Question about HP DeskJet 9800 InkJet Printer
Hp9800-Printer will not take paper
Printer worked fine until recently, but now it won't take the paper, either A4 or A3! Have taken out the paper tray and taken the rear off, so see if I can diagnose the problem. What appears to be the problem is that the mechanism that normally offers up the paper is not springing up. It is permanently in the down position. Is there anything I can do about the problem, I've only had it just over a year (so the years guarantee has only just ran out! ) and it has only had moderate use (approx 3 or 4 print cartridges). I would imagine it is quite a simple mechanical problem. If anyone can shed any light on how to fix this, it would be much appreciated!
  • 5 more comments
  • Anonymous Mar 25, 2008
    Everything was working fine - printing several pdf files on 11 x 17 paper. All of a sudden it errors out "out of paper" - It will take manual feed paper but not out of the tray. I just replaced the black cartridge (only the second one since new.)
  • HATE HP Apr 07, 2008
    SAME ISSUE AFTER JUST A FEW PRINTS. SO FARHP IS NO HELP WITH TH WARRENTY
  • blackwater77 May 06, 2008
    Same problem.  Paper lifter is not functioning.  This started after I put through some card stock that was a bit too heavy.
  • Brian MacFee
    Brian MacFee May 23, 2008
    I have the same problem on 3 of them. I can't figure out how the paper is picked up - I took apart 2 of them and I'm baffled ( I have fixed numerous printers before..).
  • Anonymous May 26, 2008
    Paper will not feed. I can feed, by hand, paper through the back.
  • Anonymous Jun 18, 2008
    Exact same problem, had printer just over a year when paper feed stopped for all sizes and types of paper.
  • mbyrne48 Jul 21, 2008
    I have the same problem with my 9800. I took every step mentioned with all the other complainers. After I called HP and got nowhere there, I decided to throw the thing in the dumpster and call Epson!!
Do you have a solution?
Posted on Sep 18, 2008
A3 paper jams up as it exists the fusser unit. This usually only happens after printing off three sheets. A4 paper works fine. Paper weight is 80 grams on A3 and A4 and the fusser is set to normal...
chances are the pickup rollers are worn and in need of replacement,these are located just above the tray inside the printer and are both easy to remove and widely available
May 18, 2011 | Office Equipment & Supplies
I need to change our Canon IR2016 from A4 to A3, Also I need to activate 1 to double sided copies. I am looking on line for the user manual for the IR2016 but can't find
ir2016 is allready A3 size copier.you can change tray setting.pull out tray from machine and then set A3 paper on it according to paper you must change blue lever position from A4 to A3.then close your tray.now you can work with A3 size paper
for double side copying you must be installed a "duplex unit" which is not come with standard machine.It is an optional unit.after that you can make double sided copying.
Jan 19, 2011 | Office Equipment & Supplies
There are no matching paper size. Place paper in first tray.
A4 is n earupean size .change to 8 1/2 by 11 in both the copier and you printer setting..
Apr 08, 2009 | Konica Minolta DiALTA Di200 Copier
AR-M207 default paper tray for fax
push"special function" button, then select "key op prg", then "ok", then enter pin (default is 00000), then select "fax", then "ok", then select "rcv function", then "ok", then "tray selection", then "ok". The rest you should be able to follow your nose.
Feb 06, 2009 | Sharp AR-M207 All-In-One Laser Printer
Paper size
The problem is with the printer side. there is option in the printer, Set manualy paper size from the printer paper tray. I think this will help you.Goodluck.
Mar 10, 2008 | HP LaserJet 5550DN/EN Printer
A3 Printing
Put A3 in the paper tray and select reduce and enlarge and set to 141% this is A4 up to A3 then press start this should help.
Thanks J
Oct 02, 2007 | Sharp AR-161 Laser Printer
R1800 Borderless Printing Problem
Hi Tom, Have you downloaded the latest driver from the Epson web site. Also make sure the output tray is in the correct position and that you are using the correct paper. You can use the following media with this feature: Matte Paper - Heavyweight A3+, A3, A4 Premium Glossy Photo Paper A3+, A3, A4, 10 x 15 cm (4 x 6 in.), 329 mm x 10 m, 210 mm x 10 m (Roll paper) Premium Semigloss Photo Paper A3+, A3, A4, 329 mm x 10 m, 210 mm x 10 m, 100 mm x 8 m (Roll paper) Archival Matte Paper A3+, A3, A4 Watercolor Paper-Radiant White A3+ Velvet Fine Art Paper A3+ Ensure the output tray is in the correct position as if the tray is too low and the paper "falls" down into the tray the weight of the paper could pull the last few millimeters of paper out of the exit rollers, causing the band.
Aug 15, 2007 | Epson Stylus Photo R1800 InkJet Printer
Problems printing an A4 document in A3
Ensure that the desired paper is set in a paper tray of the printer and select [Auto] in the paper selection of the printer driver. You may need to configure the margins in the sofware you are using. hope this will help you Daniel
Feb 01, 2006 | OKI B8300 Laser Printer
HP DeskJet 9800 InkJet Printer Logo
206 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
