Question about Hoover Soft Light Supreme U4262-930 Bagged Upright Vacuum
How to change belt on hoover soft and light supreme
I need to change the belt on my sweeper and dont have the manual.. Its also not obvious. please help!
  • 1 more comment
  • Anonymous Mar 27, 2009
    i have to change the belt on my hoover seeper and do not have the manual
  • danhunt May 23, 2009
    I have a Hoover Upright "Soft & Light" model U4266-930 that uses belt 38528-027. Does the solution given apply to my model?
  • 126 Answers
Turn the machine over so you can see the bottom. If you look carefully at the plate that covers the roller, at the back behind the brush opening on either side, there is a clip that is recessed and you can push it with a flat blade screwdriver as you lift the plate up. This will allow you to take the plate off and remove the roller. Put a new belt around the roller pulley and insert the other end of the belt through the opening in the roller housing of the machine and re-install the roller. once it is installed, rotate the roller by hand to make sure that the belt is not pinched. Replace the bottom plate and rotate the roller again. The belt is running between two guards and it is possible to pinch it and damage it. This is why you rotate the roller by hand, to ensure that it is not pinched.
Now, if you look at the back wheels, on the side of the machine where the hood meets the bottom, there is a clip on either side that you can pry on gently and this will release the back portion of the hood. To release the front portion of the hood, there are similar clips located at the back corners of the bottom plate. Basically, you are prying the hood away from the base of the machine and releasing it. Now, turn the machine over, (back on it's wheels) and lift the hood off the machine. The handle of the machine should be down for this. You will see the belt where it comes through the roller housing and you will have to grab it and pull HARD and stretch it around the motor shaft. Once it is attached, rotate the belt and roller by hand to make sure that everything turns easily. Replace the hood and press the sides gently. You should hear and feel the latch/clips snap into place. If your machine has a height adjustment, there will be an adjustment knob that will have come off when the hood was removed. Replace the knob and you are done.
Posted on Feb 03, 2008
How and where does the wheel clip get re-installed? can't get that in properly....thanks
Posted on Jul 08, 2008
  • 22 Answers
DomVac's solution does also apply to the "Soft & Light" Model #U4266-930. I tried the solution and it worked! Thanks DomVac!
Posted on May 24, 2009
Removing beater bar from Hoover canister vac sweeper head
click here > http://hoover.com/file/402/ for the manual it will give you full instruction on belt change on page 7
Jan 08, 2013 | Hoover S3765-040 WindTunnel Bagless...
How do I change the belt on the Soft and Light Hoover Model #U4266930 Hoover send the manual through email, but apparent it is gone now...missing on my favorites list . Attempted to request second...
I have same problem, somehow take top all apart, looks like allen screws holding bag container on, remove that, get to screws right underneath top shell, then get to motor pulley from above . be careful not to pull off motor pulley when wrapping other end of belt around brush underneath, or else you'd have to take top all apart again. Good luck.
Jun 13, 2011 | Hoover Soft Light Supreme U4262-930 Bagged...
My Hoover Soft and Light Supreme upright vacuum has a model #U4264-930. The last two numbers in serial # are 05. I have no manual and need to change a burned out light bulb. Need to know two things:...
http://www.vacshopusa.com/pdf/hu4253930.pdf Use this link to download a pdfd scehmatic for your model. This link is the site I got it from. http://www.vacshopusa.com/elite_%26_elite_ii.htm You may find more info there. Just from looking at the schematic, I would guess the bulb cover would pop off (carefully) and see what type of bulb it is. Remove it, take it with you to buy a replacement.
Nov 21, 2010 | Hoover Soft Light Supreme U4262-930 Bagged...
I need instructions on how to change bag in a Hoover Soft & Light Supreme upright vacuum cleaner. Thank you.
Here is a link that will show you how to change bag (and more).
The model number of manual is not the same as yours but it will work for your machine.
http://www.hoover.com/pdfs/manuals/C1404.pdf
I hope this helps.
Feb 02, 2010 | Hoover Soft Light Supreme U4262-930 Bagged...
Can't get to motor to connect belt after removing brush cover
I followed the instructions that were supplied @ the FixYa site, to remove the hood. Removing the hood was the problem. Just follow the online users manual pages 22 thru 26. you must spread the hood by the rear wheels to remove. Thank You Very Much. Delano
Jun 29, 2009 | Hoover Soft Light Supreme U4262-930 Bagged...
Hoover sweeper model U4263-930 belt change
undo screws on bottom of vac take out brush and belt put belt in then manewver brush in
thank you for useing fixya please rate me
Feb 07, 2009 | Hoover Vacuums
No suction for u4264-930
This link at the Hoover site is a general manual for the older uprights. It shows how to replace belt etc. Mine is a "Soft & Light" and it worked for me:
Dec 23, 2008 | Hoover Soft Light Supreme U4262-930 Bagged...
How do you install a vacuum belt for Hoover soft and lite supreme????
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=764033
Generic problem for all Vacuums
Posted by winklefishxo on Jul 10, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Remove the bottom plate by removing the screws, clips or levers and then if you cannot get @ the belt from the bottom then the top cover should come of and then you can get @ the belt. Cut the old belt off and then lift up the side of the brushroll with the belt pulley, then slide the new belt onto the belt pulley and re-install the brushroll, then use a belt puller or a screwdriver with a left or right hand hook and then stretch the belt onto the motor pulley and then track the belt so that it is running in a straight line. Now, replace the bottom plate.
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 10, 2008 | Vacuums
How to change a Hoover Elite sweeper belt
on the bottom there should be a few screws take them out and a cover should come off the belt is right there. hope this helps
Dec 18, 2007 | Hoover Elite U5061-900 Bagged Upright...
Hoover Soft Light Supreme U4262-930 Bagged Upright Vacuum Logo
3,468 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
