Question about Thomson Lyra PDP2860 Digital Media Player
Get RCA DVD Player to work.
Have TV with built-in DVD player. Also have digital cable. There is a cable box attached to the TV. Both cable and TV have remotes. To watch a DVD, press 'DVD' on TV remote. A screen comes up looking for a disc to read. Last week the built-in DVD Player quit on me. Bought small, simple RCA DVD Player but can't get it to work. Attached Player directly to TV but couldn't even get the disc tray to open. Then, attached Player to cable box. Disc tray opened easily both manually and by remote. But couldn't get the movie to play. Tried many combinations and sequences of remotes, etc. Am ready to rip my hair out. Can someone help me? NOTE:My Player is a Thomson RCA HDMI DVD with 1080i HD upconversion. The User Manual indicates 'RCA DRC275A'.
    Genius:
  • 1,067 Answers
Ok on dvd player u wann use hdmi cable direct to tv ok then select input hdmi on tv remote to see picture
Posted on Feb 02, 2008
  • Anonymous Feb 02, 2008
    also do u have hd tv corect ? if not u wann use s video from dvd to tv with red white for sound on a input ch
    gota use hdmi tho best picture then in settings use 720 p out ok with digital sound oput not pcm in tv settings menu under audio
6ya staff
SOURCE:
How to hook up an old RCA 14 inch tv to DVD
Easy. All you have to do is to make sure that the DVD player is old the older types that have RCA connectors at the back of the DVD. Latest DVD may have RCA connections but I am not sure if it can send digital signal directly to the analog TV. Try this and see what happens. if your TV is old and does not have Component Video (Red/Green/Blue) RCA sockets (input) but has standard Pal/NTSC sockets (Yellow/Red/Black) hook up the yellow, red and black plugs into a DVD (out) RCA sockets of same colour, then hook up the other end of the cable in the (in) RCA sockets at the rear of the TV.
If it works, then all is well. If it doesn't work, then you have to hook up the cable from the DVD to the (input) RCA sockets of a Set Top Box, so that the Set Top Box will convert the signals for the analog TV. Just pay attention to the inputs and outputs at the rear of them.
On your DVD - plug the RCA cable to the (OUTPUT) RCA sockets. On the Set Top Box - plug the connectors in the (IN) RCA sockets and then use another cable connected to the OUT RCA's of the Set Top Box, then connect the other connectors to the (IN) of the TV RCA sockets. Hopefully you get the picture on what I mean.
Sep 01, 2014 | Televison & Video
RCA DRC247N DVD Player No Audio
The separate DVD player has three output cables: video (yellow), right audio (red) and left audio (white?). These connect to the corresponding inputs on the TV. If your cable box also has three similar output cables, you probably do not have a second set of inputs on the TV so what to do? You can purchase three Y adapters that combine two female RCA connectors into one RCA plug and plug everything into your one set of connectors on the TV. However, if your cable box output connects directly to the TV antenna input, the solution is simpler. Post a comment if this approach is not going to work
Oct 13, 2012 | RCA DRC247N DVD Player
I no longer have the manual for the product and I want to hook it up to my TV via a cable box; we have Charter cable. The cable box is a Motorola and it says Dolby digital on the front of the cable box. ...
The white, yellow, and red RCA phono jacks on the back are called VGA inputs and outputs. The Red is
right channel audio, The white is for left channel audio. The yellow is the video. Look carefully on the back of the unit and the input jacks and output jacks should be clearly marked.
There are several other input/output ports. One is HDMI which is flat and wide. Another, not common, is composite video which uses the three above mentioned RCA jacks as indicated plus two more colored jacks. This combination gives a better picture.
A third option is a screwed on cable for input and output. This is called a "F" connector and is only used if the receiver equipment has a built in tuner. The output of a cable box is usually an "F" connector and the above described outputs
If you connect the cable box to the DVD player input and the DVD player output to the TV input, you often must have the DVD player turned on so the signal will feed to the TV.
If the TV has multiple inputs, it is best to connect the cable box to one of the TV inputs and the DVD player to another TV input. Using the TV remote you can chose which input you want to watch. The remote should have a button labeled "input"
Apr 29, 2017 | Cyberhome CH-DVD 402 DVD Player
How do you make the dvd player work
This is the Apex SUPPORT website have a look around in here and see if it helps>
http://www.apexdigitalinc.com/support.asp
Aug 31, 2009 | Apex Digital AD-1600 DVD Player
Problem hooking up DVD player to TV thru my cable box
Chances are you've got your DVD player hooked to OUPUT jacks on the cable box, not inputs. I haven't yet seen a box that takes any kind of an input other than the cable line, but they will have RCA jacks for audio and video outputs on the back. So your cable channels are fine, but the DVD signal is hitting a dead end.
The only solution if your TV doesn't have RCA inputs for video and audio is to get an RF converter (around $10-$20). This takes the A/V signals from your DVD and turns them into a channel 3 or 4 signal that connects to your TV's antenna input.
The converter also has a connector on the back for the cable coming from the cable box, since you'll have to disconnect that from the TV. When the DVD player is off, the cable box signal gets passed to the TV as normal. Turn on the DVD player and the RF converter switches on; put your set on channel 3 or 4 and you'll see your video.
One final thing: The converter will need an AC outlet for its power adapter or power cord, so make sure you have a spare. If you don't already have your TV and DVD player connected to one, this would be a good time to pick up a surge-protector outlet strip. Then not only will you have enough outlets, you'll be protecting your equipment as well.
If this solution has given you what you need, please take a moment to rate it appropriately. And thanks for asking here!
Feb 01, 2009 | RCA DRC277 DVD Player
Bought a proscanlcd hdtv 32lb30Q unable to get cable signal
Hi and welcome to FixYa,
Initially, pls confirm if below is how it is wired using a coaxial cable and not 3cable RCA to RCA:
  • Charter Digital Cable > DVD/VCR > TV
If yes and your concern is snowy or no signal on the TV screen, might it be that you have to power OFF the DVD/VCR when selecting channels on the TV itself (including when channel setup is being done).
Alternately, you can tune the TV to channel 3 and let the DVD/VCR do the channel selections.
Pls post back results. Good luck and thank you for using FixYa.
Jan 26, 2009 | Televison & Video
Hooking up my DVD/VHS player to TV & Convertor box
I would just hook up the dvd/vhs player with the red,white,yellow rca cables that should of come with your unit and just go to the input on the tv to watch your dvd/vhs player. This will give you a better picture and sound while allowing you not to have to watch dvd/vhs on a channel which helps make the dvd/vhs player independent. Also if possible I would hook the converter box up with the red,white, yellow rca cables to the tv as well if your tv has more than one set of red,white,yellow plugs since it is a better connection that coax and you probably watch more tv than vhs/dvd anyway. So bottom line try to hook up both boxes red,white,yellow and watch each box on different inputs instead of like channel 3 or 4. Also to record of converter box you can run coax from converter box to dvd/vhs combo and make sure your dvd/vhs player is on tuner input or channel 3.
I’m happy to help further over the phone at https://www.6ya.com/expert/brandon_60dfebff379d64bd
Nov 16, 2008 | Insignia Digital-to-Analog Converter for...
Samsung CXD2512 TV/VCR Combo...Cannot hook up DVD player
We also don't have a remote. We hooked a DVD/VCR combo to the Samsung combo by attaching the cable from the cable line to the DVD player and an additional cable from DVD to TV and it used to work but after we lost the control, the DVD can only be listened to but not seen. The VHS from the DVD player works perfectly though.
When we had the remote (before connecting the other combo) we used line-in to see a DVD or VHS using the yellow red and white cables from the Samsung to the other player.
Sep 05, 2007 | Samsung CXD2512 25 in. Combo
Thomson Lyra PDP2860 Digital Media Player Logo
318 people viewed this question
Top Thomson Audio Players & Recorders Experts
Damen Wong
Damen Wong
Jerry Greenberg
Jerry Greenberg
Marvin
Marvin
Are you a Thomson Audio Player and Recorder Expert? Answer questions, earn points and help others
