Question about Kenneth Cole KC3289 Wrist Watch
Taking the battery out
I have a Kenneth Cole watch and I can't seem to get the battery out. I tried prying it with a knife for a while and it won't seem to budge. Can some one help me?
  • Anonymous May 02, 2008
    This one is a tough nut. I managed to open it up but was unable to close it by hand. Ended up buying a case back snap and ruined the crystal. I won't take this one to a professional.
  • eyemgenie Sep 06, 2008
    I have a KC4186 wrist watch, looks just like the KC3289 to me. I found the little groove on the back and tried using a small screw driver, it has moved, ever so slightly and I've done some scratching on the back cover, but that ****** ain't gonna pop off. This has become a challenge now. I change all my watch batteries myself cause it would cost me a fortune to take one in every time a battery died. Please help before this one becomes wall kill.
    Thank you, Jeanne
After a little research I found this cool looking tool....
http://www.timezone.com/library/workbench/workbench631654780793976672
I can't imagine buying the tool would be cheaper than
paying a watch repair shop to replace the battery or
sending it in to KC directly. However it would be super
cool to be able to change the battery at will. If anyone
can find where to buy this "claw" tool please do reply.
Posted on Jun 15, 2008
This one is a tough nut. I managed to open it and changed the battery but wasn't able to close it back. Ended up cracking the crystal due to my own fault. I'd take this to a professional if I could do it again.
Posted on May 02, 2008
    Scholar:
  • 119 Answers
Some watches have a special way to open..nut by push/pull out the back but by rotating it .in this case it hase some small cuts in the back cover .if this so,it just might need to rotate.
Posted on Feb 03, 2008
What size battery does a kenneth cole watch model # 9172 use
Take your Kenneth Cole watch to a jeweler who will open it, identify the battery type, and perhaps replace it for a reasonable sum.
Sep 22, 2017 | Kenneth Cole Watches
Battery size for Kenneth Cole KC3679 watch
Take your Kenneth Cole watch to a jeweler who will open it, identify the battery type, and perhaps install a replacement.
Apr 17, 2017 | Kenneth Cole Watches
How do I take the back off of a Kenneth Cole watch kc1346
Could use butter knife or similar something to pry up case back , there is back of watch 12 O'clock side between case and case back put butter knife in and pry up . Be careful make sure not hurting yourself and same time be gentle make sure not damaging something
Jan 25, 2016 | Kenneth Cole Watches
Which replacement battery for kenneth cole kc3565
Remove back of watch small pearing knife will do careful silde under back to remove battery
Aug 05, 2014 | Kenneth Cole Mens NY 3 Eye KC3565 Gunmetal...
How to change the battery in a kenneth cole 3504 watch
you have to open caseback, inside close to the battery see one tiny metal piece pressing & holding battery, you need a tiny pin to pry that metal piece battery will come out put new battery on then press VERY GENTLY 9k=
May 13, 2014 | Kenneth Cole Reaction KC3504 Watch for Men
How to open the back of Kenneth Cole KC3434 watch to change the battery?
BASIC WATCH BATTERY CHANGE
Get a replacement battery for your watch. Some watches have the battery information stamped on the back plate. If yours doesn't, you'll have to wait until you've removed the old battery to see what kind of replacement watch battery you'll need.
Lay your watch face down on a non-scratching, non-skid surface. It may help to clamp the watch to the surface.
Remove the back from the watch. You might be able to pry it off with your fingernail, but you'll probably need a stiff, thin tool like a knife or screwdriver. You can also buy watch repair kits, which have the perfect tools for the job. Check the watch back for a small notch to insert your tool, but not all watches have these.
Remove the battery from the watch once the back is off. You might need to tip the watch over to let the battery fall out.
Insert the new watch battery into the proper space, first double-checking its size against the old battery to make sure it will fit. Press lightly into place.
Replace the back on your watch. Make sure you press firmly to get the back seated snugly.
If this doesnt work, then take to a local jeweler/watchmaker who is equipped with the right tools to assist you.
Best regards.
Aug 17, 2010 | Kenneth Cole KC3434 Wrist Watch
Have a Kenneth Cole watch and the battery needs replacing. The watch is a KC1239. Any solutions?
Get a flathead screwdriver from eyeglass kit and the back cover will pry off to replace battery
Jun 27, 2009 | Kenneth Cole KC1239 Wrist Watch
Kenneth cole reaction KC1408 changing battery problem
You have to take the back off. If it has about 6 slots around the back, then it screws off. If it's flat, then you can pry it open. If you pry it open, it,s very difficult to get it back on all the way. You may have to get some tools, or go to a repair shop.
Mar 02, 2009 | Kenneth Cole Watches
Trying to replace battery in Kenneth Cole C275-04-KC3522
You need a watchmakers knife or caseback opening tool to open your watch.
1)If your watch has screwdown back, there should be grooves in caseback where you have to put in opener and unscrew that caseback.
2)If your watch has a 'clip-on' caseback, you have to carefuly examine the caseback and find the groove between caseback and watch case (it is called 'the lip'). This is the right point where to insert the blade of wtchmakers knife and open it using pressure and lever action.
3)The safest, but dearest way is to visit your nearest watch repair shop and ask for battery replacement. You may ask the watchmaker to show you how to do that, so, in future you can do that yourself.
Do not forget to rate, please.
Jan 13, 2009 | Kenneth Cole KC1104 Wrist Watch
Battery replacement
For that you need tool called watch caseback opener. It looks like knife, only the blade is very short, curved and hardened Plenty on ebay for around 5 GBP.
Ordinary knifes wont work as they aren't hard enough and you can damage the watch and injure yourself.
If you gonna try to use chisel and hammer action, then you will damage your watch definetely.
Why don't use watchmaker services? Battery replacements are not very costly.
Regards
Arthur
Dec 15, 2008 | Kenneth Cole KC3271 Wrist Watch
Kenneth Cole KC3289 Wrist Watch Logo
217 people viewed this question
Top Kenneth Cole Watches Experts
Jimmy Accardi
Ansel Alberto
Ansel Alberto
Are you a Kenneth Cole Watch Expert? Answer questions, earn points and help others
