Question about BUSlink (RW-4048) CD-RW Burner
Buslink LTR 40125S CD-RW
When I click on the CD-RW icon in Windows explorer it reboots the computer.
This is something that just started happening.
  • alreb Feb 07, 2008
    Chie-chie
    Checked all connections, no fix
    Apparently XP and INCD have decided to not get along. I uninstalled INCD and reinstalled the outdated program I have on my original cd and it appears to work ok. I haven't figured out why the updated program has decided to cause problems. It has been working since 2005 up until about 2 weeks ago. I thought it might be the cd burner but any other disk I run works ok.
    Thanks for trying.
    alreb
  • 98 Answers
Open ur pc and check for loose connection. specially the power supply.
Posted on Feb 06, 2008
6ya staff
SOURCE:
Icon of DVD/CD ROM driver of Acer Aspire 4520 doesn't indicate in My Computer pannel and as a result I can't work with the DVD/CD ROM.Please help me.
if you want a shortcut so to get to your cd/dvd's
click start click on my computer you will see your cd/dvd drives right click on the cd/dvd drive you should create shortcut another message will appear windows cannot create short cut here do you want it to create one one your desktop another way to get the cd/dvd drives
click start all programs accessories you will see windows explorer in the list click to open up then on my computer you will see your drive/s click on cd or dvd
you could create a shortcut for windows explorer by right clicking on it send to desktop to create shortcut if you mean that you cant see your cd/dvd in windows eplorer
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark?! or a red x right click you will need to update the driver or
hope this helps
hope this helps
Jun 21, 2011 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
Ive bought a dvd rom rw cge-8527b but when i put a cd in (dvd movie or dvd rom nothing happens the disc turn and stop no sign of it the icon stays the same
make sure that the cd rw is getting enough consistent power test all leads that are attached to the cd rom including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd rw then plug them back in this will activate found new hardware wizard
hope this helps or
you might have to uninstall then restart your computer then reinstall your cd rom or uninstall the driver then reinstall for this device
also
click start control panel administrive tools computer management device manager scroll down cd dvd rom drives right click you can you will have options to update driver roll back driver select properties general troubleshoot select driver click to reinstall drivers click update driver uninstall then reinstall
you need only do the registry check if you cant see the drive/s in windows explorer/my computer
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Mar 27, 2011 | LG (GCE-8527B) CD-RW Burner
[email protected] have a buslink usb 2.0 cd-rw drive i have windows 7 now i lost my disk for it.what do i do
Hook it to your computer. Make sure it is powered on. Windows 7 shouls automatically install the driver.
Mar 21, 2011 | Computers & Internet
Need drivers for w2k and xp
Here it is (click here), for windows 2k and xp, you don't need to install the other drivers, it's included with the Operating System. For windows 2k and xp, this will be sufficient.
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Sep 21, 2010 | BUSlink (UIIRW52L) CD-RW Burner
Laptop Optiarc DVD RW AD 7530 B is not reading CD or DVD media. 1.DVD icon displayed in My Computer. 2.When I insert DVD or Cd in the drive,Green light flashes and tries to read the nedia and goes off...
2.When I insert DVD or Cd in the drive,Green light flashes and tries to read the nedia and goes off within few seconds.
3.DVD drive in My Computer when clicked shows empty folder
4.Uninstalled DVD drivers in Device Manager and let windows find it on reboot
5.Issue still persists.
6.Right now external DVD RW works perfect.
Please help
Oct 29, 2009 | Sony NEC Optiarc AD-7530B 8x DVD?±RW DL...
Cd-rw not being displayed in "send to" on windows explorer
Probably easier just to add it back:
start>run>type in "sendto">click "ok">right click in the white area>select new>shortcut.
In the "create shortcut" box, click on browse and navigate to your cd/dvd drive, just follow directions after that.
Jan 28, 2009 | Microsoft Windows XP Professional for PC
I'm looking for a replacement CD-RW for my Gateway 720S
I had a Lite-On DVDRW that I recently replaced as well but it didn't fail. I upgraded my system and had to get a SATA DVD. I got an LG DVD-RAM that works great for CD and DVD single and dual layer in both XP and OS X86 10.5.5.
It was 40 dollars at Frys. You can get it online at www.frys.com if there is no Fry's Electronics in your area.
Cheers
Dec 26, 2008 | Computers & Internet
Need driver for CD-RW
http://www.buslink.com/support.asp#NewSupport
Dec 20, 2008 | Televison & Video
I am trying to install a Linksys router WRT54G. I have E-machine model W4885 I put the disk in and nothing appears on the screen. What do I need to do?
Open windows explorer.(START-PROGRAMS-ACCESSORIES-WINDOWS EXPLORER)
click the +, by my computer, click once on the cd rom, find the setup or autorun file in the right hand pane and double click it and the cd should start.
srich
Mar 13, 2008 | Computers & Internet
Lite-on LTR-52246s
As a first step try running this and then reboot the computer. Sometimes windows loses track of CD drivers. I see one or two computers a week at work with this problem. If they doesn't work it could be a few other things, let me know if it works.
Good Luck,
Matt
Nov 10, 2007 | Lite On LTR 52246S CD-RW Burner
Open Questions:
SBCGL0baL TecH SuPPoRt PHoNe {1855\536/5666-}NuMbER #O'+' SUPPORT NUMBER SBCGLOBAL SuPPoRt PHoNe NuMbER {1^855^536^5666}#[email protected] SBCGLOBAL eMaiL is one of the excellent service providers of various online services, SBCGLOBAL eMaiL mail tech support phonE number # {1,855-536*5666 }and its services are used by millions of users worldwide. to resolve all SBCGLOBAL eMaiL products. SBCGLOBAL eMaiL is an American multinational company which was founded by Michael SBCGLOBAL eMaiL using its company headquarters in Round Rock, United States of America. Contact SBCGLOBAL eMaiL for Setup & Installation SBCGLOBAL eMaiL Setup Support & Installation SBCGLOBAL eMaiL TECH SUPPORT number Connect is a utility carrier that lets in you to print and scan from anywhere. The Wi-Fi characteristic in it makes it very on hand and easy to use. So, when you have in the end determined to head for SBCGLOBAL eMaiL Connect, SBCGLOBAL eMaiL TECH Support Phone Number you'll be searching out SBCGLOBAL eMaiL Connect setup as well. So, here we're with all cthe setup process and for your to SBCGLOBAL eMaiL Connect. Get SBCGLOBAL eMaiL Setup Instant Support SBCGLOBAL eMaiL TECH SUPPORT Phone Number Usually, the setup TECHnique takes SBCGLOBAL eMaiL + tech + support phonE number # {1,855*536.5666 .u.S.A..SBCGLOBAL eMaiL mailtoll free number+SBCGLOBAL eMaiL toll free number, toll free number for SBCGLOBAL eMaiL, SBCGLOBAL eMaiL toll free phone, SBCGLOBAL eMaiL toll free, SBCGLOBAL eMaiL toll free, toll free number SBCGLOBAL eMaiL, SBCGLOBAL eMaiL support toll free+SBCGLOBAL eMaiL+toll+free+tollfree.SBCGLOBAL eMaiL
Nov 12, 2019 | Carrier Computers & Internet
See all BUSlink (RW-4048) CD-RW Burner Questions
BUSlink (RW-4048) CD-RW Burner Logo
65 people viewed this question
Top BUSlink Computers & Internet Experts
Ekse
Marvin
Marvin
Are you a BUSlink Computer and Internet Expert? Answer questions, earn points and help others
