Question about Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum
Hoover cleaner model f5865-900
I want to try to fix or repair my hoover cleaner. Appeared that the rotor will not turn,vacuum and water spray work. I understand that there may not any belt in it.
Can anyone please help me out?
Thank you
Lj
  • teon28 May 11, 2010
    Repair registree
    President:
  • 1,673 Answers
There is no belt, either the turbine part #43191003, or the brush block, the shaft that goes up into the turbine broke off part #48437022. The turbine is what drives the brushes.
Posted on Feb 10, 2008
Water won't dispense....how do I fix it?
Posted on Oct 17, 2008
Water wont spray from cleaner how to fix
Try cleaning the Flow Indicator Filter. Turn the Flow Indicator Cap counter-clockwise to remove, lift rotor and filter. Clean filter and replace in reverse order. Bissell's Consumer Care # 1-800-237-7691
Sep 16, 2015 | Bissell 9500 ProHeat 2X CleanShot Upright...
Hoover SteamVac LS F5899-910
Did you try to clean first the unit..
Jun 01, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Water dispenses without pulling trigger. How to stop it?
you should have a lever which controls this spray slid it all to one side then the other sometimes its just trial and error if this doesn't work then see if it has a cut of valve if so it may be broken
Apr 10, 2014 | Hoover F7225-900 SteamVac V2 Upright...
My hover extract deep cleaner won't spray water or cleaning solution
If you have the receipt from when you bought it, take it to the closest Hoover warranty center and they will fix it under the warranty at no cost to you.
Jun 11, 2017 | Hoover F7431-900 SteamVac Vacuum
I have the hoover automatic dual vac 5. this is the 3rd hoover rug cleaner i purchased and always the same problem the spray underneth the rotator bars hardly dispenses and the floor hardly gets wet, this...
The carpet is not intended to get soaked, like what you see with a spray application. If you are seeing a stream of water in the nozzle/tank during the recovery stroke, this is working properly.
Jan 17, 2010 | Hoover Steam Vac Dual V w/ SpinScrub...
Carpet cleaner pick up water
water outlet are pluged soap residue seal broken or miss alined
Apr 05, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover Steamvac Upholstery Cleaner will not spray water.
In my case when I pulled the trigger on the upholstery hose I barely got a drizzle of water. After looking at the parts online I realized the valve assembly on the spray end of the hose consisted of a black valve housing, with an inner spring and a white plunger part that sprays the water. The white plunger should move noticeably when the trigger is pulled. Since all 3 part of that valve assembly were replaceable I decided to try and take it apart. First I removed the 2 silver screws on the cover of trigger end of the hose and lifted out the valve assemble. The white plunger part was basically frozen in the black valve assembly. Tried pulling the white plunger out by hand wouldn't budge. So I use a pair of plier and pulled the white part out. Sure enough the whole inside was caked with what appeared to be old dried cleaner. I rinsed the spring and the white plunger. There were o-rings on the white plunger, I did not remove them but used an old tooth brush to clean out around them then reassembled. The white plunger now freeing slides a noticeable distance when the trigger is depressed and getting a large V shaped spray pattern. Lesson learned, I will now make sure I run plenty of plain water through the hose to rinse all the cleaner out after using it .
Jan 12, 2009 | Hoover F5832-910 SteamVac Supreme Vacuum
Hoover steam vac model F5853-900 series 17.9
Make sure that the recovery tank is completely close.
Oct 13, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum Logo
345 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
