Question about Tomtom GO 700 GPS Receiver
Turned on my 720 and it did not register any
Turned on my 720 in its usual location on the lower portion of the car windshield and it did not register any satelite reception and would not pick up position for about 30 minutes. I pressed the off button for about 25 seconds and the screen when back to an ocean then went blank and hasnt done anything since. The battery indicator says it is charged. I then used the paper clip and hit the reset button. Hve tried to turn the unit back on but no reaction except the green light.
  • 518 Answers
OOooppps, try connecting to your computer, and start tomtom home software, let it check for updates and see what happens/ comes up on screen, then we will take it from there, OK, Colin.
Posted on Jan 04, 2010
SOURCE:
93 ford f150 supercab wipers not working but clicks when trun to high speed
Sounds like the wiper motor "transmission" has broken or malfunctioned. Many wipers "park" when turned off. That additional movement, lowering themselves onto their rests, is made possible by mechanics in the drive transmission portion of the windshield wiper motor assembly. Probably needs service or replacement. Look for the assembly under the hood on the firewall likely near the top edge adjacent to one of the wiper arm locations.
Mar 20, 2016 | Ford Cars & Trucks
Where is cowl drain ?
cowl drain is located under the cowl. the cowl is the plastic trim cover in front of the lower portion of your windshield. you may have excessive leaves or debri that clogged the drain and is not allowing water to flow out from the behind the empty space behind the firewall.
Aug 28, 2014 | Cars & Trucks
Where is the location of vin plate?
its usually located under the windshield on the driver side of the vehichle, on the the bottom of the windshield were it meets the car. If you are facing the car its on the way bottom right hand side.
May 30, 2014 | 2002 Pontiac Aztek
Suzuki SX4 2008 SERIAL NUMBERS locations
Under the lower portion of the windshield on the driver side. There should be about 18 digits
Oct 21, 2013 | Office Equipment & Supplies
How do I register this product.
To register go to their website and choose your location then click on product registration at the lower right portion of the page. You can also go to this link and register. This is set for US customers http://tinyurl.com/pus7f87
Sep 15, 2013 | Bosch Vacuums
What is the switch code of dodge caravan 2005?
The ignition switch codes vary. The only way I could answer this is for you to take the VIN (located on under the windshield on the drivers side lower portion of the window) or on you registration and call you local Dodge dealer and ask the parts department.
Jul 08, 2010 | 2005 Dodge Caravan
How to replace my dashboard
Very long process. Remove ground cable on battery first. Then take all screws out accross dash near windshield. thenremove all bolts to steering column and lower, remove all bolts on lower dash and braces, this will allow dash to move somewhat, now start disconnecting the million wires and reverse procedure to reinstall
Jun 10, 2010 | 1997 GMC Yukon
Hi I need to locate the vin number on a 1997 kia sportage. I cannot locate it on the chassis
The vin number should be located on the driverside at the bottom of the windshield. Looking from the outside of the car on the driverside you should see it through the windshield. Hope this will help you.
May 20, 2010 | Cars & Trucks
Windshield wipers not working '95 Honda Civic ex
Check yoour fuse box located on the left side lower portion of the dashboard. You should find the label mark wiper remove the fuse and make sure to replace it with same watts of fuse which you can find a spare also on your fuse box labeled spare. If you can find it in your interior fuse box you can try also the fuse box located at the engine bay mine is located on the left side. Goodluck.
Dec 21, 2008 | 1994 Honda Civic
Tomtom GO 700 GPS Receiver Logo
64 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Marvin
Marvin
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
