Question about Sanyo PLC XU33 Multimedia Projector
Connecting Ibook G4 to Sanyo PRO xtrax projector
How do i connect to the projector?
  • kohndola Feb 03, 2008
    Thank-you for your instructions. I appreciate it. Locally no one had the right mini DVI adapter so I ended up using my IMAC for the event which went well. cool site. Good to know there is help out there.
  • Anonymous Mar 12, 2014
    COLORS MUTED ON SANYO PRO PROJECTOR
    Brigadier General:
  • 6,966 Answers
Most of the Apple iBook G4 series have a video out port on the left side. This is a non-standard port and would require the use of an adapter (Apple VGA Display Adapter) that is normally included with the laptop package when first bought. The VGA's output connector is the standard 15 pin HD D-Sub (HD-15).
On the other hand, the Sanyo PRO XTRAX projector is capable of multiple input type of connectors. They are: a) RCA type composite video in, b) DVI, c) RGB, c) RS232, d) S-Video, e) USb and f) VGA. You would then be using the latter, VGA since it matches the Apple VGA Display Adapter.
To connect the iBook to the projector, you would need a length of VGA cable that are available in most projector/computer stores. Here, here and here are examples of commercially available.
Please refer to the images below.connecting Ibook G4 to Sanyo PRO xtrax projector - c02d50f.jpg
Hope this be of some help/idea. Pls post back how things turned up or should you be in need of additional information.
Good luck and kind regards.
Posted on Feb 03, 2008
  • Louie  Role
    Louie Role Feb 04, 2008
    Hi again,
    You are more than welcome, happy that things are working.
    Am glad to be of assistance and appreciate likewise the rating.
    Cheers.
You can find a more affordable VGA monitor cable at ShowMeCables.com
Posted on Nov 07, 2008
4 Suggested Answers
SOURCE: Sanyo Pro Xtrax
You need to change th bulb. It's damaged
Posted on Nov 30, 2007
  • 84 Answers
SOURCE: Sanyo PRO Xtrax Multiverse Projector powers on but no reflection appears
broken lamp?? check for little cracks in the bulb bar.
If lamp is discoloured( dark grey), overheating is cause, no cooling after using the PJ.
Posted on Sep 25, 2008
SOURCE: Sanyo Pro Xtrax Projector
not all computers are F4 - some are F7... - If there is not a small graphic on each Function button - just press and hold your function button and I'd start with F3 then F4 then F5 and so on - often your image will appear on the projection screen and disappear from your laptop - just re press Function and the appropriate key - you may also need to change your display - go to your control panel then display then settings and you will want 1024x768 - as far as cables you will need a male VGA that will plug into (usually blue) connection on your laptop and then depends on what type of projector you are using - it may take a VGA or RGB (5pin cable ~ red green blue horizontal vertical) make sure that in your menu settings that you have it set to the same as the input you have plugged into
Posted on Feb 13, 2009
Connecting sanyo pro xtrax multiverse projector to a Macbook pro
VGA to HDMI cables don't work. They're a con. VGA is an analogue signal. HDMI is digital. It's not possible to convert from one to the other with just a bit of wire.
Sep 02, 2014 | Sanyo PLC-XU101 Projector
Connected the Sanyo Pro XtraX Projector, but cannot get image to fit screen. Used the zoom button, but that does not bring it far enough down to size. HELP!
Is the projector permanently mounted or can you move the projector closer to fit your screen. This should do the trick, unless I'm missing something.
Sep 23, 2009 | Sanyo PLC XU35 Multimedia Projector
Sep 25, 2008 | Sanyo PLC XU35 Multimedia Projector
Sanyo Pro Xtrax PLC-XU50
Hi there
If you have the know how open up the machine and replace the fuse on the Powersupply board ( where the AC socket sits in )
If this still occurs , I'm afraid you will have to replace the Powersupply board.
Apr 09, 2008 | Sanyo PLC-SU50 Multimedia Projector
Sanyo pro xtrax
I am not understand the exact problem.
Can you pls explain briefly about your problem?
Dec 07, 2007 | Sanyo PLC XU35 Multimedia Projector
Sanyo Pro Xtrax
Sep 03, 2007 | Sanyo PLC XU35 Multimedia Projector
Sanyo PLC XU33 Multimedia Projector Logo
1,484 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
