Question about Mitsubishi WS-55813 55" Rear Projection HDTV
Screen blacks out
After watching TV for 2 hours, screen on SAT input (DVI) starts horizonal roll. Switch inputs and find black screen on ANT-A, Component 1 (DVD) and DTV input from SAT. Turn off and on, works fine for 10-15 min and problem returns. Turn on next day and problems returns again after 2 hours.
    Scholar:
  • 90 Answers
Check your set for coolant leakage. It is very prevalent on Mits HDreadys.
If your 4 layer Signal board - beneath the blue gun - has coolant on it, you'll have problems finding a replacement. If it's the boards under the other 2 guns, they can always be repaired as they are single layer.
A drip shed should be installed to keep the coolant off your boards.
Mr Bob
Posted on Feb 03, 2008
Westinghouse SK19h210Sd black screen with sound only
Change input device to some other like a DVD player and see.
Switch off TV, switch off power, remove plug and wait for 48 hours and retry.
If problem persists, call in a qualified service technician.
Aug 06, 2012 | Westinghouse SK-19H210S Television
I've got a toshiba 53hx71 that the screen rolles when the tv is on in the video inputs or the ant inputs. when there is nothing on the tv it has red squigle marks on the black screen. When you watch a...
Most of the time the Hyper Board failing is the cause of this problem. It will eventually get worse where it also affects the HD ins. Unfortunately the Hyper Boards are no longer available from Toshiba and have not been available for quite some time. My suggestion is to coast with it and replace the Set when the HD ins fail.
Sky Assoc
Nov 24, 2009 | Toshiba 53HX71 53" Rear Projection...
HS500, white/light at top of screen
I believe input 5 is hd input wich is different from the others
you may want to try hooking the sat to any component input to find out if there is any difference
Jul 19, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
"ant A" and "ant B" inputs go black when the tv is first turned on.
Try opening that "Ant A, B" device and apply some fresh solder to all the components inside. Also you can try to by-pass that device using the connector below. One end connects the cable in and the other end connects to the circuitry inside the TV.
Jan 24, 2008 | Mitsubishi VS-60609 60" Rear Projection...
Black TV Screen above Channel 46
Try resoldering the tuner can's connections to the main board.
If that doesn't solve it, you need a new tuner.
Or do what all too many people do, use the VCR's tuner and just leave the TV as a monitor.
Jan 03, 2008 | Televison & Video
LINES ROLL THROUGH THE PICTURE
Not to discourage you, but here is an extensive thread from other Samsung owners with similar problems:
forum.ecoustics.com/bbs/messages/2/77447.html
Sounds like the digital/DMD board has noise in those modes.
hope you are under warranty
Dec 31, 2007 | Samsung HLN617W 61" Rear Projection HDTV
Screen flicker when watching 1080i
Component video has a max resolution of 720p. in order to use 1080i or p you have to use hdmi or dvi connections. That is why you get the flicker.
Dec 08, 2007 | Onkyo TX-SR304 Receiver
No Picture, sound is all static
Make sure the ant. input switch didnt change and check the ant. connections If that dosent work sounds like a defective tuner.
Mar 30, 2006 | Philips Magnavox 27MS343S 27" TV
Mitsubishi WS-55813 55" Rear Projection HDTV Logo
128 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
