Question about GE GSH25JSRSS Stainless Steel Side by Side Refrigerator
GE GSH22JSRE Refrigerator Ice / Water Dispensing Issue
I am having a Ice / Water Dispensing Issue with my GE GSH22JSRE Refrigerator. The ice maker makes ice, the Ice basket is not blocked at the bottom and there is water coming to the unit.
When I put a glass under the dispenser it will always light up but will not always provide water or Ice. The probability of getting water is much higher than getting ice.
If I open and close the fridge door it will sometimes work. Other times I jiggle the Ice basket or press all of the buttons on the control panel.
I unplugged the unit for 1 min to reset it but that did not work. Do you have any ideas?
We are having a baby and I can not jump to spend the money on a service call. I will just have to live with it if I can not tweak it myself.
Thanks in advance.
jeff-
  • 2 more comments
  • Lentzer Mar 02, 2008
    Same issue with my unit. Its a little over 2.5 years old. Now it sounds like a relay is clicking on a constant cycle and I am not sure if the unit will keep my food cold....I will see tomorrow I guess. The symptoms Jberg2ks describes has been getting progressively worse. We have tried removing the Filter, removing the excess ice, unplugging for 15 minutes....Also, now the Water button on the Dispenser is blinking Green constantly.
  • Anonymous Mar 27, 2008
    I won't bother rewriting a perfect description of MY problem as it was addressed so thoroughly by JBerg2k
    "I am having a Ice / Water Dispensing Issue with my GE GSH22JSRE Refrigerator. The ice maker makes ice, the Ice basket is not blocked at the bottom and there is water coming to the unit.
    I unplugged the unit for 1 min to reset it but that did not work. Do you have any ideas?"
  • helpslip Dec 14, 2008
    My Ice will not dispense. The motor that turns the device is not responding. Any one know the fix?
  • JBerg2k Dec 18, 2008
    All,
    I wound up calling GE to come out and service my unit. They wound up repairing the circuit board in the despensing pannel. The total cost was about $325. About 1 month later I got a letter in the mail from GE about a rebate. I sent in my receipt and they sent me a check for $150. This must be a wide spread problem. I hope this helps!!!
I have the same issues as above, ice maker makes ice but will not dispence or give water,
when I push the lever to get anything the lights go out and the fans slows or stops until I let go of lever.
Side by side GE : Model # GSH25KGRE WW / Serial # MG278521
has anybody else had this issue with this model?
Posted on Sep 15, 2008
I have the same fridge with the same problem.  its the water line freezing.  if you leave the freezer door open for about 5 mins or so, the water should start working again.  it must be a pretty crappy design.  I'm searching for a better solution
    Problem Solver:
  • 5 Answers
Contact GE and notify them of the problem. Also let them know that you have located numerous other cases of the problem online of people with the same problem. They will set up a service call and will cover the cost of the parts.
Posted on Aug 03, 2008
My GE Side by Side stainless steel refrigerator won't dispense water. The ice works fine. The crushed ice works fine. The water light comes on and sounds like the pump is pumping, but no water comes out. My water bill is current. I have no other problems with the refrigerator keeping the food cold. I have a perfectly good machine, with no water coming out!
Posted on Jul 26, 2008
Ice and Water not dispensing. Light button not working
http://www.repairclinic.com/0100_1.asp
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
Jul 04, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Most likely your water control valve on rear of refrigerator has failed. Do this pour tap water into the ice maker make sure it is on and let the water freeze. If the ice drops and does not refill then the water control valve is the problem. If ice maker does not cycle then it is the ice maker. Find your model number around the door frame and tell me which model GE you have and I will tell you the replacement parts. Let me know, Thanks, Sea Breeze
Nov 19, 2009 | GE Refrigerators
My GE side by side fridge/freezer is working, water dispensing ok, but not making ice. I switch off the fridge, than ice maker but still not making ice. I try all the hints from Manual but no luck. Water...
fill the ice maker with water manually, if you have ice in the bucket you know that the ice maker is working , after check the water valve if is opening , if it is replace main board
Jun 17, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice and water not dispensing
check the water solenoid in the back of the unit where the water line hooks up. sounds like the solenoid is not powering to admit water to the ice maker or dispenser.
Jun 01, 2009 | GE GSL25JFPBS Side by Side Refrigerator
My GE side by side refrigerator in not dispensing ice or water
I had the same problem with my GE refrigerator. A 26.6 cu side by side as well. I replaced the main motherboard located behind a small panel on the mid to lower right side of the back and it fixed the problem. I used GE part WR55X10552.
Dec 30, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice/Water dispenser is dispensing crushed ice only.
You could have a problem with the lever that changes from one to another. If you can access the panel behind that door you may be able to see if it is mechanical or not.
Dec 27, 2008 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
GE Arctica (PSS26NGSB) ice and water dispenser
need to call ge at 1800-386-1215 some of these sxs have a door insulation issue that they will either send replacement doors to an authorized service company to exchange at no cost to you or offer a rebate for a newer model. yours might be in this group
have your model and serial number out of the ref located in the refrigerator section, about 4-5 inches from the celing down the right side and call and see
Apr 12, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE GSH25JSRSS Stainless Steel Side by Side Refrigerator Logo
924 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
