes, you do need a modem (DSL, Cable). This router does not function as a modem.
Oct 01, 2007 | Belkin (F6D3230-4) Router (F6D32304)
Wont connect to the internet
Try this, assuming you're using Internet Explorer: Go to Tools > Internet Options and select the Connections tab. Does it show your old dial-up connection in the list? If so highlight it and click on REMOVE. Close IE and re-open it. It should now use the Belkin LAN connection.
Aug 18, 2007 | Belkin (F5D7231UK4) Wireless Router
Belkin Wireless Pre-N (F5D8230-4) Router (F5D82304) Logo
103 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
