Question about Linksys Wireless-G WRT54G Router
Server connection WRT54G
Hi my linksys home connection is working fine. However, I am trying to connect to my wireless with my work laptop. It indicates that the computer is connected to my wireless but when I try to access the internet "cannot find server is at the top of the page? How can I connect to my server?
  • 3 Answers
This sounds like your work laptop is configured to configure the connection manually. Do you use your wireless at work? If you do not use your wireless at work, then you need to open your network properties (WINDOWS XP, click start button, then right click on "network places" and select properties, then right-click on your wireless card and select properties). in the middle box, double-click on the TCP/IP properties, and in the box that opens, select the button to "configure my network automatically". Do the same for the button at the bottom (DNS). This should fix the issue. If you do use your wireless at work, then you will need to remember (put into notepad and save to desktop) the settings that are in there already, and then set the same.
Hope this helps. If not, then I can get more in depth with you.
Posted on Feb 03, 2008
6ya staff
SOURCE:
My linksys router wrt54gv8 not connected to work for my laptop wireless but have connection to my desktop
If I understand you correctly. You cannot connect wirelessly at work with you laptop but you can connect with your desktop.
1. The laptop has to be allowed on the network by either MAC address ( Media Access Control) number or an IP (Internet protocol) address.
2. This is done by the administrator of the router. To allow the device to be seen by the router and and assign an IP address to that device to gain access to the server and be able to connect to the Internet.
3. At work you will have an IT administrator that will give a password/ user name to allow you to obtain access to the company server.
I hope this helps. Have a great day.
Aug 27, 2010 | Linksys Wireless-G WRT54G Router
Router will not work wireless after switch from DSL to cable
You can go to 192.168.1.1
Enter the default username(leave it blank) and password(admin) and enter the router page
Under setup--> basic setup you can configure your ISP settings
Under wireless you can configure wireless username password etc
If still unable to connect wireless mention the operating system
Jan 29, 2010 | Linksys Wireless-G WRT54G Router
Picks up wireless network but unable to connect to the internet. I am trying to connect to the wireless on a laptop and a phone, both work fine else where but i am unable to connect to the internet using...
what is the wireless status in system tray? is it local or local and internet.
1. first check if it works fine with wire conection or not.
2.if it fine with cable then issue is with wireless. probably issue with Wireless security key.
3. go to available wireless networks and select the net work, if it is asking for wireless key please enter that. if you donot remember that perform router reset.that takes care of it.
Sep 24, 2009 | Linksys Wireless-G WRT54G Router
Need to setup Laptop wirelessly thru Linksys WRT54G
The default password of Linksys device is admin without username.
Jun 06, 2009 | Linksys Wireless-G WRT54G Router
LINKSYS WIRELESS-G MODEL WRT54G
Have you checked to make sure your internet is connected through your router, and DHCP is turned on. Sounds like you may have internet connection sharring setup through your desktop and it is acting as the dhcp server
Oct 05, 2008 | Linksys Wireless-G WRT54G Router
Internet connectivity problem
try to upgrade the latest firmware for the router and reset and reconfig it..
Dec 27, 2007 | Linksys Wireless-G WRT54G Router
Linksys wireless prnt server
Based on your post description, I am assuming that:
1. You can connect to the Internet through your 2241 Neptoia modem;
2. You can access your WRT54G V8 Linksys Wireless router @ 192.168.1.1;
3. Both 1 & 2 above could be done through a wireless connection from your PC.
Connect everything as they are supposed to be wired (printer, Print Server, modem, router etc)
Pls try:
a. Connect the Linksys wireless print server using a lan cable to the Linksys WRT54G Wireless AP/router. (Will tackle the wireless connection a bit later)
b. Reset your print server; &
c. Do a diagnostic print-out.
Instructions for b & c are in page 4 of your manual.
You need to verify that:
i. the Power indicator is contnously green
ii. the Ethernet indicator is contnously green
iii. the USB indicator is contnously green
iv. the Wireless indicator may or may not be contnously green
Pls post back with the generated diagnostic print-out before we can proceed with the other steps.
Additionally, try installing the Epson Stylus Photo RX600 direct to one of the USB ports of your PC. Use the installer/driver CD that came with it. Try using it as a regular printer. This will tell us status of the printer.
Good luck and kind regards.
Nov 11, 2007 | Computers & Internet
Linksys Wireless-G WRT54G Router Logo
49 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Ekse
Mike
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
