Question about Toshiba Satellite P35-S611 Notebook
My Satellite P35-S611 will not run on ac power nor will it charge the battery
This can be due to 3 reasons.Check these out and report back so that i can help you out
1.The AC power cord is damaged:Try connecting another chord to see if its the problem is with this
2.Damaged Battery
3.This is slightly tougher..you will need to open your laptop check if the DC powerjack is damaged..If you dont know how to check this come back and ask..I will guide you
Hi eagle338 I need help with this one
thanks vader3510
  • 1 more comment
  • hypernez Jul 02, 2008
    P35 S6112 Charges battery just fine. With Ac plugged in...Icon says running on battery even while plugged in . . Take 100% battery out ,leave Ac plugged in ...unit dies. Put battery back in take Ac out ...unit runs fine. Plug Ac in and it just runs on battery. In order to recharge battery..Unit must be turned off. When Charging battety sometines the yellow charging light goes out ....I take battery out ...put back in and it starts charging battery again. after 2 or 3 hours of this battery indicator light turns green.
    Any Ideas?
    Thanks
  • mhungry Sep 04, 2008
    Hypernez,
    Did you have this problem AFTER you did a Toshiba update? I think I have the same problem but it occurred after the update and Im debating whether to recover the whole computer.
    Joe
  • eagle338
    eagle338 May 11, 2010
    hi vader! I cant read the complete problem. Pls post your question again and i will make sure its done for!
    Regards!
    Eagle338.
    Problem Solver:
This happened to me also after window update ..i think it was updating with sp3
Posted on Sep 21, 2008
  • nadia-2 Sep 28, 2008
    it has nothing to do with software ..it's the power supplu inside ..needs to be changed!
    i took th elaptop appart and came out to this solution
Toshiba P35-S611 wont power on! When i plug it in no led lights come on, i get nothing out of it. the led on the battery charger lights up but nothing on the computer, someone said maybe the motherboard? ...
yeah if you are planing to do it yourself..it is worth ..I just bought last week a broke one and I payed something under 100$ ..and I changed the motherboard in one that was doing the same..so ...if you think you will use it ..its worth looking on ebay ..or parts to buy what is missing
Anyway check the power line on the motherboard ..it may be just something unplugged..or a little part..but if it does not get any power..its just that ..
The fact that is charging the battery it means that the power is ok from the charger and the entry on the board...so check the ram memory ..and the power cable of the board...cause if the charging is ok ..and the fan is working ..it may be something like a cable or the switch itself..( in this case the switch board is changeable in a few minutes and has just a plug and 2 screws..
May 08, 2010 | Toshiba Satellite P35-S611 Notebook
The inner connector for the AC power adapter seems to be loose inside, how do I get a replacement for that? Also, my AC power will not kick in when my battery gets low, what could be the reason for this?
hi i had the same problem, there is a fix to this but it means taking the laptop apart ( you will have to do anyway ) and where the power plug is it has come un soldered from the board you can try re soldering it back on then to prevent it coming adrift get a hot glue gun and cover it in hot glue this will stop it from moving about in future....hope this helps
Feb 21, 2010 | Toshiba Satellite P35-S611 Notebook
Toshiba Satellite P35-S611, power up failure.
Open the processor area located under your laptop. You can detached and re attached the processor, some sort of lose contact on pins. If same problem occur, your processor may burnt out. pm me caligayanstep@yahoo.com i will assist you remotely.
Oct 21, 2009 | Toshiba Satellite P35-S611 Notebook
The fans run but the computer fails to turn on
Likely either a bad power connector (common) or the charging circuit on the motherboard may have a problem.
Oct 12, 2009 | Toshiba Satellite P35-S611 Notebook
Satellite P35-S611 has trouble charging
If you have to wiggle the power cord it is most likely the DC jack on the motherboard. It is usually the center pin in the the jack that breaks the solder point and the small tension band inside the jack housing weakens.
Sep 26, 2009 | Toshiba Satellite P35-S611 Notebook
AC /batteries problem with my laptop
Please try to take the battery out then try to power on using the ac adapter only. It is okay to insert the battery this time. Hope this works. Thanks.
Sep 20, 2008 | Toshiba Satellite P35-S611 Notebook
Always running on batteries
You can still use your laptop even if you take out the battery and run on ac alone. You can also leave your battery in with the ac plugged in for 4 hours to charge it even if the laptop is off. Hope this helps. Thank you.
My satellite P35-S611 will not run on AC power nor will it charge the battery
I have just fixed the same problem on my Toshiba p35 s611.
The power jack inside the laptop had been damaged. To reach the problem you must take apart the entire laptop (there are a few guides for doing this online). Next I simply found the positive connection coming from the jack (it is the wire coming out of the back of the jack) and followed it to where it enters the motherboard. I simply flipped it around and re-soldered that one spot. Other sites recommended I remove the jack but I couldn't melt the solder enough to do so, however just trying and adding some fresh solder was enough to fix the problem. I no longer need to jiggle the power connector to the right angle just to get power.
Feb 02, 2008 | Toshiba Satellite P35-S611 Notebook
Toshiba Satellite P35-S611 Notebook Logo
186 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
