Question about Microwave Ovens
Whirlpool Microwave I have a built in Whirlpool microwave (integrated with the oven) Model RM280PX8O3. When I turn it on cook I get a loud buzz/hum followed by a blown fuse. It takes a couple of seconds to blow the fuse. When I replaced the fuse I can put it on defrost, and the lights, turntable, everything works, until the unit cycles on , then I get the same buzz/hum. Seems to be only making noise when it cycles to cook. After the buzz/hum I can turn it off quickly without blowing the fuse. I have read a couple of posts- looks like high voltage capacitor, transformer, or magnetron. Any way to narrow it down? Easy job to replace- any direction is greatly appreciated!
  • 3 more comments
  • TheSavant Feb 02, 2008
    After further review, looks like the model is RM280PXBQ3
  • TheSavant Feb 03, 2008
    Thanks for the tips- I ran the following tests (and an ohm test of the HV components):
    Discharge HV capacitor!
    2. Remove one end of the lead from the HV capacitor to the transformer.
    3. Start the oven.
    * Hum gone? If so, it is the HV circuitry, go to step 4.
    * If it still hums you probably have a faulty HV Transformer. (Not uncommon.)
    4. Discharge the HV capacitor again, reconnect wire and disconnect the 2 wires to the magnetron.
    5. Restart oven.
    * Hum Gone? If so, magnetron is shorted. Replace or get a new oven.
    * Hum still there? If so, go to step 6.
    6. You have either
    * Shorted HV capacitor,
    * Shorted HV Diode,
    * Shorted clamp diode across the HV Cap terminals (if one is present, about
    30% of microwave ovens use these). (The oven will run 100% without this
    protection for the HV capacitor but it should be replaced if possible.)
    * Some older Panasonic ovens have a HV reed switch and these can also short
    but these are rare now because of the age.
    After this test, and the ohm tests of the capacitor, diode, and HV transformer, It looks like I have a shorted capacitor or diode. I ordered them today, so hopefully this will fix the problem.
  • Anonymous Nov 08, 2008
    how to test magnetron
  • jellybean_mi Apr 08, 2009
    My Whirpool built in microwave hums too. But works fine otherwise. I did not notice any changes in cooking temps.
    I have no idea how to even start checking for problems. It is a microwave/oven combo. Do I pul it out completely?
  • Anonymous Mar 15, 2014
    loud hum, fuse blows
  • Microwave Ovens Master
  • 9,176 Answers
I would suspect the high-voltage transformer in this case, but the capacitor may be failing.
The high voltage section uses and generates voltages that can be instantly lethal.
So I don't recommend that anyone work in this area unless he has either a lot of experience or at the minimum, a good understanding of the safety issues and procedures involved.
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
Also, there should also be a very helpful "mini-manual" hidden inside the unit behind the control panel. It's very helpful when troubleshooting.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Here are some links you or a friend can use for test help, but read the safety warnings first:
http://www.gallawa.com/microtech/cap_test.html
http://www.gallawa.com/microtech/diode.html
http://www.gallawa.com/microtech/mag_test.html
http://www.gallawa.com/microtech/xformer.html
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Feb 03, 2008
6ya staff
SOURCE:
I have a "continuous" humming sounding when units are heating. The sound is very loud
The humming sound that occurs may be similar to the annoying buzzing my GE microwave produces at random. It could be mechanical vibration. Doesn't seem to affect cooking.
Nov 16, 2016 | Microwave Ovens
When microwave is started, why does it make a loud buzzing sound--like a Skil saw sounds?
Whirlpool Microwave Buzzing Loudly - ApplianceBlog
www.applianceblog.com/.../26531-Whirlpool-Microwave-Buzzing-Loud...
Aug 12, 2011 - 10 posts - ‎2 authors
My Whirlpool MT4155SPS-2 microwave oven has recently started to buzz loudlywhen operated. The sound is getting louder and more frequent ...
Whirlpool making intermittent loud buzzing noise Microwave ...
www.fixya.com > ... > Microwave Ovens
Whirlpool microwave ovens making intermittent loud buzzing noise related questions and answers. Ask your ... ...loud buzzing noise and it doesn't heat. i just tried it again and let it run for 1 minute. ... Question about Accuwave Microwave Oven.
Troubleshooting the Microwave: Potential Problems ...
www.appliancejournal.com/.../troubleshooting-the-microwave-potential-...
If your microwave buzzes loudly and produces no heat you probably have a defective power .... I have a whirlpool oven range and it's less than a year old. .... Humming sound stops when I open door to remove food, but when door is closed, ...
Whirlpool Microwave Ovens - Consumer Affairs
Feb 03, 2016 | Whirlpool Accuwave Microwave Oven
My microwave made a loud "pop"and now hums loudly
Since the microwave is humming, that tells me that the diode is bad and needs to be replaced.
Feb 04, 2011 | Whirlpool MH3184XP Microwave Oven
Whirlpool microwave makes loud buzzing noise
When your microwave oven won't cook your food, and, you hear a loud buzzing sound, it’s normally caused by a faulty (a) diode (b) high-voltage capacitor (b) magnetron.
The diode would be the most likely culprit of the three components. It’s also by far the cheapest!
Sep 21, 2009 | Whirlpool MH6140XK Microwave Oven
Odd buzzing after timer stopped, food was still being heated
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
r6uw
Aug 20, 2009 | Whirlpool MH1150XM Convection/Microwave...
Microwave Buzzing When Not in Use
Are you using a 3 pronged outlet and is it grounded? If you have a 2 holed outlet and are using a ground eliminator adapter, try turning the plug around to reverse the polarity. If this helps, then it would be advisable to have an electrician to ground your oven.
May 22, 2008 | Whirlpool MH7140XF Microwave Oven
Maytag Rangehood Microwave Loud Humming
Sounds like you just fried your magnetron. Normally when they go bad, they make a very loud noise like what you described. The smell concerns me because you may have ruined the waveguide as well. If the magnetron burns through the protective painted surface of the waveguide, the waveguide is ruined. In most microwave ovens this means replacing the entire unit because the waveguide is not replaceable. Putting a new magnetron in a damaged waveguide will result in the same arcing and eventual failure. In addition to the magnetron, the following components are part of the same high voltage network: HV Transformer HV Diode HV Capacitor Magnetron Thermal Cut-Out Any one of these components could have also been damaged. I DO NOT recommend taking any voltage measurements inside the HV network. Potentials of over 4000 volts can be reached and make it very dangerous for the do-it-yourselfer. Taking resistance readings with the unit unplugged is strongly encouraged. If you decide to pursue a repair, inspect the magnetron tip and inside of the waveguide first. If the magnetron is melted and/or there are burn marks inside the waveguide, a new microwave may be a in order. This actually may be a better option than an expensive repair. I hope you find this advice helpful.
Jul 31, 2007 | Whirlpool GH4155XP Microwave Oven
Microwave makes loud buzzing sound when on and no heat
Have you tried putting a cup of water in it and cooking on a low power level? If it buzzes only when it is on the cook cycle, that would narrow it down. More detals might help us help you, including the model number.
Mar 20, 2007 | Kenmore 62622 Microwave Oven
Microwave Ovens Logo
601 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
