Question about Kenwood CD-423M 200-Disc CD Player
CD-423M THis morning I turn on the CD player and nothing happen. The disc loaded but I cant hear any music.
  • 1 more comment
  • hil2002plr Aug 19, 2008
    my player took the cd and loed into the drive after that no movement either the disk rotate or lens dectact.
  • I also have this problem. The cd loads but there is no sound. I would like to try to fix the amp if that is the problem. How do I test the amp?
  • I also have this problem, the cd loads but there is no sound. I wouldlike to try to fix the amp if that is the problem. How do I test theamp?
  • 29 Answers
The amp may be damage.
Posted on Feb 05, 2008
Rp8070d volume problem cant get volume . if you put your ear up to the speakers you can hear it but other than that nothing !!??
The CD player must be connected to an amplifier to work. You can not connect speakers directly to this unit. If you do have it connected to an amplifier, check to make sure any tape monitor switches are off.
Dec 10, 2017 | RCA RP8070D 5-Disc CD Changer Disc Direct...
Nakamichi cd cassette player 1 not spinning discs
There's a Music Bank 7-disc player in use in my bedroom these days. Nice unit, but they used to come in for service once in a while- from what I could tell, these units don't 'park' the CD drawers on a soft power off- they simply shut down. When powered up again, they sometimes let the disc last in play slide off the tray & jam the machine. I've had no issues, as long as I always hit stop, wait for it to park, and then shut off. The analog output's sound has been very good (has a coax out as well).
Jul 28, 2012 | Nakamichi Audio Players & Recorders
Cd wont play
If the player do switch ON, and it won't read CDs, the fault might be to its optical pickup unit. Seek tech support.
Jun 01, 2012 | Kenwood CD-423M 200-Disc CD Player
I cant hear the music very well... it is very faint and i have my speakers plugged in. how do i turn up the volume? i cant find any buttons to do so.
CD changers don't normally drive speakers (the lack of a volume control and speaker connections being a HUGE clue). What are you using for a speaker amplifier?
Sep 18, 2011 | Kenwood CD-223M 200-Disc CD Changer
Remote Control of Unit has ceased, tried the original as well as others. Otherwise the unit functions ok from the Front Buttons on the Player
Sounds to me like there's a fault in the remote censor of the CD player. You could have a look around inside following the point where the machine's picks up the signal from the remote. Otherwise it's off to the repair man.
Apr 08, 2010 | Kenwood CD-423M 200-Disc CD Player
Car CD player won't load Cd's - Peugeot 306
Yeah, the sensor that detects the presence of the disc is knackered - probably broken off. The eject will always eject the disc. Just press the button with no disc and you will hear it try. Look at ebay for a replacement - theyre dirt cheap!
Jul 13, 2009 | 2006 Peugeot 505
Loading but nothing happens
With the power turned off, open the DVD Player, and then open the top where you load the DVD into the player. Locate the laser lens and notice that the laser is attached to a transport assembly that moves the laser diagonally outward in a slot. 1. Slide this assembly outward to the end of its track. 2. Slide the assembly back inward to the closest inward position. 3. Repeat the process of sliding the assembly outward and then back inward.4. Put in a music CD and let it play all the way through. This helps to calibrate the laser head assembly movement. When the music CD is finished playing. 5. Put in a DVD, and you should have a working unit again This is a factory solution from Mintek that was given to a customer who ask for help with the forever loading disc problems. This solution may work on other models of portable DVD players. Most portable DVD players use this type of transport mechanism. Try this solution it might work for you.I hope this information helps your problem.
Apr 07, 2009 | Mintek MDP-1810 Portable DVD Player
12 Disc CD Changer in 2002 Corvette Convertible
I had this problem on my 2001 Corvette. I took the whole thing out, took off the cover and was able to get the jammed cartridge out by carefully pulling the stuck tray out of the carriage and then removing the entire carriage. Check to make sure your individual trays are not warped. Mine continued to work without problems for about three months and then it happend again. Another thing you can do is not to load a disk in the last (#12) slot. I think it's the one that gets stuck.
Nov 04, 2008 | JVC KD-LH7R CD Player
Says it's not docked, but it it is
Is your hardrive ok chceck it by listening to it and if you hear a clicking sound then its stuffed. Try reinstalling the CD that came with it and then reload the firware it soud work.
Jun 15, 2006 | Creative Labs Zen Touch MP3 Player
Remove DISC010 error
If there is a disc in the changer (I guess it's in the tenth slot), try removing it, if it doesn't work by 'normal' means and you feel brave, try shaking the unit a bit. If it doesn't help or you don't feel like banging on it, you'll have to take it for a repair (they open the unit and extract the disc, they get jammed sometimes).
Nov 05, 2005 | Kenwood CD-423M 200-Disc CD Player
Kenwood CD-423M 200-Disc CD Player Logo
101 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
