Question about Photography
Canon camera shutter sticking cannot take photo regards Margaret
  • 1 more comment
  • Anonymous Feb 09, 2009
    I have the same problem....I think. I have to press my shutter button twice when using optical view finder. I have a canon xs. What to do?
  • emsteve May 02, 2009
    When I take a picture the shutter closes but does not reopen unless I push the button a second time. I have a Canon EOS Rebel X 35 MM. Please help we have a BDay party in about 50 mins.
  • Kevin Pettit
    Kevin Pettit May 11, 2010
    Hi Margaret,
    Which Canon camera do you have?
Canon EOS cameras manufactured in the late 1980s to early 1990s have an internal foam bumper for the shutter curtain which deteriorates with time, breaking down into an oily black tar. The tar oozes down and gets onto the shutter blades, causing them to stick. This results in the shutter either failing to open altogether or opening too slowly, resulting in blank or unexposed photographs.
Posted on Feb 26, 2010
Hi it is canon snappy LX ii
Posted on Feb 03, 2008
Stuck shutter
It doesn't sound like a shutter problem, especially since the G12 doesn't actually have a mechanical shutter. It sounds as though there is either an exposure setting issue when the camera is in Manual mode or one of the other settings that will allow you to take a photo no matter the conditions. If it does the same thing when in full automatic there could be issues with flash or flash compensation or an internal issue. When it happens again, check to see that the camera has not accidently slipped into another mode.
Oct 04, 2014 | Canon G12 Digital Camera
HELLO , LANCE HERE (NEW ZEALAND) I HAVE A CANON POWERSHOT A430 ABOUT 3 YEARS OLD, ITS STARTED TO HAVE A PROBLEM ON OUDOOR SUNNY DAY PHOTOS, ALL THE PHOTOS COME OUT WHITE, OVER EXPOSED, SEEMS...
Probably the shutter flex cable is broken inside the lensblock,or replace the lensblock,labor extensive,technical skill required.
See other solutions for similar faults.
Jean
Jan 02, 2011 | Canon PowerShot A430 Digital Camera
I have my canon a470 digital camera, recently i had a problem with my cam, while taking any picture it showing fully white screen pictures not at all viewing properly as well their is a white lines are...
This sounds like a stuck shutter, with the shutter stuck open. See this link, trying Fix #5A. If Fix 5A does not work, your camera is then likely experiencing a broken ribbon cable to the shutter control. Unfortunately, repairing that cable would be more costly than the value of the camera. Also, repairing the cable yourself is not recommended as finding a replacement cable would be just as costly, and the actual repair is very difficult.
Dec 27, 2010 | Canon PowerShot A470 Digital Camera
A 620 canon camera iris does not open, photos seem
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
May 23, 2010 | Canon PowerShot A620 Digital Camera
When the camera is switched on it shows only memory card photos but in the camera mode it does not shoot photographs. I sent the camera to Canon Repair center, they told its optical assembly is faulty and...
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter (a.k.a. "faulty optical assembly") are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help:
But if you notice shutter movement when you take a picture, then it's likely a failure of the CCD image sensor. If so, Canon WILL FIX THIS FOR FREE. This is a worldwide advisory for this issue. Go to www.Canon.com, select "support" in the left column, then your region on the map. Continue on to select your country. Search your countries website for support of the A85, and any "important information regarding your camera". Included there should be the info regarding the free repair. It's important to ONLY CONTACT OFFICIAL CANON SERVICE CENTERS listed on this webiste. Non-official repair centers may charge you for the repair, and merely ship the camera to the official Canon center for the free repair.
Here's a sample of the advisory notice for the US.
Dec 21, 2009 | Canon PowerShot A85 Digital Camera
Horizontal lines on lcd after taking photo
Sticking shutter. It will require either cleaning or replacing.
lines on photo's are due to the shutter sticking.
the video function does not use the shutter so is un affected.
Dec 11, 2009 | Fuji FinePix F470 Digital Camera
My Canon 20D is malfunctioning. The top right corner of all my photos are black. Please help!
Most likely the shutter blind sticking, so it will need a service. The cost might exceed the second hand value of the camera though.
Nov 28, 2009 | Canon EOS-20D Digital Camera
Canon 1D shutter problem
may be shutter not opening fully some grit dust in it i had thia prob with my camera cleaned it and it was fine
Sep 15, 2009 | Canon EOS-1D Mark II Digital Camera
Menu and display buttons do not function
One quick question. Is the camera taking photos?? when you try to transfer the photos to computer , are the photos fine or there are some Black photos??
Regard's
Manoj Goyal, INDIA
+91-9214988557
Dec 03, 2007 | Sony Cyber-shot DSC-N1 Digital Camera
Photography Logo
220 people viewed this question
Top Photography Experts
pontelemon
pontelemon
TC CAMERA REPAIR.Com...
Are you a Photography Expert? Answer questions, earn points and help others
