Question about Infinity BASSLINK Car Subwoofer
No Sound from Basslink
I have a sony mexbt5000 head unit and a infinity basslink hooked up to it. I have my blue remote turn on wire connected to the amp turn on wire on my radio harness. The Basslink turns on when radio is on but I get no sound from the Basslink. Any Suggestions?
  • zxque Feb 06, 2008
    Basslink worked great for about three weeks. All of a sudden it just quit. I checked connections, fuse etc. Nothing seems to get it going again. Power light in on.
  • 7davie7 Feb 21, 2008
    Same exact thing happened here. Worked great for 6mos, then last night nothing...triple checked the wires, everything is perfect, LED is on...just no sound from BAsslink - I have heard that these have bad amps and blow often.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 199 Answers
Do you have speaker wiring or RCA's hooked up from AMP to Basslink? Also check the settings, make sure you are have bridged the channels on amp.
Posted on Feb 13, 2008
Infinity Basslink. I wired and connected everything and sounded amazing. I removed my center console to construct a box to put the Basslink in. When I was putting the Basslink sub into the box (tight fit)...
I would get a test light and see if the remote line is still working. Otherwise, yes you probably fried it. Doesn't take much in car audio to fry an amp.
Jan 17, 2014 | Infinity BASSLINK Car Subwoofer
Power light
Hi Bill, I believe the power problem is related to the Remote wire which should be blue or yellow. The remote wire is suppose the turn the Basslink on and off when the radio is turned on and off. The yellow wire is normally used for power antenna. Traditionally the remote wire is blue. You can use a Speaker level adapter and splice in with the L/R rear speaker wires, and the adapter will convert the speaker level to line level. The output of the adapter will go to the Rear speaker input on the basslink., Write back if you need more detail on the adapter.
Oct 07, 2007 | Infinity BASSLINK Car Subwoofer
I have a 2005 Mitsubishi Eclipse with the Infinity high end stock radio installed, which has a 200 watt amp under the seats. The head unit does does not have direct speaker outputs. The head is connected...
I am going to refer you to the live help
at crutcfield.com audio
They can give you ideas on compatible equipment and designs that will achieve your desires without the OBVIOUS overlad/mismatch.
Your search for comparison returned these articles
Free factory (usa market) wiring diagrams
BBB Industries Premium Alternators Starters Power Steering Products
Mar 11, 2017 | Infinity BASSLINK Car Subwoofer
My basslink circuitry is fried!!
go to the website that built the part. they usually have manuls you can download and get exact part number.. then go to ebay or google t for fix andddd parts cosr
Feb 17, 2010 | Infinity BASSLINK Car Subwoofer
Basslink Powerlight comes on then fades quickly
check to make sure your remote wire is hooked up to your amp turn on that runs straight out of the stereo not your power antenna also make sur you have a clean ground(no paint or rust) and also check your connections make sure you have a strong connection to all wire hook ups.......you should check to see that your remote wire has no tears in it or small rips or cuts because that can interrupt your current to and from the amp and radio
Jun 25, 2009 | Infinity BASSLINK Car Subwoofer
Humming noise when amp is powered on.
check the heatsink, touch it with your finger feel it ,if you can hold it with in 15 sec, then your power amp. component might be working if not then probably you Power Amplifier IC or transistor is shorted.
May 31, 2009 | Infinity BASSLINK Car Subwoofer
Power Never Comes on
that remote wire has to be hooked up to the power or the radio power antenna wire which will switch the remote wire on when the radio is turned on, so that remote wire really should be hooked to the radio wire that gets power when the radio is turned on , thats why the sub is not turning on
electech
Oct 26, 2008 | Infinity BASSLINK Car Subwoofer
Infinity Basslink killing battery
Both issues sound like they are related to a non-connected or loosely connected remote wire on the Basslink.
If you're using RCA preamp wires to connect your stereo to the Basslink, make sure the remote wire input on the Basslink is solidly connected to the stereo's remote output.
If you're using the speaker level inputs on the Basslink and not the RCA preamps, make sure the remote input is not connected, as the Basslink will automatically turn on when it senses the speaker level inputs are active.
Mar 19, 2008 | Infinity BASSLINK Car Subwoofer
No power
Other than the +12V, the ground (-) and the 2 RCA inputs, normally external amps have also a remote trigger which switches it to active on. The remote trigger is activated by a wire from the head unit. Colors would either be yellow or blue but depends on manufacturer of head unit. Alternately, you can connect a simple toggle on/off switch to activate the external amp.
Additionally, pls verify that the 2 RCAs from your head unit are audio out and not audio in for aux source.
Good luck and kind regards.
Nov 01, 2007 | Infinity BASSLINK Car Subwoofer
Open Questions:
See all Infinity BASSLINK Car Subwoofer Questions
Infinity BASSLINK Car Subwoofer Logo
480 people viewed this question
Top Infinity Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Colin Stickland
Colin Stickland
Are you an Infinity Car Audio and Video Expert? Answer questions, earn points and help others
